Inserting value by clicking a RadioButton
Hi there
am having problem , putting a value into a database by selecting a radio button , am doing an assignment on online test. if any help is there plz reply me.
my E-mail add. xingvoo@hotmail.com
Please let me know in which language your are want to use radio button to put your datas into database & please mention the database you are using, like access, sql etc
Posted on Feb 14, 2008
Private sub cmdEdit_click ( ) what is the right code to work the edit buton
You will probably want to be able to update some value of some field when doing database programming. This is done with Edit and Update. We will try to change the value of the "Phone" field by editing the text in the text box and clicking a button.
Put a command button on the form and name it "cmdUpdate". Then copy the following code to the project.
Private Sub cmdUpdate_Click()
rsMyRS.Edit
rsMyRS!Phone = txtPhone.Text
rsMyRS.Update
End Sub
Could it be that simple? Yes. This changes the phone number of our selected person. Or to put it technically: This changes the value of the "Phone" field of our current record. Imagine the current record being a set of boxes, with a field in each box. T he Edit method takes the lid off all of the boxes and Update puts them back on. When we write rsMyRS!Phone = txtPhone.Text we replace the content of the "Phone" box with the content in the text box.
Dec 16, 2010 | Microsoft Visual Basic 6.0 for PC
I have inserted a new column in my project, and I want to make my own formula for the values in that column... How can I do that??
In the field type the variable name you want a value assigned to, then a colon, then type an equals, and the equation. If you use other values from the database, enclose them in braces. If you use formulas, preceede the commands with @. If you do not want the value assigned, I think you can just write the equal sign. Be sure to check the radio button for "Formula"
It would look something like this.
PName: = @If(@Trim(@ProjectName) = [DatabaseName])
Mar 03, 2010 | Primavera SureTrak Project Manager 3.0 for...
My phone is deleting my text messsages and my calls I have made. When I go to check if my message sent, it says there is nothing in my inbox or outbox. How does my phone delete my stuff without me doing...
Cause 1 A number of large applications are installed on the BlackBerry smartphone. Resolution To resolve this issue, complete the following steps: Make sure that the BlackBerry® Device Software is installed on the computer to display the correct total application space. Determine the application space that is available on the BlackBerry smartphone by completing the following steps: Connect the BlackBerry smartphone to the computer. Open the BlackBerry® Desktop Manager. Double-click Application Loader. At the Device Application Selection screen, under the application selection window, note the total application space. Note: Select the List additional applications that are installed on the connected device check box to include the applications that are installed outside of the BlackBerry Device Software applications and the file sizes. Remove applications that are not required. For example, remove additional language packs and themes. Cause 2 A large amount of BlackBerry smartphone user data is present on the BlackBerry smartphone that cannot be removed by the Low Memory Manager. Resolution To resolve this issue, complete the following steps: On the BlackBerry smartphone, click Options > Status. Display the menu, and select Database Sizes. Reduce the number of items that are increasing the size of the database. For example, if the Address Book database is large, remove out-of-date contacts. If the Content Store database is large, move media files from the BlackBerry smartphone memory to a media card. Cause 3 Media settings may contribute to low memory capacity. Resolution Modify the Device Memory Limit settings by completing the following steps: On the BlackBerry smartphone, click Media. Select a media application. Display the menu, and click Options. Set the Device Memory Limit to the lowest setting field. Display the menu, and click Save. Note: Some BlackBerry smartphones have integrated cameras without a media card. As a result, some features have been added to handle picture storage on the BlackBerry smartphone, including the following: · Reserved Pictures Memory: In BlackBerry Device Software 4.2.0, the default value setting is 10 MB. In BlackBerry Device Software 4.2.1 - 4.7, the default value setting has been reduced to 2 MB. This setting reserves memory for pictures that the BlackBerry smartphone might take, and reduce the File Free amount that is displayed in the BlackBerry smartphone. This makes sure that the BlackBerry smartphone has memory available for pictures that are taken when a media card is not inserted in the BlackBerry smartphone. · Device Memory Limit: The default value setting is 20 MB. This prevents the BlackBerry smartphone from storing more than the specified amount of memory use. Cause 4 An application has expanded beyond intended memory boundaries. Resolution Note: In the Java® operating environment, applications increase and reduce memory usage when the applications launch, run required processes, and close processes. An application may use more memory than it is intended to use. Please make note of the values outlined in the following steps: On the Home screen of the BlackBerry smartphone, click Options. Click Status and note the values listed for File Free and File Total. Divide each of these two values by 1024, so that they are measured in kilobytes (KB). Record the new values, and name them as Displayed File Free and Displayed File Total. Display the menu, and click Database Sizes. Record the value shown in the Total Size field at the top of the screen. Open BlackBerry Desktop Manager, then open the application loader tool. Click Next on the Welcome screen. Connect the BlackBerry smartphone to the computer and allow the application loader tool to detect it. You might be prompted to type a password. Click Next on the Device Application Selection screen. Verify that the List additional applications that are installed on the connected device check box is selected. Record the value for the Total application space, located at the bottom of the window. Calculate the Reserved Pictures Memory for BlackBerry smartphones that have integrated cameras. If a camera is not integrated, proceed to step 12. On the BlackBerry smartphone, open the Media application. Display the menu, and click Options. Note the Reserved Pictures Memory value and multiply that value by 1024. Record the value. For example, 2 MB * 1024 = 2048. To calculate the Total Amount of Memory In Usage, add the values for Total Application Space, Total Size, and Reserved Pictures Memory (if applicable). To get the Calculated File Free value, subtract the value for Total Amount of Memory In Usage from the Total Flash Memory supported by the BlackBerry smartphone.
