Water remaining in washer after cycle has completed. It appears as if the drain/spin cycle didn't kick in?
Any error codes maybe f21,take the bottom panel off, you'll see the pump on the right hand side,use a pair of plyers to unscrew the middle part of pump,if you have a shop vac turn the middle part counter clock wise slowly when water starts coming out vac it up,also put a towel under the pump to catch water,when it's drained unscrew the middle part all the way and take it out and clean out the pump,feel around inside to make sure nothing is stuck in the impeller of the pump, try blowing through the other end of drain line to see if there is a block in it,put it back together and run it,put it on spin drain and make sure water is pumping out the drain line,if not the pump could of been damaged and you need to replace it
