Whirlpool Motor/Isolation Coupling Failure Repair
I have a Whirlpool automatic washer model# LST7233DQ1.
I found the motor/isolation coupling shredded on the floor today. I am wondering if I need to purchase any other part to go along with this failed part? Sears replacement part #285753A . I want to minimize the mean time between repair for my wife and get all parts needed up front.
Thanks in advance
  • 51 Answers
You should do fine with this part. While it is apart look for any leaks and make sure that the hoses are all connected before you reassemble the machine.
Posted on Feb 14, 2008
My Bosch dishwasher SHX 46a 05uc will not pump the water out when done with the wash cycle or rinse cycle
1 Remove the pump and drive motor. You willfind two plastic and one rubber motor couplings. One is located on the drivemotor and the other is on the gear case with the rubber coupling between them.
2 Pry or break the old couplings off with your screwdriver. Replace with newcouplings. Simply push one onto the shaft of the gear case and press the secondone onto the shaft of the drive motor.
3 Line up the holes of the rubber isolation coupling with the studs in thecoupling. Push the rubber isolation coupling in place.
4 Push the isolation and coupling on the drive motor making sure that theholes line up with the studs on the other coupling on the gear case. · 5 Reinstall the drive motor and then snap the pump in place with the retainersto hold it in place. Reconnect the hoses with the clamps and snap the.Put thewasher back on and screw the back in place. Position the washer where you hadit before and plug the washer in.
Good luvk and thanks for using fixya.
Jul 27, 2011 | Bosch 24 in. SHX46A05UC Built-In...
Dryer will not ignite even after I replaced the igniter.
For dryer thatt will not ignite
If your dryer machine does not agitate, spin or drain, you have a problem that needs fixing. The average do-it-your self offer can do this job without hiring the professional technician. Each problem indicates a separate repair, but while you have the washer apart, it never hurts to check things while the back is off and the parts are off the washer. exercise caution and make sure that the washer is unplugged and the water is off before you begin.
  • Remove the pump and drive motor. You will find two plastic and one rubber motor couplings. One is located on the drive motor and the other is on the gear case with the rubber coupling between them.
  • Pry or break the old couplings off with your screwdriver. Replace with new couplings. Simply push one onto the shaft of the gear case and press the second one onto the shaft of the drive motor.
  • Line up the holes of the rubber isolation coupling with the studs in the coupling. Push the rubber isolation coupling in place.
  • Push the isolation and coupling on the drive motor making sure that the holes line up with the studs on the other coupling on the gear case.
  • Reinstall the drive motor and then snap the pump in place with the retainers to hold it in place. Reconnect the hoses with the clamps and snap the.Put the washer back on and screw the back in place. Position the washer where you had it before and plug the washer in
  • Hope this solution help?
    Thanks for using fixya.
    Nov 23, 2010 | Kenmore 75922 Gas Dryer
    Elba ew 6001 spin cycle no working
    If your Roper washing machine does not agitate, spin or drain, you have a problem that needs fixing. The average do-it-your self offer can do this job without hiring the professional technician. Each problem indicates a separate repair, but while you have the washer apart, it never hurts to check things while the back is off and the parts are off the washer. Exercise caution and make sure that the washer is unplugged and the water is off before you begin.
    Instructions
    And Things You'll Need As Step By Step Instruction.
    • Screwdriver,Needle-nosed pliers,Wire,Garden hose,Bucket.
      Washer Won't Drain
    1. Check the drain hose to see if anything is plugging it. Sometimes small pieces of material go out with the wash water and become lodged in the drain hose.
    2. Open the access panel in the back by removing the screws and taking off the back panel. Remove the drain hose. this is usually held on with a clamp, collar or clip.
    3. Use a pair of needle-nosed pliers to remove the obstruction. If the material is further into the hose, you can use a sturdy piece of wire with a small hook bent at the end. Stick this into the hose to try to pull the obstruction out. If you still can't reach the obstruction, disconnect the entire hose and force the obstruction out with a water hose using the jet spray.
    4. Washer Won't Spin
    5. Check the pump or pulley if your machine doesn't spin. Sometimes the pump may be frozen or stuck.
    6. Remove the screws from the back access panel of the washer and remove the back panel.
    7. Remove the pump from the washer by unsnapping the retainer from the pump using a screwdriver. Remove the hose clamps and disconnect the two hoses one at a time. Have a bucket handy, because the hoses may have water inside.
    8. Rotate the pulley by hand. If it does not move easily, then you will need to replace this because it is frozen or stiff. Also, check the belts to make sure they have no tears or damage. While the pump is off the machine, continue to the next step to check the motor couplings. When these become bad, the washing machine will not agitate.
    9. Machine Won't Agitate or Spin
    10. Remove the pump and drive motor. You will find two plastic and one rubber motor couplings. One is located on the drive motor and the other is on the gear case with the rubber coupling between them.
    11. Pry or break the old couplings off with your screwdriver. Replace with new couplings. Simply push one onto the shaft of the gear case and press the second one onto the shaft of the drive motor.
    12. Line up the holes of the rubber isolation coupling with the studs in the coupling. Push the rubber isolation coupling in place.
    13. Push the isolation and coupling on the drive motor making sure that the holes line up with the studs on the other coupling on the gear case.
    14. Reinstall the drive motor and then snap the pump in place with the retainers to hold it in place. Reconnect the hoses with the clamps and snap the.Put the washer back on and screw the back in place. Position the washer where you had it before and plug the washer in.
    Nov 19, 2010 | Washing Machines
    How do you remove the agitator on a wash machine?
