Question about SanDisk Sansa e260 MP3 Player
Sandisk Sansa Connect
Hello. I got a Sandisk Sasnsa today and now after a software update, I can no longer connect to my wireless router. My router is NOT static but I found the IP and MAC address from when it connected before the update, but there doesn't seem to be any way for me to enter it in. Also I am unable to erase my wireless connection from the list of networks.
  • Anonymous Feb 15, 2008
    I download files to the sansa the computor says it's already on the sansa but you unplug the sansa and it isn't up there. also the computor does not detect the music files that is on the sansa
GO TO FUTURE SHOP
Posted on Feb 17, 2008
I dont have sandisk driver for my sansa E260..i cant transfer songs..
Sansa Not Recognized: Try connecting it to the back of your computer or another computer the back straight to the motherboard this should be USB 2.0 and see if it will recognize it as sansa or Drive/removable drive. if it does then download the sansa update software and install it. Make sure you disconnect the sansa and connect it when asked. This will update your sansas firmware and add the Usb Mode. Try to connect it to your computer at home it should recognize.... link for update software (http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) download to a flash drive much easier. Make sure USB mode is MSC
Recovery Mode may also allow your computer to recognize the sansa
lock your sansa hold in the rec key on the left at the same time push the menu/power button this will take you to recovery mode then connect to the computer Start the update software when finished disconnect.... Sync to upload songs to the sansa......Hope this works
Dec 01, 2010 | SanDisk Sansa e260 MP3 Player
I have always been able to sync music on my Sansa MP3 player until today. It wont accept any new music, but the music files are not hidden. When I try to sync the music, it gets about half-way through a...
Freezing up while playing songs Check and see if there is a boot file in any of the folders on the player use the Explorer to check Check both MTP and MSC modes and unhook your player
Recovery Mode: download the update software and install then lock your sansa hold in the rec key on the left at the same time push the menu/power button this will take you to recovery mode then connect to the computer Start the update software if it doesn't start automatic goto /start /all programs /Sandisk/sansa updater/ sansa updater and start it up manually... follow instructions on the updater and the sansa. http://www.youtube.com/watch?v=_95hLqZxCHc&feature=related here is a link to a kid showing you how to goto recovery mode.
Update software from this link..
and install the software before you recover
Delete songs and Format (Helps with try to delete BAD TRACKS and folders that will not delete(Some ripped CD folders).. Go to my computer scroll to sansa or your MP3 player and open the music folder and open each sub folder and delete Songs manually then delete the folders them selfs then format a couple of times hope this works
Jul 01, 2010 | SanDisk Sansa e250 MP3 Player
My sanddisk won't connect to my computer what do i do?
Sansa Not Recognized: Try connecting it to another computer the back straight to the motherboard thIs should be USB 2.0 and see if it will recognize it as sansa or Drive/removable drive. if it does then download the sansa update software and install it. Make sure you disconnect the sansa and connect it when asked. This will update your sansas firmware and add the Usb Mode. Try to connect it to your computer at home it should recognize IF not try a laptop.... link for update software (http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) download to a flash drive much easier. Make sure USB mode is MSC
Jun 26, 2010 | SanDisk Sansa e250 MP3 Player
Where can i download sandisk media converter?
Sansa software: Firmware updater/Manual/Video Converter
Link to Sansa Softeware
Download and install. run.. connect player when asked.. update if need
be... download video converter. run converter with sansa player connected.
it will convert and install video en you start your computer for now on
Jun 10, 2010 | SanDisk Sansa e260 MP3 Player
My computer doesn't recognise my sansa 260.
Sansa Not Recognized: Try connecting it to another computer the back straight to the motherboard ths should be USB 2.0 and see if it will recognize it as sansa or Drive/removable drive. if it does then download the sansa update software and install it. Make sure you disconnect the sansa and connect it when asked. This will update your sansas firmware and add the Usb Mode. Try to connect it to your computer at home it should recognize.... link for update software (http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) download to a flash drive much easier. Make sure USB mode is MSC
Apr 08, 2010 | SanDisk Sansa e260 MP3 Player
How to put music in a sandisk sansa
Download the Manua; after you run the link below ....Put check next to converter/firmware update/Manual download...Go to your start menu programs go to sansa choose Sansa updater follow instructions.......(http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) here is the link After installation connect your sansa......
Also make sure you are connected to a 2.0 usb the back of the computer2.gif is best (the motherboard).... USB mode located on the sansa if asked to change to MSC goto menu press enter scroll to settings press enter scroll to usb mode press enter scroll to msc press enter press menu.....Connect should auto start sansa software..... Sansa software/driver Updates firmware follow instructions Downloads manual Downloads converter
You can make another music folder (music1)put music in this....
Oct 25, 2009 | SanDisk Sansa e260 MP3 Player
Sansa latest updates
Download the converter after you run the link below ....Put check next to converter/firmware update/Manual download...Go to your start menu programs go to sansa choose Sansa updater follow instructions.......(http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) here is the link After installation connect your sansa......
Also make sure you are connected to a 2.0 usb the back of the computer is best (the motherboard).... USB mode located on the sansa if asked to change to MSC goto menu press enter scroll to settings press enter scroll to usb mode press enter scroll to msc press enter press menu.....Connect should auto start sansa software..... Sansa software/driver Updates firmware follow instructions Downloads manual Downloads converter
Oct 04, 2009 | SanDisk Sansa Fuze MP3 Player
I'm trying to charge my Sansa MP3 player but am getting and error USB Device Not Recognized Help PLEASE!!!!
Try connecting it to another computer and see if it will recognize it as sansa or removable drive. if it does then download the sansa update software and install it. Make sure you disconnect the sansa and connect it when asked. This will update your sansa and add the Usb Mode. Try to connect it to your computer at home it should recognize.... link for update software (http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) download to a flash drive much easier I used my friends labtop it worked USB 2.0
Apr 17, 2009 | SanDisk Sansa e260 MP3 Player
System update is not available
Try connecting it to another computer and see if it will recognize it as sansa or removable drive. if it does then download the sansa update software and install it. Make sure you disconnect the sansa and connect it when asked. This will update your sansa and add the Usb Mode. Try to connect it to your computer at home it should recognize.... link for update software (http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) download to a flash drive much easier ..Make sure sansa usb mode is in msc
Apr 14, 2009 | SanDisk Sansa e260 MP3 Player
I cant donlod any songs to my sasnsa e200
ok buddy..try this...format the mp3 player completely once.. then download the songs.. try it with the windows media player.. if it doesnt work then try to re install windows media player or try to update it from microsoft website.. :)
Sep 15, 2008 | SanDisk Sansa e200 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
