Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Folder option i cant find folder optin in tool menu after removing the virus
    Problem Solver:
U will run Rav Vont software it will recover all thing which was removed due to virus.
Posted on Feb 14, 2008
When i put a usb in my computer it hides the folders and files. But when i look at the usb properties it has the memory of the hidden files. When i tried it in other computers it already has virus.
Could you please explain what you are trying to do?
Are you trying to reveal the hidden files on a USB device or are you trying to remove a virus?
-Revealing hidden files and folders-
1. Open the drive you are wanting to view the hidden files and folders in.
2. Click Tools on your menu bar and select "Folder Options" (If you cannot see your menu bar, you may need to press "alt" on your keyboard.
3. A box will popup, select the "View" tab on top and look down the list of tickboxes, you should come across one that says "Show hidden files and folders", select it. Click apply and ok.
(To view system hidden files and folders, untick the option: "Hide protected operating system files", it is not recommended to have this unticked.)
If it's a virus, I suggest you run a scan on a up to date Virus scanner, once threats have been removed. I would also recommend formatting the drive (once you have backed up any neccessary data).
~ David
Nov 04, 2010 | Office Equipment & Supplies
How to safely remove this new folder virus.
You can find the step by step explanation to delete newfolder.exe virus from your computer in the below website:
http://www.securitystronghold.com/solutions/Newfolder-ese-solve-new-folder-problem-now.html
Follow the steps, you can remove it easily.
Rate my solution
Regards
May 25, 2010 | Symantec Norton Antivirus 2009 1-User -...
Hello CyberGuru
its not from microsoft explorer, you have to be inside folder then hit tools and folder options and show or hide files.
Windows XP
To enable the viewing of Hidden files follow these steps:
Close all programs so that you are at your desktop.
Double-click on the My Computer icon.
Select the Tools menu and click Folder Options.
After the new window appears select the View tab.
Put a checkmark in the checkbox labeled Display the contents of system folders.
Under the Hidden files and folders section select the radio button labeled Show hidden files and folders.
Remove the checkmark from the checkbox labeled Hide file extensions for known file types.
Remove the checkmark from the checkbox labeled Hide protected operating system files.
Press the Apply button and then the OK button and shutdown My Computer.
Now your computer is configured to show all hidden files
if it doesnot work use spyware software to fix it.
Jul 08, 2009 | Acer Aspire One PC Notebook
I couldn't view the hidden files when i apply show hidden files in my folder options in tools menu in menu bar.
Folder Options is removed from Tools in Windows by a virus. The virus is called W32.Rontokbro@mm OR W32/Rontokbro.gen@MM
The removal of this virus is slightly difficult. Antivirus can't remove it automatically. However detailed procedure to remove it is available at
http://coolexp.blogspot.com/2008/01/fold...
About this Virus/Worm:
What it does is creating new files which looked like a folder but its actually a .exe file. Unless you’ve enabled the view extensions in the folder options or else you won’t see the .exe extension of the file. The file is approximately 43.7Kb and normally people will click to open it because it looked like a folder. So after you’ve open it, the virus will run each time during startup and keep on spreading and spreading… into the harddrives.
More troubles coming up. Normally when you click “Tools” in explorer, there’s a “folder options” underneath it. Once the pc is infected with the virus, the Folder Options will be missing, which disabled you to change the options to view the extension of the files. So when you see a new folder appeared from nowhere and you clicked to open it out of curiousity, the virus spread more again. Moreover, the virus disabled the registry edit where you will see this message “Registry edit is disabled by the administrator” everytime you try to edit the registry.
So how to clean the virus then? I found some solution from the following link and have successfully cleaned it from my system.
It will help you to get rid of this virus named W32.Rontokbro@mm aka brontok.a and to get back your hidden files. Source(s): http://coolexp.blogspot.com/2008/01/fold...
P.S.: If this information was helpful, please rate this solution.
Mar 14, 2009 | Microsoft Windows XP Professional
Windows folder cannot be hidden
Hi its a virus.
Heres the fix for it.
Go to registry editor by running regedit in the run box.
Go to this key:
HKEY_CURRENT_USER\Software\Microsoft\
Windows\CurrentVersion\Explorer\Advanced
In the right hand area, double click hidden and change the value to 1.
Now you’re all set to go. Check it in your tools menu if the changes have taken effect.
alternatively use this tool
Smart Virus Remover
Nov 04, 2008 | Microsoft Windows XP Home Edition
Hurri virus
Hey there
Once you are infected of viruses then you wont be able to remove them compltely by doing some utilities.
You need to install some good Antivirus Program.
First of all check for what kind of viruses are affecting ur system by:
Because your virus leads to your system very slow as well as restarts itself without awaring you. It is caused by Worm and Trojon viruses. For making sure that ur system is suffering from virus go to tools in menu bar and check for folder. if the folder option appears to you then it is okay. again try to go to Task manager by right clicking on the tasl bar. If the task manager is also showing then you are not affected of viruses.
Try out QuickHeal Antivirus by downloading it from the following link:
http://www.quickheal.com
Download its trial version and then get it updated by connecting ur pc to the internet.
This antivirus program can remove all the viruses that are currently present in ur system.
gimme your acknowlege by rating me
thanx
Romy
Jul 24, 2008 | Microsoft Windows 98 for PC
Hello, I am experienceing difficulties with my PC. I can't access to any folders and cant open the start menu.
You might have a Virus. In the case of a Virus infection I would most likely disconnect the Hard drive from the machine, scan it on another machine ( using AVG7 + AVGAS = AVG Antivirus and AVG Anti Spyware Scan) remembering to turn off system restore while scanning on the drive.
If you have successfully found and removed the virus infection, remember to delete your system volume information and recycler folder on the drive. virus files tend to infect these folders.
When you plug in your HDD into your machine again, you might want to do a Windows repair; to fix the issues that the virus has caused OR use a registry repair tool to repair registry items. Another option would be to create a new user name. The settings in that new accound should be working fine and you should be able to access the start menu and your folders again.
Apr 17, 2008 | Computers & Internet
Folder options in my control panel and in tools menu
hi friend
ur pc has been infated by viros taht y the folder option remove so u have to do this dwonlaod the latest updated antiviors form the intenet downlod it install ur pc scan form it see the link for more info
http://maintainyourpc.blogspot.com/2008/02/registry-editor-disabled-by.html
http://maintainyourpc.blogspot.com/2008/02/task-manager-has-been-disabled-by-your.html
after removing viorus here is link for ur restor ur folder optin link downlod soft & install it
http://www.raymond.cc/blog/archives/2007/06/28/restore-task-manager-regedit-and-folder-options-disabled-by-virus/
Mar 28, 2008 | Microsoft Office Professional 2007 Full...
Folder option
seems that you can have a virus in your machine. after this
The goto Start --> Run --> and type gpedit.msc Then navigate to User Configurations --> Windows Components --> Windows Explorer. On the right hand side you will get a lot of options. Double click on " Removes the Folders options menu from the Tools menu " item (which the third option from the top). In the next screen click on "Enabled" and click on Apply (don't click on Ok). Again in the same screen click on "Disabled" and click on Apply and Ok. There you go you get back the Folder Options under the Tools menu.
Feb 28, 2008 | Microsoft Office Professional 2007 Full...
Folder option
may be you are only using the USER account so folder options are not available... there are full administrative right to use folder option so have a check with this...
in case you are administrator then also it s not available means this may be due to virus attack some system files have became unstable .... so try reinstalling operating system ...
and in further dont forget to use updated antivirus......
Feb 09, 2008 | Microsoft Windows Server Standard 2003 for...
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
23 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