Oct 29, 2009 | AT&T Blackberry Curve 8300 Smartphone
How i can add a name and number in to existing contact list?
Nice try! Find an upper-class student to give you one-on-one tutoring with your homework.
Apr 08, 2009 | Google Android
Php counter
You might want to note that this is not the most effective manner of creating a counter in PHP. On a few of my websites, I find it is much more effective to simply create a text file, eg. counter.txt and have PHP read that every time the page is loaded, instead of running a MySQL query. Then, have PHP also update the counter.txt file by adding 1 to the number already listed in the file and read to the user.
Mar 19, 2009 | The PHP Group PHP
I can't add data in the database using vb
The database can be any like oracle.
Two type of connection u can make.
One of such connection is ADODB
The code is like
Dim ors As ADODB.Recordset
Dim oconn As Connection
Dim Qry as String
dim Qry1 as string
Set ors = New ADODB.Recordset
Set oconn = New ADODB.Connection
Chk_selectall.Visible = False
oconn.Open "Provider=MSDAORA.1;" & "user id = " & Username & _
";password = " & Password & ";data source = " & Conn_string _
& ";Persist Security Info=True"
Qry = "insert into table1 values (100,'we')"
oconn.execute "Qry"
If u select any data then u ve to use
Qry1 = "select * from table1"
ors.open "Qry1",oconn
do until ors.EOF
msgbox ors(0) & "," & ors(1)
ors.movenext;
loop
Mar 17, 2009 | Microsoft Visual Basic 6.0 for PC
Database talks to code but code won't talk to database
Make sure you are connecting to the database,then just before you call your sql to insert use an echo statement to display the sql and check it for syntax:-
$sql = 'insert into table1 values('.$no.','.$no.',"block","'.$value3.'", "'.$value4.'")';
echo "SQL ==>" STARTOFSQL<br>".$sql." ENDOFSQL<br>";
Jan 18, 2009 | The PHP Group PHP
Steps in saving file in excel to database
severals solution :
- save file as text separated by comma and use sqloader from oracle
- use function in excel to concatenate insert order : "insert into TABLE_NAME (field1,...,fieldn) values (A1,B1,...,??n);". Save file as text with sql extension. Connect against roacle db and execute file previously saved.
- use ODBC from MicroSoft
Dec 11, 2008 | Microsoft Computers & Internet
MS Access and ASP.net application
You probably need to be inserting the value of a text object (ie, a String) , not the object itself. In VB.NET, a String object is an actual, not unlike a Java String object. In "classic" VB, a String object isn't really handled by the interpreter as an object in the C# / Java sense, so it can be referred to directly without resolving the value via a method call. So attempting to insert an object reference into a database field from C# code will probably not work unless the database knows to call toSting() on the object, which I am 99.99999% sure it cannot (depends on the database-- in this case Access, and more particularly, what version you are using, and if there is any .NET framework interoperability).
Calling myString.toString() though returns a String object in C#, so using that is likely not going to work. What you may need to do is return a character array using the 'chars' and 'length' properties of the C# String object.
Finally, after all this, your problem could be a lot simpler: the value(s) you are trying to insert may not be right for the field-- check the length of the values being inserted, etc. Use .trim() to eliminate leading and trailing whitespace, for example. If you post your INSERT statement and an example of the data you are using, I may be able to tell you more. Also, you are in ASP.NET and data transfer from web containers to Access databases is notoriously bedeviled work.
Mar 07, 2008 | Computers & Internet
Hyperlink function in ms access
To Create a Hyperlink Field:
Display the table in Design view, create a new field to store the hyperlinks, click the new hyperlink field's Data Type box, click the list arrow, select Hyperlink, and save the table.
To Insert a Hyperlink:
Select the hyperlink field and then click the Insert Hyperlink button on the toolbar or select Insert , Hyperlink from the menu. Either select a file you want (use the Browse button to help you locate the file) or type a Web address for the hyperlink's destination and click OK.
To edit a Hyperlink: Right-click the hyperlink and select Hyperlink , Edit Hyperlink from the shortcut menu.
Is this enough?
Dec 21, 2007 | Microsoft Office Access 2003 (077-02871)...
Computers & Internet Logo
74 people viewed this question
Alun Cox
David Payne
David Payne
