Question about Cyberhome CH-DVD 300 DVD Player
Systems pal to change back to ntsb
I change my ch dvd300 to system to pal, but no way i could go back to system ntsb, since no display anymore on the screen. hoping if you could help me with this problem since i lost my manual
  • rhymus Feb 20, 2008
    thanks a lot for the help it works and fixed my player
You can reset it by opening and closing the tray without a disc inserted. Then, press "stop" button for 5 seconds. This is suposed to reset the player. If you change the region to "0"
you don't need to switch between pal/ntsc.
To change the region code:
Switch player on and make sure there is no disc in the tray.
CLose tray and press menu,1,9.
A menu should appear with the region option at about the third line from the bottom. Press enter and enter the region you want. Next press open/close. Put in your movie and enjoy.
Posted on Feb 19, 2008
How to Change NTSC/Pal ?
press the button again
or try taking out the
DVD
Jan 10, 2010 | Televison & Video
Cyberhome dvd ch dvd 300 changed ntsc to pal by accident
I have done it! All I did was take the yellow video cord and plug it in those progressive scan plug in until I could see a blurry screen enough to be able to see to do a reset, which is under system and did a factory reset. I DID IT AND DAMN PROUD OF IT SINCE THE EXPERTS DIDN'T EVEN KNOW IT!!!!@ Jennifer pc, fl
Jun 05, 2009 | Cyberhome CH-DVD 300 DVD Player
I bough the CH-DVD300 used. Supposedly all cords,
The yellow is usually the video connector the the other two connectors would be for the right and left channel sound hook-ups.Hope this helps you with you problem.
Apr 25, 2009 | Cyberhome CH-DVD 300 DVD Player
Black and White Image
Yes there is video format for our TV and dvd players. NTSC & PAL...
NTSC SYSTEM SELECTED IN TV & DVD PLAYER PLAY PERFECT NTSC CDS & DVDS, BUT IF PAL CD OR DVD IS INSERTED SUCH PROBLEM COMES.
EVEN IF, THE DVD PLAYER SETTING IS KEPT AS PAL, AND WE INSERTING THE CORRECT CD OR DVD AND ALSO IT SHOW BLACK & WHITE PICTURE, ETC.... so please check your video system in TV, DVD PLAYER and check the CD or DVD you are inserting is of same video format you have set in DVD player.
Apr 23, 2009 | Cyberhome CH-DVD 300 DVD Player
I missplaced my remote for the Cyber Home CH-DVD300 model bought a year ago....please facilitate getting a new one to match. What do I have to do? Thanks! ETK Wisconsin
I have a remote for the CH-DVD 300. I'm about to toss the player because of a bad power supply board. I think I'll follow the advise of a previous post - buy American or at least Japanese!
Mar 25, 2009 | Cyberhome CH-DVD 300 DVD Player
Set up video output
Pal output will only work when it is plugged into a pal tv. The only way you can restore is to use the remote to put the settings back to ntsc without using the display. That should work. If you don't have a pal tv you should never change devices to run on it, because it can damage your tv set. The scanning lines are very different between the two systems.
Aug 14, 2008 | Cyberhome CH-DVD 300 DVD Player
No color picture on any DVD played
Make sure the scart lead in pushed in fully and none of the pins are bent!!
Mar 27, 2008 | Cyberhome CH-DVD 300 DVD Player
Cant play anything on it
I had the same problem, After googling for a few minutes I found the reset procedure for this player.
1. Turn it on.
2. Eject any disk you have in there and close the tray.
3. Hold down the "STOP" button on the player (not remote) until the green light flashes red and the system reboots.
4. Insert disk and enjoy.
This worked for me... mileage may vary.
Aug 29, 2007 | Cyberhome CH-DVD 300 DVD Player
No colour
Go to the setup menu. Change the output from NTSC to PAL. Should work.
Jan 22, 2007 | Cyberhome CH-DVD 300 DVD Player
Sony Mobile DVD MV-7101 Display is Black and White
Try pressing the arrow up on your monitor while it is on the PAL mode. This is what I just tried on my systema and it switched from PAL to NTSC.
Jan 07, 2007 | Sony MV-7101DS Car DVD Player
Cyberhome CH-DVD 300 DVD Player Logo
119 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