    HELLO,
    HERE ARE SOME SOLUTION BELOW
  • 2 Pry or break the old couplings off with your screwdriver. Replace with new couplings. Simply push one onto the shaft of the gear case and press the second one onto the shaft of the drive motor.
  • 3 Line up the holes of the rubber isolation coupling with the studs in the coupling. Push the rubber isolation coupling in place.
  • 4 Push the isolation and coupling on the drive motor making sure that the holes line up with the studs on the other coupling on the gear case.
  • 5 Reinstall the drive motor and then snap the pump in place with the retainers to hold it in place. Reconnect the hoses with the clamps and snap the.Put the washer back on and screw the back in place. Position the washer where you had it before and plug the washer in
  • Washer Won't Drain If your Roper washing machine does not agitate, spin or drain, you have a problem that needs fixing. The average do-it-yourselfer can do this JOB without hiring the professional technician. Each problem indicates a separate repair, but while you have the washer apart, it never hurts to check things while the back is off and the parts are off the washer. EXERCISE caution and make sure that the washer is unplugged and the water is off before you begin.
  • Check the drain hose to see if anything is plugging it. Sometimes small pieces of material go out with the wash water and become lodged in the drain hose.
  • 2 Open the access panel in the back by removing the screws and taking off the back panel. Remove the drain hose. this is usually held on with a clamp, collar or clip.
  • 3 Use a pair of needle-nosed pliers to remove the obstruction. If the material is further into the hose, you can use a sturdy piece of wire with a small hook bent at the end. Stick this into the hose to try to pull the obstruction out. If you still can't reach the obstruction, disconnect the entire hose and force the obstruction out with a water hose using the jet spray.
  • Thanks.
    Oct 02, 2010 | Kenmore Washing Machines
    The drum is not spinning. I hear a noise like when you stick something in your bike spokes.
    Assuming that this is a Kenmore / Whirlpool top loader with a direct drive system, the first thing to check is the motor coupling.
    The transmission and motor have plastic parts that connect through a rubber coupling.
    pd_0026_110_285753a?$pddetailsth$ #13 on diagram Coupling, motor and isolation Number:661560Substitution:285753A $18.50 If the coupler rubber piece wears out, the pins on the motor and transmission sides will rub together making the sound.
    If the coupler looks good the problem is likely in the transmission.
    Sep 10, 2009 | Kenmore 22422 Top Load Washer
    I have an average top load washer that is 11 years old. The tall agitator in the middle isn't agitating. Thank you.
    Assuming that this is the basic Kenmore / Whirlpool top load, direct drive, neutral drain two piece agitator model.
    There is a Sears repair parts site:
    http://www.searspartsdirect.com/partsdirect/index.action
    Enter your model number and a list of major sub-components will come up.
    Since it isn't agitating (I assume not at all rather than just the top part of the agitator. If just the top part
    isn't turning then the easiest solution is replacing the 4 "agitator dogs" ) the solution points to a
    couple of places.
    1. The motor coupler
    #13 on diagram Coupling, motor and isolation Number:3364003Substitution:285753A $18.50 In stock
    may be broken. This piece is a fail safe between the motor and transmission. and basically transmits power to the transmission.
    If it spins and drains OK, and if you can hear the motor turning, the problem points to the transmission.
    Inside the transmission are a number of gears, springs, and plastic cams and levers. Over time one of
    them may have either broken or worn out.
    There is a Whirlpool site with a parts list for their "commercial washer" which is essentially the same as
    for your washer. On it is a list of all of the components and parts for the washer.
    By paging down to and following the diagram of the transmission you should be able to determine
    which actual part is broken.
    http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
    When our washer (12 years old) wouldn't spin, rather than spending $170 for a new transmission, we
    installed a repair kit into the old one ($15) and the problem was solved.
    Sep 07, 2009 | Kenmore Washing Machines
    The revolver in the middle isn't spinning.
    I assume that the machine is a Kenmore / Whirlpool direct drive, top load with neutral drain and that the "revolver" is actually the agitator.
    Since it isn't agitating (I assume not at all rather than just the top part of the agitator. If just the top part isn't turning then the easiest solution is replacing the 4 "agitator dogs" ) the solution points to a couple of places.
    In stock may be broken. This piece is a fail safe between the motor and transmission. and basically transmits power to the transmission.
    Inside the transmission are a number of gears, springs, and plastic cams and levers. Over time one of them may have either broken or worn out.
    There is a Whirlpool site with a parts list for their "commercial washer" which is essentially the same as for your washer. On it is a list of all of the components and parts for the washer.
    Sep 07, 2009 | Kenmore 22422 Top Load Washer
    Kenmore top load no spin -.coupling destroyed w/ isolation dsk?
    Hello I believe you have pinpointed the problem accurately yourself.
    1. It is an easy fix, if you said you got the top off then thats the hardest part. That will restore spin because it is the linkage between the motor and transmission which spins the inner tub.
    2. The causes of the coupler busting are just wear and tear. Happens all the time. Main reason for it busting is because its plastic.
    3. Thats probably all it is most of the time the transmission will just slip when it goes out and not lock up. Like I say this is common so it is not likely that it is anything other.
    To fix it just pull cabinet off. Pop the pump off, then the motor. Then you can access the coupling. When you buy the coupling it will come in 3 pieces. Two plastic coupling gears and the isolator. Now to put the coupling on the motor and transmission use something like a socket with a hammer to knock the coupling flush up onto the shafts of each. Put it all back together and you should be working again.. Hope this Helps
    Feb 15, 2009 | Kenmore 22422 Top Load Washer
    Washing Machines Logo
    383 people viewed this question
    Top Washing Machines Experts
    Marvin
    Marvin
