Question about Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV
Yellow stripe down left side of picture
On HD channels (16:9) I have a yellowish, semi-transparent stripe going down the left side of the screen. I notice that is is the same size as the black-bars that are present when watching a 4:3 channel. Any solution (or link to a thread)?
    Champion:
  • 213 Answers
Some of this are still ud werrnty you need a dmd opictbock.
call sony and give them your mod# ane sel# to see if your block
is cover. i hope this help you iam a auther sony sevice man.
Posted on Apr 01, 2008
Yellow stripe screen
Bad Color Wheel or you unplugged it doing bulb replacement and did not get it plugged back in.
Feb 02, 2014 | Samsung HP-R5072 50 in. Plasma HDTV
Vertical line
what cables are uusing for tis 15pin vga in or hdmi ?
Feb 02, 2008 | NEC MultiSync MT1020 Multimedia Projector
Vertical blue transparent line plasma
Check for loose or dusty flexible connectors. (Please take care to switch off TV and remove plug from the power outlet and discharge high voltage capacitors before you do anything on the PCB) Apply cleaning oil in connectors wherever possible and remove and reconnect it a few times. If problem persists, it might need attention by a qualified service technician.
Jul 22, 2012 | Nakamichi VU50P 50 in. HD-Ready Plasma...
A yellow line going down the left side of the television
you likely have the "screen size" option set to allow the TV determine the best size (3:4 , 16:9, ...). Set it manually to 16:9 for HD channels or 3:4 for low-def channels.
The line should go away. This is a common problem on Samsung, Sony (Green line right side) and Phillips (yellow line left side).
May 05, 2011 | Philips 50PF7321D 50 in. Plasma HDTV
I can't get the full screen on some hd channels and during commercials. It goes from full screen viewing on some channels to the picture shrinking and having a border around it.
There are a few picture sizes out there 4:3, 16:9, as well as some for movie screens. New televisions are 16:9 and when you are watching a true HD program, it will fill the screen perfectly. However the program may be broadcast in one of the other formats. This results in the bars on top/ bottom or on the sides. This is true for commercials too. If the commercial is or isn't in HD will determine if there are bars or not. All this is normal operation.
Apr 20, 2011 | Televison & Video
Yellow Stripe Down Middle of Screen on Laptop
This system has a VGA port so you can plug in an external monitor. You can buy one for less than $130 based on the Sunday ads. Other than that, it is new laptop time.
Jul 31, 2010 | Acer Computers & Internet
Blue smears and dots on the screen and a orange yellow picture
Bad Light Engine/optical ASSY Encompass Parts Distribution 1-800-638-3328
Jun 01, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
I re-scanned my channels this weekend because I lost HD on 2 of my local channels. Now I have HD back, but I have 2 black lines on each side the picture on all of the HD channels. How do I get rid of the...
A broadcaster will transmit an HD channel in 1 format. This may be 720p or 1080i, both of which are HDTV formats. HDTV formats have an aspect ratio of 16:9. SDTV or standard definition broadcast have an aspect ratio of 4:3. Because not all content is record in an HD format (ex: Judy Judy), the broadcast is faced with 2 options. #1, stretch the 4:3 picture do that it fills the 16:9 canvas. #2, simple place black side bars on each side of the 4:3 image. What you are seeing is the latter of the 2 options. You will notice a change during the evening programming. The bars are only there when the content is not HD. You can use the WIDE feature of your TV to stretch the picture so that it fills the screen, just like broadcaster option #1 above.
Mar 15, 2010 | Vizio VW37L 37 in. LCD HDTV
Aspect ratio problems on Samsung LN-S2651D Flat Panel TV
The aspect ratio (zoom) button on the cable remote had been changed. On Brighthouse the # button toggles through the zoom settings. It's not a tv issue, it's a cable fix.
May 29, 2008 | Televison & Video
Picture shifts to left
I had the offset left issue for non-HD channels with my Panasonic 42" plasma, using Comcast HD cable box. Went into the configuration menu (to get there with the newer Comcast boxes, you have to turn the box off, then hit the menu button on the box immediately after). You will see on the menu a resolution (probably says 1080i), then below it a "4:3 override". Our said 480i. When I changed it to "none", so that it stayed 1080i, it worked! It also works by selecting 480p, but then the picture is stretched.
Mar 13, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV Logo
94 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
