Question about Zenith IQB60M92W 60" Rear Projection Television
Zenith rear projection 60 in a60m91w1
I have no picture, i do have sound. the screen went black then there was a burning smell. like maybe a bulb blew.. thanks
Need replase new trasformer fly back is color grey
and check all parts losse by cool solder parts is sparking by cause is losse parts firt
Posted on Feb 14, 2008
  • 579 Answers
The power supply section is not working.
Common possibilities are:
- Convergences amps have failed overloading the supply
- High-voltage section (flyback transformer) has failed
(happens sooner or later, about 8 years typical))
- CRT tube has failed overloading the supply
- Power surge has popped the power input circuit.
(Fuse, rectifier diodes, turn-on relay etc)
- One of a hundred of electrolytic capacitors has failed short overloading the supply. They dry out with age, are cheap to replace, but hard to find which one it is.
- Or any of many other possibilities.
In short, you need a experianced tech to troubleshoot this.
How to fix a Zenith Projection TV. Could it be the bulb needs replaced? Is this something I can do myself?
The whole service manual is here: http://www.manualslib.com/manual/790821/Zenith-R50w46.html
But this is something that you might want to reconsider. The availability of parts could be an issue. The smell could be the ballast or the bulb got really hot and went out. The repair process involves troubleshooting with special meters etc. You may be able to spot something that burned out though.
Dec 22, 2015 | Zenith R50W46 50" Rear Projection...
I have a Zenith 54"
You have Bad Convergence ICs they are Big Black ICs and will have the part number on them ,example STK392-570 Mats Electronics has ICs 1-800-628-1118
Jul 03, 2011 | Zenith R49W36 49" Rear Projection HDTV
Zenith Projection Television R45W47
Ur tv the convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts are defective still have some life left,it will causes colors lines like RED,GREEN,BLUE misaligns,colors shadows,3D picture.When the 2 STK covergence ICS are totally dead it make this cricket noises and burning smell.The shop cost u $300-350 for parts and labors.
Jun 15, 2010 | Zenith R45W47 45" Rear Projection HDTV
No picture. no sound
Bulb may have popped. Cheapest fix, unless your an electrician it the only thing to really try before replacing set.
May 31, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Picture went out. sound works. smelled something burning
Replace Deflection/ power supply board,FBT flyback Transfomer will be on it.
Call Zenith Module Exchange 1-800-632-6637
Cheaper just to replace board.
May 02, 2010 | Zenith R60V26 60" Rear Projection...
I have a 1994 zenith big screen the picture is showing really dar
It could be that the picture tubes have gone down on emission, there is a prcedure that can be tried to bring up the overall brightness but it is just possible that you will loose some picture quality. If it's a 1994 projo tv i am thinking of the three crt system, a gray scale alignment would probably correct the dark condition in your picture, again depending on how far gone is the emission in your picture tubes, if your projo tv is the dlp system, the bad news is that you could be needing some light engine repair. The color adjustment is possible with the availability of a service manual or in the case of the dlp system, light engine repairs or replacement are available from some on line stores.
Jan 12, 2010 | Zenith E44W46LCD 44" Rear Projection...
"pop sound", picture out, burning smell...?
Usually, yes. A bulb that has audibly 'popped' will be apparently bad if you pull it out of the TV (shattered). Other times this is a lamp ballast board.
May 18, 2009 | Sony KP-53XBR45 53" Rear Projection...
Wont turn on smell burning
Can you remove the rear panel and check if the hissing is coming from the flyback? Which is a large transformer with a large red wire coming from the top of it? If so can post a link where you can get a replacement their not exspensive and their easy to replace. If its not coming from the flyback post a picture of where the hissing is coming from and I will identify the parts for you, But I feel its the flyback due to the hissing. respond to this same post so I have your correct model number when you reply.
Jun 25, 2008 | Zenith R57W46 57" Rear Projection...
Zenith rear projection 1997 z60283r8 (60")
check around the flyback for burn holes or splits in its case. May also want to check the horizontal output and regulator transistors for being shorted.
Feb 11, 2008 | Televison & Video
Zenith IQB60M92W 60" Rear Projection Television Logo
309 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
