Question about Hotpoint 24 in. FDW60 Free-standing Dishwasher
I have a hotpoint dishwasher, was installed in my house new when it was built in 2004
I have the above listed built in dishwasher, with a rotary dial.. For the first time tonight my wife and I noticed the smell of burnt plastic/rubber while sitting in the living room nearby. Please help!!
  • 868 Answers
This is a bad control board that if replaced will only repeat in a short time .My advice is to contact the manufacturer and complain,you have the right as a consumer to do so.
Posted on May 23, 2008
Hotpoint Built-In Dishwasher HDA3600DWWmy dish
there is an electronic solenoid near where the drainhose connects to the sump that changes the waterflow direction from recirculate(washing), to evacuate (draining). this is electronically controlled by the timer. you can test the power leads at the solenoid for voltage when it sould be draining. if none then the timer is faulty. if there is voltage then the solenoid is faulty. if the solenoid is engageing, then the water diverter is faulty. if the water diverter is broken, replace the dishwasher.
overflowing is another problem of its own. the water level float/ sensor is not working and could be caked with detergent. work the float from the inside of the dishwasher, it should move freely. if so, then there is a switch connected to the float on the underside. test it with an ohmmeter. if bad replace it. if it is an electronically timed water level control then it could be a problem with the timer as well, but with hotpoint they are usually manual.
Sep 27, 2013 | Hotpoint Dishwashers
Door on Hotpoint Diswasher BF1620 won't shut
To better assist you I need the Hotpoint Model n serial # look like this;
HDA3540NSA Hotpoint® Built-In Dishwasher HDA3500NWW Hotpoint® Built-In Dishwasher HDA3500NCC Hotpoint® Built-In Dishwasher HDA3500NBB Hotpoint® Built-In Dishwasher HLD4040NSA Hotpoint® Built-In Dishwasher HLD4000NWW Hotpoint® Built-In Dishwasher HLD4000NBB Hotpoint® Built-In Dishwasher HDA1100NWH Hotpoint® Built-In Dishwasher
Let me know wish one is yours.
Thank you
May 13, 2009 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Want to replace the heating element
Can you tell me which one is your dishasher to better assist you.
HLD4040NSA
HLD4000NWW Hotpoint® Built-In Dishwasher HLD4000NBB Hotpoint® Built-In Dishwasher HDA1100NWH Hotpoint® Built-In Dishwasher HDA3540NSA Hotpoint® Built-In Dishwasher HDA3500NWW Hotpoint® Built-In Dishwasher HDA3500NCC Hotpoint® Built-In Dishwasher HDA3500NBB Hotpoint® Built-In Dishwasher
Thank you
May 12, 2009 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Missing Instruction manual smeg dishwasher SA945X
try going to servicematters.com. You can download owners manuals there.
Apr 03, 2009 | Smeg 18 in. STX45-1 Stainless Steel...
Dishwasher made a popping noise and all the lights...
the connection at the bottom of the dishwasher where the house wiring meets the dishwasher wiring is probably melted. you would need to cut back the burnt wires and re-splice it..
Mar 13, 2009 | Hotpoint 23 in. BFI62 Built-in Dishwasher
I want a manual for HDA200G02WW
Go to managemyhome.com and register. This is a FREE serivce. Once registered, log in and go to the "Home" drop-down menu. Click on "Products and Manuals" and enter your Brand name and model number. Your installation guide and operators manual is listed in a downloadable .pdf format. Just make sure you have Adobe Acrobat reader on your computer so you can view it. I hope this helps you.
Oct 30, 2008 | Hotpoint 24 in. HDA2000Z Built-in...
Can't get the dishwasher to start!
Sounds like the pump seal is stuck. Cut the power and look at the back of the motor. There will be a cooling fan in the end of the motor. take the fan and keep rotating it until the seals break loose.
Jun 28, 2008 | GE 24 in. GSD2000Z Built-in Dishwasher
BF162 DISHWASHER HOTPOINT
I think if you push the heated wash and heated dry button several times until all the buttoms light up this will fix your problem.
 A clean light that flashed repeatedly 7 times then off. Reset as above with the heated wash and heated dry buttons. You may then noticed a reduced flow from the pump so dissasemble the lower arm and water inlet assy.You may find it mostly plugged with foregin matter and some othe junk. Upon removal of that stuff and reassembly,It may work as new!
Feb 09, 2008 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Hotpoint 24 in. FDW60 Free-standing Dishwasher Logo
190 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
