Question about Sony Grand WEGA KDF-55WF655 36" Rear Projection HDTV
Sony 55" rear projection tv
I have a Sony KDF 55WF655 rear projection tv and it turns off for a few seconds, the green light blinks and then it turns back on and it just keeps doing it over and over.
  • 2 more comments
  • elvisluvr Feb 15, 2008
    Sony Grand WEGA Big Screen I bought this brand new 3 years ago and have one problem other than the current one where it turns on but says "no signal to be found" and starts blinking green stand by light and then the picture and sound will come on and off intermitently as well and it continues to do this. The cable guy came out today and changed out the cable box but it still does this. Is it the light bulb inside the casing or what? I don't think it's still under warranty.
  • DFox Feb 26, 2008
    We have the same television with EXACTLY the same problem. It started this morning. Have you found a soultion???
    This Sony has been a nightmare. We had it one year and had to replace the lamp. One month ago we got the blue dots and blue haze at the bottom of the screen. And now this!
  • JimNC Mar 12, 2008
    I have the exact same problem. Mine is a Sony 55in HDTV SXRD LCD projected TV. The Lamp will go off and then come back in a cyclical timeframe. However, after I leave it on for days, it eventually will stay on. So I simply haven't turned it off, except put it on a non-video input. I have reviewed the manual and troubleshooting manual which I purchased off the internet. I have not pulled the back off to take readings as the optical block has a 24 month warranty and it might possibly be that. But I would like to know if someone else got theirs fixed, what they had to do to it.
  • mahana1012 Mar 20, 2008
    We have the same problem however is is intermitent. The TV will work for hours or a full day. The next day it will start going off and on as soon as it is turned on. If it was a temperature problem I would think that it would have to be on for a while. The green power light blinks the entire time the sound and picture are off. It goes to steady green when working properly. I have service coming in tomorrow however I am willing to bet it works fine when they are here and they do not fix the problem.
TIGHTEN THE BULB --AFTER YOY CLEAN THE DUST OFF THE BULB VENTS ON THE BULB ITSELF. PROBLEM SOLVED. EASY--CHEAP. Hey it worked for me. My picture was turning off blinking 29 times for picture 37 times for audio. This was the first issue with my KDF-55WF655 since I unwrapped it almost 5 years ago......... ITS STILL ON!!! I hope this helps someone.
Posted on Sep 12, 2009
My Sony also flashed the green light and intermittently went out. The bulb was loose. Once I tightened it in with the allen wrench, it worked properly
Posted on Aug 15, 2008
Help I have the same problem
Posted on Aug 13, 2008
That is totally the bulb, There was a recall on that model number and I called Sony about it. They scheduled a technician who replaced the bulb and did some software upgrade. My TV works perfectly!
Posted on Apr 24, 2008
My TV Sony 55" rear projection does the same thing. Someone on line told me theirs did the same thing and they had to replace the bulb.
Posted on Apr 06, 2008
  • Sony Master
  • 8,617 Answers
Try cleaning the air filter sounds like a thermal problem often cleaning the filter takes care of it.
Posted on Feb 14, 2008
2 Suggested Answers
  • 86 Answers
SOURCE: Sony KDF 55WF655 rear Project tv Power/standby light flashing
This would be an error code indicating a problem.  You didn't mention if anything else was going on with the TV as in no picture, or no sound.  If the TV is operating just fine, there could be a bug in the software causing this.  If there is a problem, the best thing would be to contact Sony and relay that error message and go from there.
Posted on Mar 26, 2009
TV repeatedly goes into standby mode and then comes back on
Resolder Horizontal section & SMPS Power Supply with Soldering Iron
Jan 02, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
Problem for Sony Grand WEGA KDF-55WF655. Hello,
5 times Red LED blinks means Lamp Driver Error. (KDF-55WF655)
2 possible reasons, either Lamp is gone or Ballast Supply got bad.
Replace lamp first, in most cases it solved the problem.
How old is this TV and did you replaced lamp recently?
Thanks.
Oct 21, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Picture and sound shut off, blinking green standby
MY SONY PROJECTION TV WENT BLANK WITH NO SOUND GREEN LIGHT WAS ON WHATS WRONG
Oct 14, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony KDF-55WF655 'rebooting'?
Replace the lamp . p/n XL-2200
Oct 05, 2009 | Sony KDS55A2000 55" HDTV
Tv shuts off and green light blinks 5 times and repeats 5 blinks.
Please buy new Lamp for KDF-55WF655 from Sony Accessories Store with following part number..
" A1085447A " LAMP BLOCK ASSY XL-2200U
(type model number in search box and click)
Always buy Sony original lamp for safety of your TV.
Feb 06, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony KDF-55WF655 Won't Pwr up
There's a fan in the optical block (light engine) You may also have either an intermittent fan or a bad connection from the fan(s)
michtech
Jan 28, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Standby light blinks for 6 times
Did you get this solved yet? Six blinks usuall meand thermal fuse. I can look it up if you still need help.
Apr 08, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony Grand WEGA KDF-55WF655 36" Rear Projection HDTV Logo
878 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
