Question about Dell Dimension 4600 PC Desktop
Tear in lcd flat panel
Dell 19" flat panel moniter
  • Marieshari Feb 14, 2008
    Hi! Thank you for responding - I have a chance to buy
    a 19" flat panel at a really good price, but they say there
    is a 1/2" long 'scratch' that is approx the depth of a needle.
    I didn't ask them how it happened. I can though, if it's important.
    I'm going to go look at it today. They say it's in the right
    lower corner. I'm concerned about:
    1.) leakage of any extra emf's? Anything that could be harmful?
    2.) could this damage progress on it's own to affect quality of the picture?
    3.) How is this usually repaired?
    Thank you so much for your time
    Marieshari
  • Griffin Kaves
    Griffin Kaves May 11, 2010
    Hi marie
    can you tell more in detail
    Problem Solver:
  • 12 Answers
If the scratch is in the frame surrounding the viewing area and the monitor still works, I wouldn't worry about it. However, if the scratch was caused by a drop, it is possible that an intermittent connection will eventually develop and make the monitor non-functional. See if you can get the seller to guarantee against it being "dead on installation".
To address your specific questions:
(1) No need to worry about electromagnetic leakage--LCD monitors don't work the same as CRTs (and even if they did, the scratch would have to be on the inner surface of the screen to allow for even the most minor chance of any radiation).
(2) If the scratch is all the way through the glass, the damage will likely get worse. If it's just a surface scratch, the risk to the picture is from any other damage that may have occurred internally along with the scratch (see the first paragraph, above).
(3) If the scratch is in the display area, make sure it doesn't significantly impair your viewing experience. It's not worth the time or money it would take to repair the cosmetic damage, so if you can't live with its continued presence, I'd pass on this offer.
In summary, if the display looks and works good and is a fabulous deal, then it's probably worth a shot. However, if the scratch is distracting or there are ANY picture quality problems that seem to be related (dead or stuck pixels, flickering, etc.) I'd approach it with extreme caution.
Posted on Feb 14, 2008
Is the Hannspree XM M19W1 a HD moniter
This is the specs of this monitor.
HANNspree XM Boston M19W1 19"
1440 x 900, 700:1, 5 ms, VGA, DVI, Audio
Apr 16, 2013 | Hannspree 19" Widescreen LCD Flat Panel...
My Dell moniter is a 19 inch monitor (Model No: E193FPc) and it's been working fine for 5 years. Now when I plug in the power, the power button goes green, but the monitor shuts off instantly. This...
your LCD monitor has a defective cathode driver inside, it will shut down your monitor when it has short circuit or has defective cathode bulb. you have to open your LCD case to see the circuit .you need screw driver set plus and negative to open the case. if your have knowledge in troubleshooting you can check the circuit if it has a short or defective part at the cathode driver, it has two small transformer that supplying the 2 or 4cathode tube in upper and lower screen of lcd
Aug 18, 2011 | Dell E193FPC 19" TFT LCD Flat Panel...
Moniter will not stay bright
can be due to damage in LCD panel or due to low voltage
Apr 03, 2011 | Envision 19" Widescreen Flat Panel LCD...
Dell moniter, brightness adjustment keeps coming on
The up/down button on your flat panel is stuck. Please contact Dell Technical Support to have the monitor replaced if its still within warranty.
Jun 06, 2009 | Dell UltraSharp 2407WFP 24" LCD Monitor
ISH819 LCD MONITER WITH TFT?
This link, is to the User Manual for the Envision H 819 TFT LCD monitor,
http://www.technostation.com/user-guide-owners-manual/Envision/Envision++H819+LCD+Monitor
Under the User Manual heading, you will see ->
2009-04-08 12:20:36
To the right of that is -> cache <- in blue. Click on -> cache
The Envision user manual, plainly states that the Envision H 819 monitor, is a TFT monitor.
[18.5" (47.0cm) TFT Color LCD Monitor]
May 17, 2009 | Envision 19" Widescreen Flat Panel TFT LCD...
19 inch Dell Moniter Screen turns blank
i think may be its monitor problem or may be the wire problem that are attached with ur CPU...... change it and then see its again wrking??????
Mar 23, 2009 | Hitachi CM721F 19 in.CRT Conventional...
Moniter clicking
check capacitors inside for damage is found replace them
Feb 13, 2009 | Proview PL913S 19" Flat Panel LCD Monitor
Got a dell computer wont pick up westinghouse moniter
Use a different monitor to test and set up the PC, try lowering down resolution settings, and test also the video cable.
Try also changing the monitor input channel, just in case this is set on a different connection input.
Dec 25, 2008 | Westinghouse 19" Widescreen Flat Panel LCD...
Hi My name is denise, I have the invision 22" Moniter can you tell me are there build in speakers on the moniter.
http://www.testfreaks.com/blog/review/22-envision-g22lwk-dvi-widescreen-lcd-monitor-wspeakers-black/
Here is a review of the monitor, it says it does have speakers, but not very good review, but most if not all speakers that are built in are not great. I hope this helped, Gym
Dec 21, 2008 | Envision 19" Widescreen Flat Panel TFT LCD...
Dell 1900fp 19" moniter Ultrasharp
Button on the bottom back base raises and lowers, if not low enough then you can remove the base. removal button is back and center of monitor.
of course you will have to deal with a way to mount it then.
Dec 12, 2007 | Dell UltraSharp 1900FP 19" Flat Panel LCD...
Dell Dimension 4600 PC Desktop Logo
66 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
