Sites don't fill in completely
Websites have lots of blank spots where pictures should be. Some writing is too big for boxes. Some writing is faded and hard to read. Can be on a website I know has color, graphics, etc, from looking on other computers. Miss lots of information. If hold cursor over blank spot will sometimes say what's there or you can click blindly and things will appear.
Example, on AOL email site, there should be little boxes to check on left to delete messages but boxes don't show up. Can still click on spot where they should be and will delete, but can't see them. What can this be??
    Master:
  • 474 Answers
Try update-ing your Flash and Java, Google search Flash or Java and you should get plenty of hits for it.
Posted on Feb 15, 2008
Who do i contact for replacement cushions
You should go to www.reliable-store.com they have got books on every vehicle and also how to service/repair it,
service/repair/owner's/maintenance manual with
parts info, fuse box, gear box, torque specs,coiling, wiring diagrams, electrical diagrams, fuse diagrams, error codes, etc everything
Worth it
Mar 14, 2018 | Garden
The boxes are blank how do I see the pictures or anything in the boxes
try right clicking on the blank boxes and then select picture.
Sep 18, 2015 | Facebook Computers & Internet
My facebook only contains writing all boxes where pics and posts are are completely blank what happened
Is this on a cell phone, tablet or PC? Have you tried another device to access your FB page?
Oct 28, 2014 | Computers & Internet
Hi, I have a trouble with this toy, the writing pad don´t works, if I type a line or a letter, the pad fill areas that I don´t mark, the square pad fills completely and I can´t see what I...
Hi!
Please try removing the batteries first and make sure you use fresh ones. If it is still not working properly, it could be a malfunctioning LCD screen and might need replacing.
Feb 21, 2012 | LeapFrog Scribble and Write
Refilling procedure
You need to specify what brand is your printer.But the procedure is as simple as dirty. Make sure you have a cloth or paper to handle the messy part :).
Requirements: 1. Printer-Ink 2. Syringe with thin needle3. Piece of cloth
I will write how to refill HP cartridge, because I don't know your model.Ususally Hp cartridges have colored or black spot ont white sticker.Under this spot there is a tiny hole. This hole is designed to be used for refilling. You need to pierce the spot with the needle and start the refilling process.Make sure that there are no bubbles in the syringe and start filling slowly the cartridge. Do not hurry! Don't fill the cartridge to its full capacity. If your cartridge is 20ml fill only 15 or 16ml.After you finish set aside the cartridge for 30 minutes so that the ink settle. This is it!Good luck!
Dec 19, 2011 | Office Equipment & Supplies
Is Windows 98 too outdated, to enable burn to a disc
Yes it is possible to burn them to a disc. Or the simplest way is get a USB flash drive and save them all there.
Oct 08, 2009 | Computers & Internet
When initially powered up the picture is normal after a few minutes the picture fades and exhibits curvature along the edges. The picture also no longer fills the screen to the edge. If it gets warm...
Power off after warming up and picture fading problem:
CHECK C2B1 100 UFD 16V OFF PIN 2 IC202 ON THE MAIN PCB.
BTW, on most Hitachi circuit boards there are small green lights in the circuitry that show if a section of the set is working. Also,there are small protection fuses that look like resistors on the board around the power supply transformer. Check to see if any of those are open and it will lead you to the trouble spot. More than likely on that set it is convergence, vertical, Cold solder in horizontal (FBT or H.Drive xfmr.), cold solder at vert. output, regulator i.c., or audio out. Make sure you check the fuses that go to the convergence amps and look for discoloration on resistors surrounding conv. STKs. These are prone to change in value or burn up. Hope you have some luck solving this, Russmann.
Aug 24, 2009 | Hitachi 65SWX20B 65" Rear Projection...
Picture in high def does not fill screen
That is normal. Most HDTV's have a format or picture size option on the remote or menu. It will give you options like full, stretch ot zoom to fill in the blank spots. The problem is those settings can also distort the picture size so people look funny.
Feb 28, 2009 | Protron PLTV-37 37 in. LCD Television
Color fading, orangy red, video adjustments don't fix.
if it is a tube type unit you may not find a new tube they are almost extinct ,
also, most tube malfunctions are caused by improper voltage, only a qualified tech should work on the high voltage section of a tube tv,,, it can kill you even if it has Not Been Plugged in for a whole year
re-post with the make and model number for further assistance
Apr 08, 2017 | Televison & Video
Computers & Internet Logo
44 people viewed this question
Alun Cox
David Payne
David Payne
