Question about Car Audio & Video
MY CAR AUDIO WONT PLAY CD
CD WONT PLAY
  • 1 more comment
  • quickvick Feb 14, 2008
    pioneer in dash cd receiver wont play cd
    I CANT PUT CD INTO MY CD PLAYER
  • john clarke May 22, 2008
    how do i open my monitor to insert the cd?? pressin the eject button wont open it
    Brigadier General:
  • 6,966 Answers
Most CD players that would not play a disc even with a known good disc inside signifies that the laser eye/lens is not reading the disc. This could probably be attributed to:
1. dirty, damaged, inverted, blank, un-finalized burned CDs
2. defective, weak, dirty/dusty burned-out laser eye/lens;
3. dirty, dried up lubrication of the slider shafting (where the laser eye's carriage moves) or some other components; and/or
4. dirty, dried up lubrication, defective spindle motor.
A few things you can try:
1. Use a CD cleaner (readily available from most computer shops);
2. use a can of compressed air and blow through the inside of the loaded disc area;
3. gently tap on the top cover where you estimate the reading/laser eye/lens would be;
4. gently press on the tray door (if it's got one) once the disc is loaded;
5. relube, clean as necessary but that would require pulling the unit out of the dash.
Should this not be corrective, perhaps your best bet would be to seek the services of a qualified professional such as those in a Service Center. Alternately, your friendly neighborhood electronic shop should do just fine.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kindest regards.
Thank you for using Fixya.
Posted on Feb 14, 2008
  • Louie  Role
    Louie Role Feb 14, 2008
    Your last post "I CANT PUT CD INTO MY CD PLAYER"
    can mean:
    1.there is already a disc inside but is stuck;
    2. the loading tray mechanism, motor, belt requires repair or replacement;
    3. the electronics controlling the tray in/out requires repair.
Car CD player wont play CD-RW MP3
Some players won't play these, I stick to the CD-R's and have no problem.
Jan 27, 2014 | Panasonic CQ-C800U Car CD/ MP3 Player
Wont play
you may have an older cd player they have trouble playing burnt cds try regular cds
Jul 16, 2013 | JVC KD-S730 CD Player
Cd player doesn't play mp3 files recorded on cd
Possible that the format you have recorded is not accepted by the player's specification. I would recommend that you re-reccord the files with MP3 compression that is accepted. Use another software - nero- should be fine. If this wont work but your audio files play Ok then it could be a fault within the audio processing section. Hope your get this right. Good day
Jul 06, 2010 | Blaupunkt Brisbane SD48 Car CD/ MP3 Player
The screen wont light up. we got it to play a cd
you probably have a bad flexible cable. (goes from the face to the main motherboard).
Jun 27, 2010 | Kenwood KDC-715S
I put in the cd and it reads then it says play and it wont play
THATS NORMAL......SO DOES IT PLAY? IF NOT U HAVE A DEFECTIVE UNIT...TRY A DIFFERENT CD OR CD CLEANER DISC
Aug 29, 2009 | JVC AM FM CD DET FACE CAR STEREO
Rover 25 CD player wont play MP3 format discs
It sounds like your Rover dosn't have MP3 capabilities. You will have to use standard audio CD format (not data/MP3 format). You will only be able to burn about 15-20 songs but they will play in any cd player.
Aug 07, 2009 | Car Audio & Video
CD's play in Media Player but not Home/Car CD player ?
If you are using windows Media Player to burn the cd you have to burn to an audio cd. You can only burn to mp3 cd if your car or home system canread them. Wma audio cannot normally be read by car or home audio. The file format is called WAV
May 14, 2009 | Dell Dimension 3100 PC Desktop
Cd loads wont play then ejects
HI, this is the result of a failed optical assembly. you can confirm by inserting a cleaning disk. if this continues after the cleaning attempt, have the optics replaced.
May 07, 2009 | JVC KW-XC550 CD / Cassette Player
MP3 convertion
You have to convert mp3 to an audio file first then it will play. (using a computer an a burning program....ie mindows player,nero ect...
Oct 04, 2008 | 1996 Chevrolet S-10 Pickup
My cd player wont play my burned cds
this happens all the time, instead of getting CD-Rs, try getting the CD-R Music, they are specially made to be played on CD players, I buy these all the time and they work in every CD player.
Feb 09, 2008 | Jensen CD4610 CD Player
Car Audio & Video Logo
584 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
