Question about Nokia 6133 Cellular Phone
Nokia 6133 LCD Replacement Trouble
I recently got an LCD screen to replace a cracked one in my Nokia. I just pried the casing open, disconnected everything, switched out the LCD, connected everything back and everything seemed really easy. The problem is that the LCD will show a backlight on the internal and external displays, but no characters or colors will show. Just white screen. I have undone and redone everything about ten times. It's not the LCD because I switched the cracked one back in and still had the same problem. Thanks for your help.
  • Anonymous Jun 13, 2008
    hey my 6133 does that too... I have contacted numerous cell phone repair people and they seem to think that it is the LCD but I know that it has to do with the wiring... I just don't know how to go about fixing the wiring...
  • Anonymous May 23, 2009
    I have the same problem and it happened twice with two different phones of the same model.
You most likely need a new front board as well or the lcd they gave you was bad!!
Posted on May 05, 2008
  • 3 Answers
My guess is that you messed with something while you were prying it open.
I have the nokia 6126 (very similar) with a broken screen but i get it open, could you help me with that
Posted on Apr 06, 2008
I'm looking for some self repair info on how to change my screen on my 6133 nokia.
To repair the screen of your nokia 6133, you need to get the appropriate screwdriver and Plastic tool such as a credit card or guitar plectrum, and follow the steps below;
  1. Run your plastic tool all the way around the join of the cover on the front of the phone to release it.
  2. You should now have the cover removed. Next you need to disconnect two ribbon connectors. These attach like a plug and socket. Simply lift each connector up, away from the circuit board, to unplug it.
  3. Another ribbon connector needs to be disconnected. Again, this is a plug/socket type connection. The green circuit board will now be loose.
  4. Lever the LCD out at the four points,
  5. You should now have the LCD screen removed.
  6. You can now replace your screen and,
  7. Reverse the whole procedure for reassembly.
Take care
Jun 21, 2010 | Nokia 6133 Cellular Phone
Nokia 6133 screen just went blank for no reason
if the device is fully charged then the screen will need to be replaced this can be difficult to do at home but you can do it with tools made for cell phones and buying the lcd that is compatible for the device
Apr 01, 2010 | Nokia 6133 Cellular Phone
Cracked LCD on Canon PowerShot A510. A few weeks back, I noticed that my LCD view screen was cracked on my camera. The camera still functions since I use the other view finder anyway. However, I obviously...
Your best option is buy a junk one off ebay and replace LCD. LCD replacement is very straight forward, just remove the screws, pry the case apart and the rest will be easy. Use the one you buy off ebay and practice getting it apart.
May 07, 2009 | Canon PowerShot A510 Digital Camera
Nokia 6133 black screens
does it seem ur lcd been inverted? well heres how the prof tech. will do clean the terminals of the flex ..or check the lcd for replacement and or change the flex.....
Jul 29, 2008 | Cell Phones
LCD Screen
if ur screen remains white or gets white than it could be display connectivity cables fault or if it is broken than it is the displays fault and it can be repaired at Nokia Care
May 23, 2008 | Nokia 6133 Cellular Phone
Crack screen
HI fllow the step plz. open the uper body > open 4 screew > pick the protection plate > u see a jeck of display > plz open with carefully > place a new display > push the jeck tightly > place the protiton plate > put the screew > tight carefully > place the body. keep voteing THANKS.
Mar 22, 2008 | Nokia 5300 Grey Cellular Phone
STILL NO HELP
try to replace a new LCD...
Jan 22, 2008 | Nokia 6133 Cellular Phone
Lcd screen replacement
On the front side of the phone above the camera eye you can carefully (either with your fingernail or a small screwdriver) pry the plastic apart. Once you have the top apart a little bit work your way down each side, once the top and sides are loose you can slide the cover up and off. Once open ther will be a green board around and over the lcd, remove two small connectors on the top and one small one on the bottom underneath the board. When the green board is off look on the sides of the LCD and you will see four points securing it into the phone, carefully pry out on each of these and you can then remove the LCD. Replacement is reverse. Good luck.
Dec 07, 2007 | Nokia 6133 Cellular Phone
Nokia 6133 cracked screen
do one thing sir just open up the screws which is at the backside of the phone, and check out the connecter with the main chip of ur phone, if it is a lug out connecter than plug out the old one and plug the new one, with the screen as well there is are screws, which u can open up while changing the screen and than try, if u face any kind of problem while replacing it than consult with the NOKIA CARE.
Oct 18, 2007 | Nokia 6133 Cellular Phone
Nokia 6133 Cellular Phone Logo
433 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
