Question about GE VG4267 VHS VCR
Eject motor ... I don't know
What it looks like. I turned the big gear with the tracks and released the pins/rollers that slide back and forth but then I don't know what to release the tape with.
  • 2,130 Answers
The eject motor will be a shiny metallic cylinder around 3/4" in diameter and around 2" long. It will have a white plastic pully with a black rubber belt around the pulley. Try rotating the pulley and belt to manually move the eject mechanism.
- Jim
Posted on Feb 14, 2008
Slideout in 2005 adirondack coachman travel trailer not working right. The slide out jumps up and down and back and forth when you push the switch to make it go in or out .
if gears on side its a schwintek probably ruined gears need new gears both sides and possible motors see if you have insurance costly repair
Jun 01, 2017 | RVs
Front drivers seat will not slide back and forth.
No, check for a blockage in the seat track. You have one power source for all seat functions. If it works one way but not the others it is either a bad switch, or bad motor, or a blockage.
Sep 02, 2014 | 2000 Nissan Maxima
Can't raise outboard motor up so I can trailer it
Disconnect Battery! Just For Safety.Try Turning Prop And Engage Forward Gear, Once In Gear Try Lifting Motor!!
Mar 09, 2013 | Boating
My window i thought came off track however when i got my panel off a little white piece was broken and my window wont stay up
That white peice could have possibly been on of the rollers from the regulator or a guide.
Sometimes you can purchse a new roller and it will need some pressure to snap it onto the pin. Or you can purchase a repair part that is the roller already on a pin and the old pin needs to be ground off from the back side (its like a rivet smashed onto the regulator or guide).
Then that white piece could have came from something else. Don't really know unless you look.
Aug 30, 2011 | 2000 Pontiac Grand Am GT
My old mercedes w115 220 d (1974) manual sunroof is not closing. I don't know if there is any part of the sunroof missing beacuse the car was on a major reability program and I forget the pieces of the...
There's not a heck of a lot to the manual sunroof. I suspect some sort of debris in the track.
First off to remove a sunroof you open it all the way, looking down from on top of the car you will see the two chrome tracks on either side. They are healed on by two screws (there is a third adjustment screw on each side - it is obviously different and not holding the track down - don't mess with it -- or perhaps this is your problem...)
Remove the screws and the top to the tracks (they will lift right off) then slide the sunroof mostly closed and lift it out.
Now look into the tracks - back into the roof. Is there anything there that ought to not be there? Remove it - this can be challenging since it's narrow - a shot van and the biggest pice of tubing that will fit in there might do it for you.
Lube up the track with silicone lube (oil or grease will stick to dirt) clean the 4 feet of the sun roof. Notice the two rollers at the back these love the sunroof in place within it's open and push the back up when closed. With the roof out check that they move easily when you turn the handle.
Now back to the car - notice the two adjustment screws, they lift or lower the back of the track - perhaps you turned them when you were removing it the first time. In any event if they are up too high the roof won't fit (the wheels pushing out will try to push the sunroof door out of the car) You can see the small wedge next to the track - the wheels will roll up this wedge to close the back of the roof - and it needs to be in a reasonable position.
Don't force it you risk breaking the handle, the connecting mechanism or those wheels and where are you going to get a new one?
So now you can put the sunroof door back into place. Slide it back and forth - it should move easily. Now try to close it. It should close easily if not try adjusting the wedges down (this adjustment should not have changed but I am assuming you inadvertently changed these while trying to remove the sunroof door - it you're certain that you did not do that then it's something else).
Good Luck,
Frank
Aug 03, 2011 | Mercedes-Benz 190-Class Cars & Trucks
How do you replace he belt on a 7447 Sander
To change belt:
1) Put front roller on floor and push down until roller locks back.
2) Put on new sand paper.
3) Loosen tracking screw until front roller is released.
4) With sander running, use tracking screw to center belt.
Oct 10, 2010 | Black & Decker BR300 3''x18'' Belt Sander
Does not want to open door - shows "Blocked on the display. And Remote control does not communicate to DVD Recorder - new batteries fitted.
This will happen if you close the tray by pushing instead of using the insert/eject button. the BLOCKED error means the the rack and pinion can't be moved by the motor which takes too much current and stalls hence the error
The guide pin can jump is dogleg and cause the tray to bow slightly this can also cause UNKNOWN DISC as the head tries to read the DVD at an angle.
The best option is to free the tray UNPLUG and remove the cover the you will have to remove the inner cover on the top of the DVD mechanism you maybe able to see the tray bowed look underneath you should see the dogleg guide and the pin should be inside this track yours might be outside, try to re-seat don't force it or pull the tray out you may not get it back inside the unit.
With the cover back on test the eject if this still wont work there is a manual release on the underside of the unit which is clearly visible place a screwdriver into the hole and slide across to release the DVD
Nov 29, 2009 | Philips DVDR3380/05 DVD Recorder
In Philips DVDR3380/7 I need open for put DVD it say "blocked" permanently, which is the solution?
