Question about Acer Aspire 3690-2196 Notebook
Screen freezes Dear experts, Every time I boot my cpu, everything looks normal until after the Windows XP loading screen. As soon as it's done loading, it presents the Aspire (light blue, designed screen) and never does anything after. It stays on that screen basically forever. I am able to move the mouse, adjust screen contrast/brightness, enable standby mode....but nothing else. What can I do?? Thanks!
    Novelist:
  • 103 Answers
If you can manage to access the safe mode troubleshooting please do it. By pressing F8 afre the POST and before windows loads. Select Safe mode and let 'em continue load the safe mode desktop. However if the safe mode won't work. You need to reinstall the system. You can use your compliment Recovery CD in doing so. Hope this will give you hints.
Best regards,
Rosener Guyano
Posted on Feb 14, 2008
My windows loading takes so much time
Slow Windows Machine! Sounds like not enough resources such as RAM and CPU. Check Performance in Task-Manager (CTRL-ALT-DELETE). High CPU levels causes hang ups like freezing. Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. In Startup tab, uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when only you initiate. Consider increasing RAM. Uninstall any extras like those pushy toolbars, and add-ons.
Nov 23, 2012 | Computers & Internet
My Computer will turn on and go to the windows XP loading screen with the blue bars and will won't load up, it rarely does but when it gets to the log on user screen it freezes
Right after your POST screen goes off,before you get to Windows starting,try pushing the F8 key several times until you get the Windows boot options.Then try 'last known good configuration".
If that doesn't work,you can boot from the Windows installation disk and try to repair your Windows installation.Let me know what happens.
And good or bad, please rate my post?
Bob
Aug 11, 2010 | Dell Microsoft Windows XP Home Edition
Windows xp home will freeze on the compaq logo when hd 640gb
leave the drive disconnected until you have booted up.
You could change the BIOS to tell it not to look for external boot devices to overcome this also.
All it is, is that the computer can see files on the drive that it thinks may be an operating system and it is trying to boot from that drive until it fails and then loads windows normally.
Sep 07, 2009 | Western Digital My Book Essential Edition...
Screen fades to white, everything freezes, then returns to normal
My first thought is a video inverter.
Install an external monitor and see if the problem persists.
If it doesn't then it is the LCD on the laptop.
Good luck
God Bless
-Carlos:
Jun 19, 2009 | Compaq Computers & Internet
Windows freezes when shutting down
If you can download the lastest bios for that PC from the internet that should fix your problem if that does fix issue reinstalling windows or does Xp restore from cds will
Mar 18, 2009 | Asrock K7S41GX Motherboard
I just installed xp pro and it keeps freezing
To get into the Windows 2000 / XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
I would suggest that you run only one stick of Ram at a time to determine if they are the problem.. Also these CPU's had heat problems that damaged the cpu. This also causes freezing. I would consider resetting the CPU and the heat sink, and case fans are clean and working.
Dec 10, 2008 | Computers & Internet
CPU upgrade problem
Hi there
what are your pc specs , like ram ect. So we can find out what is wrong. please check your cpu settings and reset the pc bios to see if that hasnt solved the problem
thanks
roger
Nov 12, 2008 | AOpen AK77-8XN Motherboard
Emachines 2792
pull the power plug as soon as the emacines logo comes on
and if that doesn't work pull out the power as soon as the first windows logo screen comes on. it should then come on and give you the option to start in safe mode or regular mode, choose safe mode then after it comes on in safe mode restart the cpu
then it should come on in regular mode i don't know why it works for my emachines cpu but it does . i'm looking at downloading a error fixing program because i'm doing this almost when ever i turn off my cpu hope this helps if not reformat your hard drive andput windows on again it worked last time i had this problem.
Apr 29, 2008 | E-Machines T2792 PC Desktop
Acer Aspire 3690-2196 Notebook Logo
77 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
