Question about Panasonic KX-T7630 Corded Phone
Need to store new extension numbers
We have a KX-T630 and I need to re- arrage the extension numbers. When I have tried to change them some say EXT - 115 whilst others only say 115. As they do not show ext, the light does not light up when that ext is busy. Can you please advise?
  • receptionwa Feb 18, 2008
    that didn't help!
Ghgiuyl,hjkhgkfkm
Posted on Feb 17, 2008
How do I rename Extensions?
Press program **1234
use up down volume keys to find extension hame
selct ext. number
enter new name
store
these changes dan only be made from a 3 line display phone
May 22, 2014 | Panasonic KX-T7636-B Corded Phone
Need to change extension numbers
Guessing you mean add or change extension numbers under the buttons, since you don't "add" or change extension numbers on the phone. From your set, press program dial 99 and the button you want to program. then , dial 1+ ext number and press STORE.
Do that for all the buttons you want to change then pick up the handset and drop it back down to exit programming.
Apr 10, 2013 | Panasonic KX-T7433B Corded Phone
I can't changed name on my phone. please help me.
The extension names can be changed in admin programming from a predesignated programming phone. Typically this phone is the attendant phone as in ext 100 or ext 101.This phone needs to have an LCD screen.
1) Press <program>
2) Dial **1234(1234 is the default admin password)
3) Dial 004 for Ext name programming
4) Press <enter>
5) Dial extension number that you want to change name of as in 102
6) Enter name (20 characters or less )
7) Press <enter> to store
8) Press <end> or lift handset and return to cradle to end programming session
Dec 08, 2010 | Panasonic KX-T7730 Corded Phone
How do I change the extention names on KX-T7730?
If you are using the KX-T7730 phone on a Panasonic KX-Txx 308 or 824 system.
From the Switchboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle/hook :
1. Press PROGRAM * # followed by the system password ( default is 1234).
2. Now press 604 and then SP-PHONE. Enter the jack number you wish to change ( 01 is extension 101, 02 is extension 102 etc. ).
3. Enter the name ( basically the same as texting on a cellphone ). Press AUTO DIAL / STORE to save your change.
4. To go to the next extension press SP-PHONE. Don’t forget to press AUTO DIAL / STORE to save your change after each name entered.
5. Press PROGRAM to exit program mode and you are done.
Mar 23, 2010 | Panasonic KX-T7730 Corded Phone
How do i change the phone extention number - Panasonic KX-T7665
It depends on your phone system, the smaller ones, 50, have modular jacks to distribute the extensions and you can simply move the pluged in extension wiring on the control unit, for instance if you are 102 and the other phone is 103, simply swap the plugs on the main control unit. The larger Panasonics have direct wiring so you need a punch tool and some cross wire to move an extension.
Oct 01, 2009 | Panasonic KX-T7633 Corded Phone
Changing the names fixed to internal extension numbers
If you can not log into the programing tool to change it that way then you will still need the Installer password. However from the main ext typically the first ext or 101
hit the Program soft key just below the LCD
push * then #
password
004
ext number you wish to change
type in new name
ENTER
END
Apr 14, 2009 | Panasonic KX-T7633 Corded Phone
The incorrect name being displayed when you use a preset number
The side buttons is programmed as extensions
To change the extension names follow these steps :
Jan 12, 2009 | Panasonic KX-T7730 Corded Phone
Panasonic Adv Hybride System KX-T7730
If you are using the KX-T7730 phone on a Panasonic KX-Txx 308 or 824 system. From the Switchboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle press PROGRAM * # followed by the system password ( default is 1234). Now press 604 and then SP-PHONE. Enter the jack number you wish to change ( 01 is extension 101, 02 is extension 102 etc. ). Enter the name ( basically the same as texting on a cellphone ). Press AUTO DIAL / STORE to save your change. To go to the next extension press SP-PHONE. Don’t forget to press AUTO DIAL / STORE to save your change after each name entered. Press PROGRAM to exit program mode and you are done.
PLEASE rate / vote this answer if it was helpful.
Thank you.
Sep 18, 2008 | Panasonic KX-T7730 Corded Phone
Kx-t7630 product spport
This is how I did it:
1. Press the 'Program' button 2. Then dial ** (star, star) 3. Enter the password (usually 1234) 4. Press 'Next' until you get to 'Ext Name' 5. Press 'Enter' 6. You will need to know the Extension Number of you phone, when you find out enter it (eg: 104 or whatever yours is) 7. Press 'Clear' to get rid of the old name then start entering the new name via the number keys. Note: If you keep cycling through the letter on each number you can get to lowercase or uppercase letters. 8. Press 'Enter' then you are all done... pick and hang up the handset.
Feb 11, 2008 | Panasonic KX-T7630 Corded Phone
Panasonic KX-T7630 Corded Phone Logo
253 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