With the cover back on test the eject if this still wont work there is a manual release on the underside of the unit which is clearly visible place a screwdriver into the hole and slide across to release the DVD. This model has not release hole at the front as kladdaugh suggested this paperclips type of release is normally put onto ATAPI DVD-ROMs on your PC
Oct 22, 2009 | Philips DVDR3380/05 DVD Recorder
Samsung clp-500 paper feed roller replacement - how to...
You're on the right track! If you remove the paper tray and put the printer in a position so the front of it is facing up, you can then access the roller shaft with ease. If you now look on the right hand side of the roller shaft you will see a white plastic end which is secured onto the shaft with a little clip, lift this up and slide the plastic part inwards. This should now make the shaft easy to turn so you can release the two white clips on the roller and remove the rubber band (which there is only one of, but looks like two on a first glance). Once removed, I just turned it inside out so you can get another few months or more out of it before you have to buy a brand new one for a couple of ££. Replacement is just the reverse of removal. Hope this help!
Jan 28, 2009 | Samsung CLP 300 Laser Printer
Glass on sliding door
this is the link to the information http://www.swisco.com/Screen/how-to-repl...
Opening your patio sliding glass door should be an easy task. If your sliding door is giving you a work out every time you open it, most likely it is your rollers that are causing the problem. The rollers are located on the bottom of the sliding door and give the door the ability to slide. Often times they get dirty and wear out, making it difficult to open the door. If you have an older sliding glass door your rollers may have become rusty because sliding door units did not always use stainless steel rollers.
Hiring a professional to replace your rollers could cost you around $100 not including the cost of the replacement parts. Below are detailed steps containing all the information you will need to know to replace your patio sliding glass door rollers yourself.
* Before you start, understand that you need to take the sliding glass door out of its frame to work on the rollers. The sliding glass door is heavy. You may need the assistance of another to help you remove the door.
1) Your patio glass door will have two separate glass units. One unit is the door that you slide and the other unit is stationary. First, stand outside your house and look at your sliding glass door. If the stationary unit is between you and the sliding unit you will most likely have to remove the stationary unit so that you can get to the glass sliding unit.
Before you go through the trouble of removing the stationary unit, first try to go inside your house and see if you can remove the sliding unit. Usually you cannot because there is a lip along the bottom of the patio glass door frame (it keeps moisture out of the house) that prevents the sliding glass door from being removed from the inside.
If the rollers on the bottom of the door are difficult to get over the lip, you can adjust them to help you create more room (go down to step 2). If it is not the rollers but the sliding unit�s frame preventing you from pulling the sliding unit out of the door frame, you are going to need to remove the stationary unit first before you can remove the sliding unit.
To remove the stationary unit, you first need to take out your screen door (if you have one). Lift one end of the screen door frame and use a screwdriver to lift the roller on the bottom of the screen door frame off of the track. Do this to both ends of the screen door and your screen door will pull out of the door frame.
The stationary unit is held in place by a metal piece that runs along the bottom of the track from the corner of the stationary unit to the bottom of the side jamb (there is a chance this piece is missing but if you do have one remove it from the track). After you have removed the metal piece, look for screws holding the stationary unit frame in place. After removing all of the screws try pulling the stationary unit out of the door frame. If you are having trouble pulling out the stationary unit, try placing a screwdriver between the stationary unit�s bottom frame and the track it is resting on. Lift up on the screwdriver while you have a helper pull out the stationary unit from the door frame. Be careful not to use too much force with the screwdriver so that you do not damage the door track.
2) You may need to create more room when you attempt to remove the sliding unit from the door frame. To create more room you can adjust the rollers on the bottom of the sliding unit. By turning the adjusting screws on the rollers clockwise the wheels move up into the sliding unit�s frame giving you more room. The adjusting screws are located either at the bottom of the sliding unit�s frame or in the sides of the frame. There is a chance that there are plugs covering the screws.
After you adjust both rollers (one on each side of the sliding units frame) try to remove the sliding unit from the door frame. If the unit is still getting stuck you may need to get someone to help you. Have your helper lift one side of the unit and pull outwards while you try to pry the other side of the unit over the track.
3) To remove the rollers from most sliding units you need to remove the bottom of the sliding units frame. Most likely the screw that holds the roller in place is the same screw that holds the frame together. Remove the screw from both sides of the unit. Then try to remove the bottom piece of the frame off of the sliding unit; you may need to use a rubber mallet or a piece of wood and tap on the bottom of the frame until it comes off of the sliding unit.
Now that you have removed the bottom of the frame you can take a close look at your patio glass door rollers. Remove one of the rollers and match it up with one of the rollers on this page http://www.swisco.com/page/SI/CTGY/patio...
It is a good idea to replace both sliding door rollers at the same time to prevent extra wear-and-tear to one new roller, which will have to work twice as hard when paired with an older roller.
4) After your new rollers come in, replace your old rollers with the new ones. To make it easier to install the sliding unit back into the door frame, adjust the rollers to be all the way up into the frame. Once you have the sliding unit back in the door frame you can adjust the rollers for optimal performance. Keep adjusting the rollers until the door is sliding back and forth easily
Jun 22, 2008 | 1996 Ford Windstar
Televison & Video Logo
71 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
