WESTINGHOUSE SK32H240S 32"" HDTV- How do I change the setting for 480i to 720p
    Problem Solver:
  • 18 Answers
It should be automatic on factory defaults
Posted on Feb 14, 2008
How do I change the settings on my Westinghouse 50" TV from 720p to 1080p?
Most HDTVs these days do not have settings for resolution. They auto-adjust their resolution (within their specifications) to the signal being received. So, if you are receiving an over the air/cable television signal (most are 720p), you cannot force it to go to 1080p as it will not synchronize. You CAN adjust the aspect ratio on many models in the event that there is picture distortion due to screen size.
A few sets may have progressive scan technology as do some VCRs/DVD players. These sets create extra scan lines on 480i images and upscale them to 720i. This would be a menu setting if available and would only work in the conditions specified by the manufacturer.
Nov 02, 2015 | Westinghouse Televison & Video
Rca How To Set my RCA LED32B30RQ - 32"from 480i to 720p
Refer its user manual. It must have details, if there is a facility to change the resolution.
May 01, 2013 | Televison & Video
My TV is only 480i. When my receiver reboots, I cannot see the settings menu to configure the receiver to output to 480i. I need to know the remote keystrokes to press to configure the receiver for...
You did not give your model number of receiver. Some of the ones from 2007 or so have a switch on the back for video resolution, 480i, 480p 720p 1080i so set this switch to 480i.
Mar 08, 2011 | Samsung HDTV Digital Terrestrial Receiver
I have a wd-52525 mitsubishi and it is supossed to be 720p but when I turn it on it says its 480i. What part of the tv makes it 720p or 1080p? Please help.......Thanks Paul
You will have to use component inputs for above 480i, and use the FORMAT key on your remote control unit (lower panel in center) to change to whatever you want for resolution. Be sure you have your signal input set to one of the Component inputs via Setup or Net Command (or use Devices on the remote)
Jul 19, 2009 | Mitsubishi WD-62525 62" Rear Projection...
I Have A Vizio 32LCD and my problem is i am trying to get the PS3 to play with the HDMI I have a HDMI cabel hooked up to the hdmi input on the back of the set and it is hooked up to to the HDMI input on...
Adjust the system's video output settings. Select the best output settings for the TV in use.
1. Check the resolution supported by your TV.
Resolution (video mode) varies depending on the TV type. For details, refer to the instructions supplied with the TV.
2. Select (Display Settings) under (Settings) in the home menu.
3. Select [Video Output Settings].
4. Select the connector type on your TV.
Resolution (video mode) varies depending on the type of connector used.
Input connector on the TV Supported video modes (NTSC region) *1 Supported video modes (PAL region) *1
HDMI 1080p / 1080i / 720p / 480p 1080p / 1080i / 720p / 576p
Component / D-Terminal *2 1080p / 1080i / 720p / 480p / 480i 1080p / 1080i / 720p / 576p / 576i
Composite / S Video *3 480i 576i
AV MULTI / SCART *4 480p / 480i 576p / 576i
*1 The video mode options vary depending on the region where the PS3™ system was purchased. In North America, Asia and other NTSC regions, 480i video mode is displayed as [Standard (NTSC)]. In Europe and other PAL regions, 576i video mode is displayed as [Standard (PAL)]. For details, refer to the instructions supplied with the product.
*2 D-terminal is a connector type used mainly in Japan. The resolutions supported by D1-D5 are as follows:
D5: 1080p / 720p / 1080i / 480p / 480i
D4: 1080i / 720p / 480p / 480i
D3: 1080i / 480p / 480i
D2: 480p / 480i
D1: 480i
*3 Composite is the connector used to connect the AV cable that is supplied with the PS3™ system. S VIDEO is a format mainly used in Japan.
*4 AV MULTI is a format mainly used in Japan. SCART is a format mainly used in Europe. If [AV MULTI / SCART] is selected, the screen allowing you to select the type of output signal will be displayed.
5. Change video output settings.
Change the resolution for the video output. Depending on the connector type selected in step 4, this screen may not be displayed.
6. Set the resolution.
Select all resolutions supported by the TV in use. Video will automatically be output at the highest resolution possible for the content you are playing from among the selected resolutions.*
* The video resolution is selected in order of priority as follows: 1080p > 1080i > 720p > 480p/576p > Standard (NTSC:480i/PAL:576i).
If [Composite / S Video] is selected in step 4, the screen for selecting resolutions will not be displayed.
If [HDMI] is selected, you can also select to automatically adjust the resolution (the HDMI device must be turned on). In this case, the screen for selecting resolutions will not be displayed.
7. Set the TV type.
Select the type of TV in use. Set when only SD resolution (NTSC:480p / 480i, PAL: 576p / 576i) is to be output such as when [Composite / S Video] or [AV MULTI / SCART] is selected in step 4.
8. Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the button.
9. Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see (Settings) > (Sound Settings) > [Audio Output Settings] in this guide.
Apr 06, 2009 | Vizio L32 32 in. LCD HDTV
Westinghouse SK32H240S 32'' LCDHDTV Picture appears and Disappears
This problem is caused from a problem with the main board. The main board will need to be replaced. It runs from $100.00 to $150.00.
Mar 28, 2009 | Westinghouse SK-32H240S Television
Convert 480i to 720p
Turn off cable box.
Turn on TV.
Hold down media and guide for a few seconds.
On TV pick the resolution you want. Your choices are 480i, 480p, 720p, some wide screen resolutions and 1080i.
Save the results.
You should be good to go.
Jan 25, 2009 | Philips Magnavox Learning Universal Remote
Hdtv?
is not a hdtv , and its 4x3 aspect ratio
Oct 23, 2007 | RCA 32V420T 32" TV
Westinghouse 32 in LCD TV
I have had this problem now for about six months with my Niko OPT-3211W. After replacing the Inverter card, VIT70002.00 as suggested nothing changed. I then read that it may be a couple of capacitors in the power supply, but I do not have the skills needed to replace them, nor do I want to pay to fix it. The solution is simple... turn on the TV and wait two to five minutes, then turn off the main power. I suggest using a power strip. Then turn the power back on in two to five seconds. The TV will come back on and it works great from then on. I thought that it was a freak thing, but it keeps working.
Jun 10, 2007 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
