Question about Ovens
Jenn-Air 88370 drop-in stove, want to convert!
I have an OLD Jenn-Air 88370 drop-in stove, likely the stove that was installed when home built... poor thing is falling apart, and the oven is too small to cook anything larger than a 9 lb turkey :) I have a new conventional electric stove that I want to replace with, however the Jenn-Air is hardwired (no outlet-- wired straight into wall) and the new one (obviously) has a 220 plug.
Any idea where to find a how-to on converting the hard wiring to a 220 3-prong outlet?
Thanks!
  • 13 more comments
  • Cynister1 Feb 14, 2008
    there are 3 thinner gauge wires, colored white black and green, and 3 larger gauge wires, one is green and two are black. How's that throw ya? Thanks!
    Ok, there is a red looking wire going to a black one, a silver coiled wire going to the green and a black to the other black.
    sorry for the duplicate posts :)
    do i leave the red one alone? there's a red coming out of the wall and it hooks to one of the black ones coming from the stove.
    thank you so much!
    ok FROM the wall is a reddish one, a silver coiled one, and a black one.
    AWESOME! THANKS!!!
    i compared the info with what we have and what we will have and it appears to be DEAD ON... YOU ROCK :)
    no... thank YOU :) and sorry, i didn't mean to omit the box! :) :) :)
    well no one else could even BEGIN to answer me so you get ALL my votes :)
    we'll be trying it out this weekend. we have a friend who is an electrician who isn't familiar with these old (read: ARCHAIC) drop-in stoves with hardwiring so I thought i'd do some research on my own... we may have him on call so we don't kill ourselves LOL. I'll def update you afterward :)
    LOL so i'll let you know if it works and i can cook dinner in it... or if i get cooked by it!! :)
    i'll def plan on working during daylight so i can kill ALL the power, there was lots of DIY work on the property before i occupied it so that's probably safest HAH! I'll definitely use the suggestions!
  • Cynister1 Feb 28, 2008
    ok so my electrician stood us up. based on the info you gave me i really think we can handle this (with the main breaker OFF of course lol). i have looked at the plug on the new GE stove, and it has two slanted prongs and one straight one. That said, would this probably be the best kind of receptacle to use: http://www.lowes.com/lowes/lkn?action=pr...
  • Anonymous Mar 13, 2014
    fan and oven light on and display is dark
    President:
  • 1,314 Answers
Your old jennair is 220 should be three or 4 wires in it red for 1 side of the 220 black for the other side of the 220 white for the bottom of the outlet and if green is there you can hook it with the white wire or just not use it let me know if your colors are different
Posted on Feb 14, 2008
  • 10 more comments
  • robert samples Feb 14, 2008
    what color are the ones coming out of the wall
    ok when you install the out let put black to one of the slanted flat holes in the outlet black to the other slanted flat and the silver to the round that will do it
    what color are the wires from the wall for get about the range just the wall
    ok red to flat hole black to flat silver to round hole that will do it red is hot black is hot silver is neutral
    another box wouldnt hurt lol but your welcome
    ty that helps me a lot
    its no big deal its just every time i help some one and they dont reply it drops my ratings i have 324 so far that havnt replied like ive told them how to fix it and they just go on so i need all the help i can get lol ty
    well let me know how it turns out
    youll be all right you dont put a hot line on a bare wire there are ony three comming from the wall two are coated one isnt peice of cake tech 17 isnt afaird to tackel the hard ones lol im the one you call when every one runs
    listen just turn the breaker before wiring no sweat and just handle one wire at a time people get the wrong idea 99percent of the time 110 wont hurt you now the red wire is 110 the black wire is 110 if you grab both of them at the same time you will get 220 but as long as you do it 1 at a time you wont get hurt and if you turn the breaker off there will be no power on them turn your current oven on then go turn off the breaker and try the current oven if nothing works your fine wire up your new one if you need me im here
    youll be fine sounds like a good plan
  • robert samples Feb 29, 2008
    yep that will do it and yes you can handle it
Jennair 88370 convection oven from 1979
can't help you with the noise. The knobs should only go back on one way - look at the shaft that the knob goes on, and it should not be a perfect cirlce - one side is flat. The knob should be the same way. Match them up, and push the knob down.
Jan 20, 2014 | Jenn-Air WW27430P Stainless Steel Electric...
F1E1 error happened repeatedly, jenn air says cut
F1 - E1
EEPROM checksum error
1.
Disconnect power for at least 30 seconds.
2. Re-apply power and observe for
at least one minute.
3. If code re-appears, replace control board (also
called ERC or clock).
Note: Applies to all F1-E...
codes except F1-E3.
Read more: http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Jenn
Air Range / Stove / Oven Fault Codes#ixzz19GMNtS3r
Dec 24, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
Jenn Air Range Model 88370 oven only bakes in the back and leaves food raw in the front.
It will be the oven element that has failed, a new one wiil need to be fitted.
It is located at the rear of the oven compartment behind a removeable cover.
I hope this helps.
Apr 11, 2010 | Ovens
Instructions to replace Jenn Air oven thermostat
To remove the control panel, open the oven door wide as possible. Remove the screws from the top of the CP and the screws from the bottom of the CP. Grasp the CP bu placing hands on the right and left sides of the panel, pull out and down to disengage. Depending on manufacture run you might need to lift up and out to diengage.
Have a cloth on the oven rack to lay the control on so you won't scratch the pretty facing. Once that is done you have easy access. Wear some rubber gloves doctor, this prevents harm to the electronics. Static discharge is a no no around expensive electronics. You can do this. Take your time. Piece of cake.
You will be able to check high limit cooling fan door latch and motors 9if applicable on your model) cool ain't it?
Jan 07, 2010 | Ovens
Jenn-air stove Model SCE30600B. Won't heat
check all the wiring at the main bus, and at the board connections could be a bad board
Oct 08, 2009 | Jenn-Air Ovens
I have a jenn air cook stove that was used with propane. I would like to know how to convert it to natural gas
You will need a conversion kit. The kit should be about twenty dollare, and it will explain exactly what to do. if you have any questions get back. You need a Jenn Air kit so go to any Jenn air dealer to get it.
Jul 07, 2009 | Jenn-Air JGW8130DD Gas Single Oven
Jenn-air oven model #88370
its just not that often the probe fails without setting a code
Feb 16, 2008 | Jenn-Air JJW8530C Expressions Collection...
Oven and stove top not getting hot.
The most probable cause is that the heating elements are getting 110V instead of 220V. Check the voltage to the heating elements.
Sep 07, 2007 | Ovens
Ovens Logo
1,031 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
