SOURCE: do they make adapters so the cd changer will fit
CD changers can be made to run on adapters.There are adapters availible that switch into the cigarette lighter socket with ratings of 50w,100w.Or else if its for a small cd changer, check current rating of the cd changer.ideally the voltager rating would be 12v.Then purchase an adapter with the given specific current and voltage rating.And use it with ur cd changer.
SOURCE: Cd changer will not work
I had the same problem with my 2002 307SW.
I read on another forum to switch ignition off, remove CD changer from dash and disconnect. It then told me to remove the lid from the case unscrewing the screws marke 1 to 5 then remove the Cd's. The only problem with this is you need a special size 'star' driver bit which i did not have at home and could not unscrew them. What i did was to use a terminal screwdriver in the 2 larger screws that fasten the front plastic cover on the unit. Once I had done that I could remove the CD's.
I then connected the changer back up and inserted it back into the dash. I then powered the radio back up anf loaded a CD and the problem had gone away so I loaded the 5 CD slots and everything works fine now.
SOURCE: 1998 - 2002 Honda Cassette 6 disk CD changer Radio
the cd changer is malfunctioning, the factory cd changers usually don't last that long because of the heavy use and many mechanical puts
SOURCE: 6-Disc CD Changer is not working
Unfortunately most times with these 6-disc systems once it quits working it is usually time for a new unit. The manufacturers all reccomend reprogramming the radio, but this rarely does anything other than waste your time and money. Go for the new radio.
