Question about Sony XL-2000U Projector Lamp for XBR800 serie
Need a replacement lamp for LCT50HV-tv syntax
Can i get a part # & where i can get one.
Please Visit Relampit.com for all your front projector and RPTV needs!!
Best regards,
Jon Rubino
Sales and Marketing
Projector Lamp Services
50 Orville Drive
Bohemia, NY 11716-2519
T: 631-244-0051 ext 110
F: 631-244-0053
email: jr@relampit.com
www.relampit.com
Posted on Sep 09, 2008
I actually have 2 lamps brand new for this same tv. The cost of this lamp is pretty high. My T.V. needed a brain, and the cost for this and the repair was toooo high. I'll let the 2 lamps go for $200. each. You can e-mail me @ pgaxiola@verizon.net
Posted on Mar 12, 2008
    Scholar:
  • 86 Answers
Not looking good for your problem. I have not been able to find a supplier on the web or ebay. You might have to call the company and order it from them, but I bet it won't be cheap.
here is there contact page:
http://www.syntaxbrillian.com/company/locations.html
Product Support
Olevia Product Support
Call Toll Free: 1.866.9OLEVIA
or 1.866.965.3842
If this TV is less than 1 year old, you should still have the manufacturer warranty.
You should read the customer review at amazon:
http://tinyurl.com/34owj9
Posted on Feb 14, 2008
  • 4 Answers
Here is the solution.
http://www.tvlampsforless.com/Olevia_LCT50HV_bulb_p/lct50hv.htm
Posted on Jul 24, 2008
  • twssocal Jul 24, 2008
    THIS IS THE SOLUTION!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    http://www.tvlampsforless.com/Olevia_LCT...
  • 579 Answers
Take the lamp apart and tell us what the numbers are right on the bulb. Projection TV makers charge an arm and a leg for their replacement lamps. They make it easy to do but as a result the custom lamp assy is expensive. The trick is to just buy the bulb for your model TV from any number of us aftermarket sources at a fraction of the lamp price and install it in the old lamp yourself. really easy. Some models are real bulb hogs though. Look them up on the net (include the word complaint or repair) before you buy, or you might be sorry. Many class action lawsuits out there - even against some of the name brand makers.
Hope ya fix it! www.sedonix.com
I have a 65 inch syntax brillian TV. The picture is pretty dark, and I'd like to clean the mirrors and lenses. How do I do that?
Shannon, cleaning the mirror or the lens will only drgrade the picture that's reflected onto the screen. A dark picture is most likely caused by the ~300 watt lamp aging and now needs replacement. You can confirm this for yourself by removing the lamp from behind the right hand speaker door and looking at the bulb-shape at the inside, bottom of the reflector. The bulb should be clear, with maybe a small white patch on the top of the inside of the electrod chamber. If it's a large white patch, or the chamber has any black, or even worse has a deformed chamber, the lamp only needs to be replaced.
I did the longevity testing for the 65" TV's. No other component caused the TV to 'darken' as you state....
Jun 19, 2011 | Syntax-Brillian 247T FHD 47 in. LCD TV
LCT50HV black screen and blinking red/green lights
Replace your Bulb which is located on the side panel. U can do it yourself and save some money.
May 19, 2009 | Syntax Olevia 50" Rear Projection...
Syntax olevia LCT50HV lamp
Hello starrider,
This is not a problem the power cycling or resetting can help. I would advise you to check the light tunnel for obstructions, dust can cause this, also check the voltage on the Lamp and make sure it is within specifications. The ballast can also cause this problem so I would advise checking it also. For this you will need the schematic, and a Multimeter set to DC volts. If you do not have a background in electronics I would suggest that you have a TV technician perform these tasks. As stated above, this is not a problem resetting can help.
I hope this helps,
Shuttle83
http://www.electron-age-technologies-llc.com
Feb 27, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Syntax Oleiva 50 in. LCD tv
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1Theinternal circuits are jammed because of electrostaticcharges accumulating on capacitors, or because of a wrong voltage readby the main chip on your monitor controller board. this started theprotection circuit.
2 The protection circuit detected a wrongvoltage or abroken contact, identified an internal fault and kicked in, starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Payparticular attention at inverter and power board, power board can beinspected looking for bulged or leaking capacitors, then tested with amultimeter. The inverter is more difficult to test , there is need toread voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Feb 16, 2009 | Olevia LT32HVE 32 in. LCD Television
TV LAMP
Apr 11, 2008 | Syntax Olevia 50" Rear Projection...
Olevia 50" rear projection problem
Apr 08, 2008 | Syntax Olevia 50" Rear Projection...
Olevia lct50hv
check your ballsit power supply, this is the part the light bulb goes into. Check light engine
Feb 19, 2008 | Syntax Olevia 50" Rear Projection...
Lamp
Jan 08, 2008 | Syntax Olevia 50" Rear Projection...
Syntax lcos
The lamp is dead. Call syntax/olevia and pay em a 100 bucks for a new one.
Mar 28, 2007 | Syntax Olevia 50" Rear Projection...
Sony XL-2000U Projector Lamp for XBR800 serie Logo
482 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
