Question about Canon EOS-AE-1 35mm SLR Camera
Shutter won't fire...(same ol' same ol' with a new trip.)
So should I be concerned that there's no lag between the shutter blades when I manually trip the shutter? The circuit was corroded across a few terminals by the electro-trip and i cleaned them off, but the 6 v battery died and the grocery store didn't have another. I am hoping that it's a simple--buy a new battery, maybe solder a dab--kind of job.
I'm far more apt to trust my Konica T-3, and hopefully the D70 arriving tomorrow.
  • 667 Answers
By releasing the magnet on the bottom as you have described, the shutter curtains will run together since there is no electrical current charging the magnet to hold the 2nd curtain. No Worries..
Posted on Feb 14, 2008
Canon 40d will not take pictures
1) CF card in camera? Won't shoot without one
2) Does mirror go up?
3) Canon had a run of bad motors for this model - if mirror does not go up, then it is the mirror motor. If mirror goes up, shutter will not fire, press release again then the mirror goes down, the shutter motor is bad (same model motor). If mirror goes up, shutter fires, both blades travel together/no exposure, probably the shutter is bad.
May 07, 2012 | Canon EOS Digital Rebel XS / 1000D IS...
My shutter won't fire using 18-55 lens, either on Manual, P or Auto mode. It is set to AF. But when lens is set to MF, shutter fires. I tried switching to another lens and shutter is perfectly fine.
I could be that your lens isn't focusing. If the Auto focus can't find something to focus on the shutter won't fire. If you are shooting in low light sometimes it has trouble try shooting something that is well lit. also your auto focus point may be somewhere other than the center. there is a button on the top of your camera that looks like this [ ][ ] [ ] [ ]
More or less that will switch where your focus point is. If you look in the view finder and see a red dot when you push on the shutter button that is your focus point. push the above button until the red dot is in the centre. that may fix your problem.
Jul 26, 2011 | Canon EOS 450D Digital Camera with 18-55...
Shutter lag on fuji finepix s7000 - is there a solution ?
2 things - you could do 1 or both, depending on the photographic situation:
1) If you can choose manual focusing, select manual focussing & prefocus on subject. This eliminates the need to refocus. I do this lots with the S9500 model.
2) If you can shoot in manual mode, use auto exposure to see what shutter speed & aperture the camera selects when the camera is pointed at the ground (or other suitably lit spot). Change to manual exposure & set the aperture & shutter speed indicated by the camera in AUTO mode.
Once you do either or both of these you will get instantaneous shutter release.
Practise on unimportant subjects first and see how you go.
Apr 10, 2009 | Fuji FinePix S7000 Digital Camera
Firing "lag time" response
Hi poseguerai,
Try this:
I had the same issue and even if it sounds crazy giving a massage to the shutter button all around in circles helped and when you switch on the camera has no shutter lag again.
I hope it works as it did for me.
Oct 27, 2008 | Canon EOS 40D Digital Camera
Canon Ae-1
Shutter release magnet faulty ( your camera is cocked but since you cannot release the shutter you cannot wind the film ). Remedy : open bottom cover by removing the two screws. You will see two small electro magnets one on the left hand side and the shutter release one on the right hand side ( it is the bigger one of the two ). The very thin wires from the magnet to the small circuit board on the right hand side may be broken : inspect and resolder 10 joints you see on the p.c. board. If no joy replace the s.r.magnet.
Sep 14, 2007 | Canon EOS-AE-1 35mm SLR Camera
Shutter Lag-Time
The G5 has a rather short shutter lag and a rather lengthy focus lag. So if you half depress the shutter release to focus, and then moments later fully depress the shutter release I expect you will find very little lag. But I would not expect a prosumer model to focus fast. hope this helps,
Sep 14, 2005 | Canon PowerShot G6 Digital Camera
Shutter Lag
Card speed won't interfere with shutter lag. The lag is much less (near non-existent) if you pre-focus. Or use manual focus with small enough aperture to get lots of depth of field. Make sure your kids are in the focus zone and just snap away.
Sep 13, 2005 | Olympus Camedia C-5050 Zoom Digital Camera
Shutter lag
I don't know what your measurement conditions were, but there's no way the shutter lag after focus is 1/2 second. I don't have a quantitative number at my finger tips, but it surely falls into the "instantaneous" category, as far as I can tell. I've taken plenty of action shots and candids, including shots of flying birds, that will back that up
Sep 06, 2005 | Panasonic Lumix DMC-FZ10 Digital Camera
Shutter Lag
Thats going to be a problem with most digital cameras in that price range (and even some $$ ones) really the only thing I can recommend is PF.F.S. That would be Pre-Focus -- Frame -- Shot. Many people try to frame a photo up then focus/shot all in one, but this does not always work. So if your looking to speed things up a little, just half press the button to get a prefocus and then do your magic. Really everything I talked about above was Focus-lag, not actually shutter lag. But since this is often confussed I thought I would add it in.
Aug 31, 2005 | Canon PowerShot A80 Digital Camera
Canon EOS-AE-1 35mm SLR Camera Logo
82 people viewed this question
Top Canon Photography Experts
old marine
old marine
pontelemon
pontelemon
David Payne
David Payne
Are you a Canon Photography Expert? Answer questions, earn points and help others
