I have had this unit for several years but now I want to use it to make and preserve some records and 8 track cassettes for my wife. I would like to know if I can made a CD recording from the headphone jack on the old RCA stereo unit direct to my new Philips CDR775 ?
I see " PLEASE ENTER A VALID PRODUCT" at the bottom of this form. The numbers on the back of the Philips unit are CDR775/17.
Just buy a microphone connect it to the player to record.
You will also need a headphone to hear.But there are few headphones which also have a mic with them so you don't need to buy a microphone seperately.
Ex: in a walkman you only have a headphone to hear where as in some headphone's you have a mic cum headphone..
So if you buy this headphone cum mike you will have two jacks one will be green and the other will be pink or orange.You can connect them to the player as well.
Goodluck..
Yes it should work, but you may get noise in the recording
You need to run a cable with jack plug going into your old recorder heaphones output
Sure, using tape out is much better than using your headphone plug
on the other end you should connect it to the audio in plugs in your cdr
Here are the manuals for cdr, but I am afraid the English one was not working. If you want give it a try
http://www.usersmanualguide.com/philips/...
Resuming:
If you can use tape out from RCA unit into audio in at the back of CDR.
otherwise use headphones jack from RCA into audio in on CDR
Finally, if you do not have alternative use headphones out from RCA into ext. mic. plug on CDR, but this may not work properly
I suggest you not to monitor it connecting headphones in the middle of this. Better to monitor it listening to cdr audio out or headphones from cdr while recording
I gotta go now. Hope my posts had been helpful, if so do not forget to give me positive rating.
Many thanks
Yes you could record but not with the headphones.
you need to get microphone, it will help you record your cassettes.
I don't understand how to use a microphone to record stereo from a 8 Track Player as well as a phonograph. Do you propose to attach the microphone to the CDR775 ?
Thanks !!!
I want to connect from the headphone jack on the stereo to my Philips CDR775/17. Willthis work ?
On the back of my RCA Stereo Console are a group of tape IN and tape OUT jacks. Can I use the tape out jack to record some 8 track tapes to my CD recorder, and can I use the headphone jack on the RCA unit to record both the tapes and phonograph records ? I can monitot both with the headphones.
