Question about Panasonic CT-36SL13 32" TV
TV does not power up
Panasonic TV CT-36SL13 does not power up. Tv is 3 years old.
  • 1 more comment
  • tresbarb Apr 18, 2008
    Same problem. TV will not power up, either from a remote or manually. Electrical outlet is active.
    Tres
  • Anonymous Jul 17, 2008
    tv does not power up when you turn it on, either by remote or hitting power button on tv. tv is plugged into a surge protector along with the cable box and dvd player. all other systems power up. plugged tv into a separate outlet by itself, tv will not power up. is it the fuse?
  • Anonymous Jan 30, 2009
    mine just had the same problem anyone know what needs to be done to fix this yet or repair costs?
    Genius:
  • 1,665 Answers
Check Power Cord is Plugged into Active Outlet
Adjust Brightness and Audio Controls Change Channel Check Cable Connections Program the Remote Control Again Check Second Video Source Operation As warranty has expired, check if fuse at power supply input is ok.
Consult online manual for troubleshooting.
http://www.fixya.com/support/p232673-panasonic_ct_36sl13_32_tv/manual-7023/page-22
Posted on Feb 14, 2008
I have the same problem. Any body fixed it?? plz let me know what u did to solve this problem. any idea how much the repair costs??
Posted on Sep 02, 2008
Where is this fuse, I opened the back and can not locate it, same no power problem.
it is located near the switch or transformer. Look for a cylindrical glass type.
Jun 12, 2009 | Panasonic CT-36SL13 32" TV
Tv shuts off tv/video doesnt work
that is a indication that a fault is about to occur, dont force that tv take it to a technician before it switches off completely, a power supply is supposed to be checked.
Mar 26, 2009 | Panasonic CT-36SL13 32" TV
Tv lock
PRESS POWER SWITCH AND ACTION FOR 3 SECOND
Aug 26, 2008 | Panasonic CT-36SL13 32" TV
Panasonic ct36sl14
the small fues in the back
Jul 14, 2008 | Panasonic CT-36SL13 32" TV
Is this?
This is from page 5 of the Operating Instructions:
TV set can
receive 480i signal only.
This means the television is NOT high definition, it is a STANDARD definition television.
Mar 15, 2008 | Panasonic CT-36SL13 32" TV
Tv went dead
Sounds like it could be H.O.T which stands for horizontal output transistor or a fuse is possible. Another possibility is the FLYBACK transformer. Is there a local repair facility you could take it too? Keep me posted. Have a good day...Jay
Feb 01, 2008 | Panasonic CT-36SL13 32" TV
Loud noise then no power
I recommend having a service call done in the home due to the size and weight of the set. Is the set HDTV ready or compatable? IF it isn't i would consider a new tv. Good luck on your quest. Jay
Dec 21, 2007 | Panasonic CT-36SL13 32" TV
No picture no sound nothing
We had a TV repairman look at our 3 year old (Oct 2004) Panasonic CT-32HXC14J FLAT SCREEN TV. It suddenly stopped working and appeared to have no power getting to it. It was a high voltage supply or transformer that was bad and has to be replaced - estimated cost is around $400. In a year we will also need to spend around $125 for a digital converter box. We went for the repair since that is still cheaper than a $1,000 plus equivalent size LCD or plasma.
Our old tube tv was still working after 15+ years. They aren't making them like they used to. Way to go Panasonic.
Nov 09, 2007 | Panasonic CT-32HXC14 32" TV
Panasonic model CT-36SL13G TV
Your problem is most likely the thermistor , or degausser, is going bad. It is a little black box with pins and says D1R5M on it. It can be found by following the wire from the degaussing coil around the picture tube. The location number is CF803( i think)the Panasonic partnumber is D4DF1R50001. Also, I believe your fuse is 6.3A not 3.6A.
Nov 07, 2007 | Panasonic Digital Video Duplex, Color...
Panasonic CT-36SL13 Can't select video inputs
On a Panasonic to do a factory reset while the set is on press in on the power and action buttons on the front of the TV at the same time. In a few seconds the screen shouls go blank and come up with a screen that says "CHK" in the upper left hand corner. Once it does that press the action button again to clear the screen. You have now reset the TV to factory settings and will have to re-program the channel memory once again. Hope that works...
Apr 23, 2007 | Panasonic CT-36SL13 32" TV
Panasonic CT-36SL13 32" TV Logo
322 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
