Question about Samsung RS2556 Side by Side Refrigerator
Water freezing up in holding tank
We are having a problem with the water freezing up in the holding tank in the refrigerators side.Is there a way to stop this from happening again?? We have thawed it out several times and don't know what else to do.
Might need to replace tank heater located behind the evaporator assembly panel
Posted on Mar 25, 2008
Get some foam hollowed tubeing for insullateing plubing and cut a slit down it and shorten it to the tubes leading away from the tank rap it around the plastice tubes so air isn't directly on it. This some times does the trick really well. If from there it keeps on you may be a temp. control problem that is freezing it up. Also tank temps. Most Samsung fridges should be 37degrees in the fridge section and 0degrees in freezer section. Hit me up if you have any other ploblems.
Posted on Feb 14, 2008
I have a ge cafe with the water dispenser inside and the water is freezing in the tube
Check to see if the "water tank" is freezing in the lower back of the refrigerator.
Nov 24, 2012 | General Electric Cafe CSS25USWSS Side by...
Water line is freezing up in refrigerator thermo set at 42
Yep, This sounds like a freezing problem, there is a water tank heater and a water line heater in the system, The tank heater is located behind the panel that the tank is mounted to. there is also a heater fuse in the circuit behind the panel. you will need to us a heat gun or blow dryer to defrost and check somethings back there. I saw someone selling a repair service manual on the online auction place E b a y that may help you further troubleshoot the problem.
Nov 24, 2010 | Samsung RS2534 Side by Side Refrigerator
My refrigerator water dispenser stopped suddenly yesterday. Water connection is good, filter is 3 months old, switch clicks on main panel. Have held switch down for a while. ???? Help please
Is the ice still dispensing? If you still are able to dispense ice then its possible that the water storage tank is frozen. The water tank is located in the back of the refrigerator section behind the crispers so they can sometimes freeze. You can try turning up the refrigerator section 1 setting warmer. If that doesn't fix it it's possible the solenoid for the water side on your inlet valve is bad.
Oct 07, 2010 | GE GSS22JER Side by Side Refrigerator
My Aman side by side quit dispensing water. It
Does your fridge have a small tank inside the food compartment? If so, the water may have frozen in the tank and the problem can be solved if you take a blow dryer and warm the tank. That's what happened to mine and with a temp adjustment to keep the food compartment a bit warmer, the water doesn't freeze.
May 30, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Ice and water not working, then freezing in refrigerator, leaking
If the water tank in the fresh food section is leaking then you will need to replace it. the freezing in the fresh food section is due to the damper door not closing when it should. at the top left of the fresh food side there is a door that controls how much cold air it gets from the Freezer side. This door on your GE is controled by a motorized door witch is controled by a controlboard witch is reading sensors in your freezer and freshfood section for tempretures.
In short your freezing problem could be any of these:
temp sensor, Motorized damper door or control board. I would check the Motorized damper door first.
Jan 07, 2010 | GE Adora DSS25KSTSS Stainless Steel Side...
I have a GE side by side refrigerator that in the past has had issues with the water tank freezing up. Everytime this has happened I have removed the bins and used a hairdryer to dethaw the tank. The water...
I believe you are having a combination of problems. Your air damper with fan is malfunctioning and causing freezing inside your fresh food section. The part number is WR49X10091 and there is a better replacement for that now.Refrigerator air inlet cover/damper kit with fan motor. Damper and fan assembly has been updated to prevent freezing in the refrigerator. As for the water tank epoxy does not work well with plastic so I would replace the tank to prevent having to go back later and do it again. I will assist you through this if you like, Thanks, Sea Breeze
Dec 28, 2009 | GE GSS25KGSBB 36" 25.4 Cu. Ft....
Kenmore Side By Side- Water Dispensed from door not cold
That is not a complete model# so it is hard to know exactly what you have but the old fridges (kenmore and others) had a pretty straight shot from the water holding tank to the tube that shot water in your glass so it was typically colder.
The newer ones have extra plumbing for filters along with tiny holding tanks. Most manufactures have gone out of their way to make the tanks not freeze but in doing so have made the water more "cool" instead of "cold".
It is not in the way you set it but more of the way things have become. Please give a complete model# (from inside the unit on the sticker and not off the owners manual) if you need more assistance.
Feb 18, 2018 | Whirlpool ED2FHSS Side by Side...
No water at freezer door
your freezer may be set to low causing the water tank to freeze. i would raise the temp a bit to thaw out the tank.
Feb 14, 2009 | GE GSL25JFPBS Side by Side Refrigerator
No water from dispenser
remove the crispers, youl find a water tank. chances are its frozen, somtimes thers a fitting right there to disconnect and try. IF not, it discharges from the left side of tank.Hold a hair dryer on that goose neck top portion of tank for a few minutes. water shloud start flowin now. if thats the case:::::
Order and install Water Reservoir Anti-Freeze Kit PN W10177505. Follow the instructions supplied with the kit.
Mar 14, 2008 | KitchenAid KBFA20ER Bottom Freezer French...
Water freezing at bottom of refrigerator/Temperature not right
thats a water tank holding water dfor the dispensor, if everything in refrig is freezing quite possible that the water in tank froze as well, which would explain no water,
Feb 24, 2008 | GE PSS26NSWSS Profile 25.5 Cu. Ft....
Samsung RS2556 Side by Side Refrigerator Logo
168 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
