Question about Franklin Industries FR1700
I have the FR1700 franklin chef coffee maker
It will start to perk but then does nothing but steam.
I took out the water valve and it started to work.
Do you still have new valves for this machine?
3 Suggested Answers
carldc3
  • 82 Answers
SOURCE: where can I foind technical
what part are you wanting, water inlet is usually 3/8 npt, this unit can use 1/4 to 3/8 inch line
Posted on Jan 23, 2009
  • 3 Answers
SOURCE: My franklin chef FIM200 is
Try putting a compression coupling in eliminating the valve. Did that on my machine a few months back, have not had any more leaks. Just other issues with thick ice and won't harvest correctly. Any suggestions?
Posted on Feb 01, 2011
Coffee does not brew
If you are elictrically inclined you
could take it apart and jump
across the switch with a jumper
wire or whatever avaialable means
see if it works all the time
thereby proving the switch to
be defective
Dec 07, 2007 | Krups Aroma Control 229 Coffee Maker
I have an Ariete coffee machine the steamer takes along time to heat up not much steam coming out
if the steamer is not been in use for a ling time is possible tha the valve got stuck. You can try to open and close the steam handle repeating that very often while steam get out. if it does not work try to make a cicle of water mixed with salt, just start the coffe maker, warm up and start WITHOUT COFFEE, you repeat that several time to obtain clean water from the fiter, warm up for steam function and start to open-close the steam handle on the right of the coffee maker body. If that doese not helps you must change or repair the rubinet-valve of steamer, apply to assistence.
Sep 08, 2013 | Ariete Cafe Retro Espresso Machine
My franklin chef FIM200 is dripping water from the back, right side. The water fill valve was spraying out above the tray, we managed to get that under control, but, water is dripping right behind that...
Nov 24, 2010 | Franklin Industries Franklin Chef FIM200...
Gaggia Titanium bought new in Italy. tested it to make coffee ALL OK. tested to see if steam came out and it did. Took it on a plane with me plugged it in coffe good but steam does not come out for...
When you twist the steam knob all the way, it actuates an electrical switch. The first part of the turn just opens a mechanical valve to allow the steam or water to come out but doesn't turn on the heater nor does it start the pump. You need to turn it far enough to trip the electric switch that starts the heat and the pump.
If it still isn't working, then perhaps the switch was knocked loose when it was taken on the plane.
Oct 13, 2010 | Gaggia Titanium Espresso Machine
Gaggia Titanium. Fault suggests ventilation required. Followed manual instructions, nothing happens. Tried rinsing, nothing happens. Tried hot water nothing happens? Have taken out and cleaned all pbvious...
Do you hear the pump working but no water flows?
You should select hot water (the third button from the right) and the display should say "hot water" at the same time it is saying VENTILATE --- open the steam valve all the way and the pump should start and you should see water from the steam wand.
If you don't hear the pump at all, then that is a different problem.
If you do hear the pump but still don't get any water with the steam valve open, then you need to prime the pump by using a turkey baster or the accordian pump that came with the Titanium to pump water into the valve where water from the tank goes. Remove the tank and use the turkey baster to pump water into that valve while the pump is running and the steam valve is open all the way with HOT WATER selected. the second water starts to come out the steam valve you want to stop the pump (turn the power off or turn the steam knob shut) and put the water tank back on and make sure there is plenty of water in the tank - then start the pump again by opening the steam valve all the way and let it pump water out the steam wand for a few minutes.
Oct 05, 2010 | Gaggia Titanium Espresso Machine
Brand new Saeco Villa machine won't prime
Press hot water button then open valve, then push the valve knob in if that works take it back and tell them that the valve is damaged.
Aug 29, 2009 | Saeco Vienna SuperAutomatica Coffee...
I have Saeco Royal Coffee Bar. Hot water and
Hi
You may have a flow meter that is bad. If its white plastic check for corrosion at the wire terminals. If your have corrosion change the meter and you should be good to go.
Apr 10, 2009 | Saeco Royal Coffee Bar Coffee Maker,...
Ice machine not working Franklin FIM35
did you ever find a solution? mine does the same thing and drip tray is empty.
Feb 23, 2009 | Franklin Industries Franklin Chef Ice Cube...
Water not being forced through the cup
I've seen a few coffeemakers that have a gravity valve on the inlet side of the brew chamber. If this valve has become stuck open, then the hot water may be perking back into the reservoir instead of out to the coffee.
Feb 20, 2008 | Keurig B50 Coffee Maker
Coffee Makers & Espresso Machines Logo
81 people viewed this question
Top Franklin Industries Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Kolbrun...
Ross Keen
Are you a Franklin Industries Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
