Question about Dell UltraSharp 1702FP 17" Flat Panel LCD Monitor
Flashing LED's My Dell 1702FP has flashing led's and will not power up. Is this a problem I can solve myself. I am not very electronically inclined.
  • Anonymous Mar 26, 2008
    I also have the flashing lights and can solder, is there a certain piece or part I need to replace or what kind of simple tester could I use to find out which needs work or replaced? My email is firewalker3@netzero.net I would appreciate any help you can supply me with. Thank you very much for your assistance
  • Anonymous Oct 05, 2008
    Same problem to my Dell 1702FP...has someone found a solution or what does it cost to repair? Thanks
Replace two 10uf capacitors on control board C604 and C507.
Posted on Jun 20, 2008
  • 286 Answers
If you can't solder you will likely have to take it to a service center. Ours would repair it for about $60 + parts. You should be able to get simular price in your area.
Posted on Feb 14, 2008
Monitor model 1702FP wont start. lights keep cycling
The flashing power and signal lights are caused by 4 bad capacitors on the main driver board. Here is a link to information showing where they are and how to replace them.
http://www.instructables.com/id/FREE-17%22-LCD-Monitor---How-to-do-it%3F/
Sep 23, 2012 | Dell 1702FP 17" 1280x1024 .264mm Midnight...
I have a broken Dell Precision 470 Workstation. The symptoms are as follows: Won't power up; Flashing yellow power LED on front panel; Blank STR_LED on motherboard; Yellow AUX_PWR LED on motherboa
Flashing front powerlight is often a result of a faulty powersupply, try another powersully on the pc and see if the problem gets solved. I've seen a few of these cases personally.
Jul 01, 2012 | Dell Precision Workstation 470 (204816690)...
Dell Dimension 4400 - Power light glows amber when attempting to power up. I'm thinking it's the power supply. Is this something I can fixeplace myself?
Flashing Amber power LED indicates a bad power supply.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817822008&cm_re=atx_power_supply-_-17-822-008-_-Product
A solid power LED is either a bad component connected to the motherboard or a bad motherboard
May 13, 2010 | Dell Dimension 4400 PC Desktop
I have a flat screen monitor. when i power up the screen the yellow light flash with two others lights. also i hear a click like the screen trying to power on. the model number for this product is 1702fp
This model has a know problem with parts called capacitors shorting out and causing the flashing that you have. If you can solder then you should be able to do the repair yourself. If you go to our web site at:
www.ccl-la.com and click on the monitor repair section I will post a step by step guide to the repair for you. You will need to replace 2 capacitors and yo should be back running again. Check after 12/09/09 at 2:00pm and the guide should be posted.
I hope this helps, f so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Dec 09, 2009 | Dell 1702FP UltraSharp 17" TFT LCD...
Dell 1702FP 17" Blank Screen Problem
Try it on another computer, if it works the video card moght be dead.
Jul 11, 2009 | Dell UltraSharp 1702FP 17" Flat Panel LCD...
Dell 1702FP gets off automatically or lose power by itself!
i think the power cord to your monitor is not fixed tightly. check the connections. or else the power On / Off button could have got damaged. replace it with the new one. if still the problem exists, servicing of the monitor will be the solution to it.
please rate my solution.
have a nice day.
Jul 05, 2009 | Dell UltraSharp 1702FP 17" Flat Panel LCD...
Dell 1702FP 17" shows nothing after Radeon HD 2600 put in.
Is the card plugged into the (PCI/AGP) slot correctly? Did you disable the onboard video in the bios? Also be sure to check in windows device manager and check for the graphics card to appear there.
Dec 24, 2008 | Dell UltraSharp 1702FP 17" Flat Panel LCD...
Dell 1702FP 'tearing' after warmup
It might be a failing electrlytic or a heat-related issue with a transistor in the power supply, or it may be a problem in the video board. Sounds like will need good old-fashioned component-level troubleshooting.
Jan 02, 2007 | Dell UltraSharp 1702FP 17" Flat Panel LCD...
Dell 1702FP Blank Screen problem
Hi there, I had the same problem on two Dell 1702FP monitors and I solved them, now I am using one as an LCD TV and it's been working great since then. Solution: replace surface mount capacitors, 10uF 16V value, C604 and C507... I created an instructables web page for it, so please follow the link below: http://www.instructables.com/id/ELWXF03NV6EQZJIZM2/ Enjoy it! Koray.
Feb 18, 2006 | Dell UltraSharp 1702FP 17" Flat Panel LCD...
Dell UltraSharp 1702FP 17" Flat Panel LCD Monitor Logo
174 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
