Question about HP Photosmart 850 Digital Camera
HP850 Camera repair / replace with another HP850
I have an HP 850 camera which has the corner broken by the battery compartment - may require replacement body, front half.
Can this stil be done, good secon hand body or camera would be fine?
SOURCE:
CompuGuy44
  • 432 Answers
SOURCE: Broken LCD screen
I did some checking around for your camera. http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?rule=28832&lc=en&cc=us&dlc=en&product=445611&lang=en You can check this website also. http://search.ebay.com/HP-Photosmart-M415-Digital-Camera_W0QQ_trksidZm37QQfromZR40 I would buy a new camera. It would cost more to get the camera fixed than what it's worth.
Posted on Jul 01, 2007
SOURCE: HP R927 Camera
I had this problem with my camera after a year. Scratching the battery contact terminal inside the camera fixed it.
Posted on Nov 11, 2007
jigsawbill
  • 398 Answers
SOURCE: hp r507 digital camera 1.5 lcd display cracked need replacement
I have been searching for nearly six months for replacement parts for several point and shoot digital cameras with no luck at all. I think the factory updates them so often it is not cost effective to maintain parts for them.
Posted on Aug 02, 2008
ginko
  • 19396 Answers
SOURCE: HP Photosmart R717 camera has broken screen
Call the contact at website below to get parts or a quote on repair:
Advance Camera
Posted on Apr 27, 2009
BillB-SA
  • 2761 Answers
SOURCE: hp photosmart R927. No power, no operation, no LCD, battery good.
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
If this response helps, please take a moment to post a rating for me. "Very Helpful" would be appreciated.
Posted on Nov 28, 2009
Can battery compartment be repaired when tabs are broken off which hold lid down?
possibly...if it is the body where the tabs are broken off the manufacturer (Olympus) might be able to replace the body shell. I'd check with them.
Aug 16, 2014 | Olympus SP-600UZ 12MP 15x OPT Zoom Digital...
My camera won't turn on and the lens won't open and the little light in the corner (below the zoom button) will turn on but then beep and go off.
If the camera has recently been dropped you may have lens damage that is preventing it from powering up. If it hasn't been dropped your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then clean both ends of the batteries, place them back in the camera and give them a full charge (assuming that you are using rechargeable batteries). This cleaning clears the problem about 90% of the time. If it doesn't work for you, it may be time to replace the batteries, or the camera may have a problem that requires professional repair.
Jan 01, 2010 | Olympus FE-46 Digital Camera
Camera won't turn on.
Your problem is likely due to worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera and give them a full charge . This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced or the camera may have a problem that requires professional repair.
Dec 16, 2009 | Canon PowerShot SD800 IS / IXUS 850 IS...
Hp photosmart R927. No power, no operation, no LCD, battery good.
Nov 28, 2009 | HP Photosmart R927 Digital Camera
Camera will not come on lens still extended
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
If this response helped, please take a moment to post a rating for me. "Very Helpful" would be appreciated.
Nov 25, 2009 | HP Photosmart 945 Digital Camera
Camera lens stuck and wont go back in
If you've recently dropped the camera you've likely damaged the lens tube (housing) or jarred the zoom mechanism off of its track. Either condition will require professional repair. If the camera has not been dropped, your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
Nov 15, 2009 | HP Cameras
My digital camara no longer wants to work. The
The lens may have malfunctioned. It could be jammed, one of the plastic moving parts is broken, or the motor has malfunctioned.
You can try to open the r742 camera and swap out the lens with working set from another non-functioning r742 camera.
Oct 19, 2009 | HP Photosmart R742 7.0 Megapixel Digital...
Cannot download images from camera to PC
pull the card and use a card reader to download the pic's.
Card reader is about $22
Nov 18, 2008 | HP Photosmart 850 Digital Camera
Broken Battery Door
I have the same hp 850, No way to fix it, So to hold the Battery Door Down, I Drill'ed a small hole through the top. & through the case
where, the camera latch Broke, & do it Real Slow..... Put a Sheetmetal Screw in the hole i drilled & it Work's Find. Just do it SLOW<<<<<<<< Good Luck & it's up to You What size to use
So Think it Over before you Try it....Slow slow slow, & the right size Drillbit,screw, & turn it in Slow.. P.S. It was do that! or $500
Down the Drain, Good Luck, The Wizard
Dec 15, 2007 | HP Photosmart 850 Digital Camera
Can i use a power cord and not use batteries?
The camera will work with the charger cord plugged in, but you are limited to taking photos only near a power source. I have the same issue; broken battery door...Still looking for another hard broke 850 to take parts off of.
Sep 29, 2007 | HP Photosmart 850 Digital Camera
HP Photosmart 850 Digital Camera Logo
77 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Marvin
Marvin
Are you a HP Camera Expert? Answer questions, earn points and help others
