Dell d400 not turning on?
Can a broken ac adapter make the laptop short out and not turn on my cat chewed on the wire and all of a sudden the thing stopped working. we bought a new adapter just waiting for it i was just wondering if that don't help what would? or what could be wrong with it if it don't turn on at all?
  • scorpio5050 Feb 15, 2008
    ty for trying to help me the laptop wouldn't turn on at all even with the new adapter in :(
    Genius:
  • 1,554 Answers
Don't look for a problem before it exists , wait for the adapter as it will most likely fix it.
Posted on Feb 14, 2008
  • Karl Whisenand
    Karl Whisenand Feb 15, 2008
    Well now it might be that the previous adapter if it shorted and sparked then it would have blown the protective diode in the power supply circuit.
    be sure the new adapter is putting out voltage check it with a meter.
    to you have any indication that the laptop is getting power at all.
Master reset
If you mean Factory Recovery? Does your laptop have a Recovery Partition? Take a look at Dell support: http://search.dell.com/results.aspx?s=gen&c=us&l=en&cs=&k=restore+dell+d400+to+factory&cat=all
Dec 29, 2012 | Dell Latitude D400 Notebook
Will not power on
hi
frist chack your Adeptor if it's working then just chack your bettry
if this two devices are wroking then you have to go for technition becoz may motherboard and HDD prob
May 26, 2010 | Dell Latitude D400 Notebook
My battery is charged have a brand new ac adapter/charger but it still wont turn on nothing no charging signal nothing at all what might be the problem?
If you have a new power adapter (and it is putting out the correct voltage) and you try to turn on the computer and nothing happens, I would suspect that your motherboard has gone bad.
The good news is that you can probably find a used one on e-Bay.
Oct 10, 2009 | Dell Latitude D400 Notebook
Charger isnt recognized
Dell portables use a sensing wire in the barrel of the adapter plug to determine the wattage of the ac adapter. If that fine wire in the center of the plug is bent or broken, the system cannot ID the adapter and the battery charger is disabled.
SO, first try a known good AC adapter for a D-Series Dell (You might be able to check with Geek Squad at a local Best Buy if you don'e have access to another ac adapter) If a known good ac adapter works, then replace the ac adapter.
If a known good AC adapter does the same thing then the fault is in the charging circuit of the motherboard and the motherboard will need to be replaced.
Oct 03, 2009 | Dell Latitude D600 Notebook
D400 laptop not power on,external power supply ok,19.5v ok on board,F1(fuse)ok
If you've tried a known good AC adapter, then you will be replacing the motherboard.
Sep 26, 2009 | Dell Latitude D400 Notebook
DELL Latitude D400 - what are the series of (blinking) icons?
sometimes this indicate a fault with memory or the system itsef.Before you begin you will have to remove the battery and the ac adapter.Remove the memory modules .Replace the battery and the ac adapter without the memory.Power it on if it comes on and beep several times then the memory is bad.If not remove the battery and the ac once again.Press and hold the power button for twenty seconds to clear the nonvol memory.Replace the memory the battery and the ac adapter.If still no go remove all the same items along with the hard drive and cd rom,Insert the battery and the ac adapter try again.If you hear a beep this time replace the battery(remember whenever you install to remove power).If nothing works and you none of the desired results you will have to replace the motherboard.
Good luck
Jul 16, 2009 | Dell LATITUDE D400 D500 D505 D600 D800...
Dell latitute D400 turn off suddenly
its overheating,you will have to check the heatsink if the filters on the end are blocked stopping air flow,and if the thermal grease on the processor is not totally dry.
good luck
Dec 20, 2008 | Dell LATITUDE D400 D500 D505 D600 D800...
Power problem
I don't think you are dealing with a short in your system. Your battery is probably dead and/or needs to be charged. See if your new power cord will work and will turn your computer on. Make sure that you have the exact power cord that your specific system calls for, because not all laptop power cords are the same. I mean you can't just use any laptop power cord; it has to be one that is rightly built specifically for your laptop system.
Sep 03, 2008 | Acer Aspire 7720 Notebook
Power Trouble
Hi!
First, you need to check the one that you got for replacement is the correct adapter for your system. If it matches with the old one, make sure that the ac adapter light (LED) is on when you plug it the wall outlet only. When you plug it in the portable and if your ac adapter LED blinks out (turns off) then the motherboard needs to be replaced or else the ac adapter is not working and needs another replacement. Call Dell and have it replaced if you just bought it.
Hope this helps!
Karlox™
Dec 19, 2007 | Dell Inspiron 2200 Notebook
Computers & Internet Logo
95 people viewed this question
Alun Cox
David Payne
David Payne
