Radio Shack Pro-82 Scanner Logo
Posted on Feb 14, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Reprograming im needing to reprogram my scanner with new channels.
Mechanic688
Level 2:
  • Expert 204 Answers
  • Posted on Feb 16, 2008
Mechanic688
Expert
Level 2:
Answers
204
Questions
Helped
140498
Points
542
Hi, looks like page 24 of your manual covers that part.
1. Press PGM. PGM appears. Then enter the channel number (1-200) where you want to store a frequency, then press PGM again.
2. Use the number keys and DELAY/. to enter the frequency (including the decimal point) you want to store.
3. Press ENT to store the frequency into the channel.Your scanner automatically rounds the entered frequency down to the closest valid frequency.For example, if you enter a frequency of 151.473, your scanner accepts it as151.470.
If you need a new manual, you can download it here.
http://rsk.imageg.net/graphics/uc/rsk/Support/ProductManuals/2000315_PM_EN.pdf
If your needing new freq's to use, you can go here and click on your state and county and get a list of freq's.
http://www.radioreference.com/apps/db/
I hope this helps you with your question, let us know,, Mechanic
2answers
How to do the relearn/reset after replacing ecm in 2001 monte carlo
DEALERSHIP HAS TO REPROGRAM THE NEW PCM.YOU NEED A GM SCANNER TO REPROGRAM NEW PCMS IN GM VECHICLES THE GM VECHICLES FROM 1996 UP TO 2011 HAS TO BE REPROGRAM AT DEALERSHIP, HOME MECHANIC CANT REPROGRAM IT.YOU NEED GM TECH 2 SCANNER.
Need to replace computer on 2002 chev malibu . What is the proper steps to take in removel
YOU CANT REPLACE PCM AT HOME BECAUSE YOU NEED SPECIAL DIAGNOSTIC EQUIPMENT TO REPROGRAM THE NEW PCM.YOU NEED GM SCANNER THAT CAN REPROGRAM RELEARN CKP AND CMP.RELEARN IDLE AND REPROGRAM THEFT SECURITY SYSTEM.
How do you clear all channels so i can put the channels that i want in it
There is no need to clear the scanner before reprogramming. When you enter a new frequency it will automatically overwrite the old frequency. To clear unwanted frequencies you can program "0.0" into any channel to clear it, or simply use the LOCKOUT feature to prevent the scanner from stopping on a channel.
1helpful
Need to reprogram hand held pro 96
Radio Shack can "CLone" your scanner with one in the store - try that first to see if it will work and let me know.
Citizen band scanner'
Thanks I solve the problem by going online to the local police dept. in my area and located the channels I needed' then program the scanner.
Need programing instructions
try this website here it has all uniden products http://www.uniden.com/index/manuals_results.cfm?cat=3 i believe it uses the same manual as BC248CLT
2answers
How do i rest a uniden ubc9xlt to have numbers
A full RESET or CLEAR function is not a feature on the BC92XLT, but you don't need it. To reprogram a channel just enter the new frequency (with decimal point) and press the E (Enter) key. In case you need it, here's a link to the owners manual for your scanner:
http://uniden.com/pdf/BC92XLTom.pdf
Bill B.
Top Radio Shack Radio Communications Experts
John
John
xxxxxx xxx
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
