Question about Sanyo DVW-5000 DVD Player/VCR
33 channels i am running cable thru my player but i can only get 32 channels, after that it is all blue screen, i have no idea how to get player to show all channels, also, i have no remote other than an universial that i bought but it does not perform all the functions that are needed. thank you for any help.guy at guybunn1952@yahoo.com
    Scholar:
  • 84 Answers
You can either try getting the original remote for your player, or buy cheap different universal remotes. i've actually bought remotes that control 8 different devices at the dollar store.each remote & manufactuer controls different devices & settings.just go into the menu setting,[after you program the remote] look for a cable/air setting, then press autoprogram for cable.that should get you passed 32 channels. cheap remotes will vary from$1-$10 & up.you can always return them to the store if they don't work your player. [except the dollar stores.]
good luck.
wg
Posted on Feb 14, 2008
3 yr old Vizeo and suddenly cable channels no longer received. 'No Signal' is displayed on blue screen. Any ideas ??
Do any other inputs work properly? If so I'd say your tuner has failed. If all inputs fail Id say you need a new AV mainboard.
thanks,
Michael
Apr 16, 2011 | Vizio L32 32 in. LCD HDTV
My neighbor has acquired a jvc tv/vcr combo w/ original remote. when she wanted to program it for cable it only seemed to do ch. 33 - 79 channel 2-32 did not show up. We also could not figure out after...
Your cable company has probably started distributing 2-32 as digital channels. The JVC only has analog NTSC capability. You can acquire an inexpensive digital tuner for around $40 to solve the problem.
Oct 27, 2010 | JVC TV-20F244 20 in. TV/VCR Combo
I just bought a used Sanyo 32'' flat screen, I saw the man plug it in and it showed video from a DVD player, now I can't get the regular cable to register on the screen. Help me please.
if you are using a cable box, run a.v.cables, hdmi, or s.video to your set. i'm taking for granted that you ARE auto programing your set thru the menu and you do have the setup/menu selection on all channel search. if you've hit the reset button on the remote...you'll need to unplug the power to the tv. if it is a problem with the connection, i have had problems like this repaired by pros for about $50.
Feb 13, 2010 | Sanyo DP32746 32 in. LCD Television
Green purple and blue bars rolling through screen
It is probably the main total assy needs to be replaced.
Jun 26, 2009 | Samsung LN32A550 32 in. LCD TV
Element FLX 3210 not scanning for cable channels
YOU HAVE A BAD TUNER OR RF INPUT. IF YOU CONNECT THE CABLE TO THE VCR AND THEN USE THE VIDEO OUTPUT OF THE VCR TO THE VIDEO INPUT OF THE TV YOU CAN USE THE TUNER IN THE VCR TO CHANGE CHANNELS.
Jan 10, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
No picture, blue screen
Use the TV input selector to select the right channel, that should fix it.
Jan 04, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Apex 32" TV - Blue Screen & Channels keeping running/changing
blue screen indicares that there is a problem in blue cathode circuit. please check 1 blue video output supply. 2 blue video ckt defective 3 signal from chroma ic to blue cathode missing. 4 loose connector 5 crt base loose. 6 chroma ic defective. I think sound will be ok .
Sep 22, 2007 | Apex Digital PF3230 32" TV
Help
Not a home repair take it to a repair store.
May 24, 2007 | Apex Digital PF3230 32" TV
Samsung Flat Screen SDTV Model #TXN3245FPNXXAA
on what you have explain you are to check with cable provider if your tunner was the problem all the channels would be affected try plugging another tv to the same cable and see what it does if you get the same symtoms then it will be from the cable company.if not then you will have to take your tv to a repairman and have it check probably a component in the tunner circuit is bad.or you tunner will need to be replace. good luck
Mar 26, 2007 | Samsung TXN3245FP 32" TV
Cannot set Cable Default Channel
I believe you are getting mixed up between channels and programs. Normally program 00 is used for VHS as it has slightly different parameters for colour and brightness. If the TV has about 39 or more programs which can be programmed in from the on screen menu, try using program 20 for the video and 30 for the cable. For this to work you must do the on screen frequency scanning from channels 22 to 69 (UK) and select VCR, CATV, VHF, UHF, etc. I have used program 00 and 20 for two VHS recorders, working on channel 33 and 35 for example, but you must tune them to 33 and 35 on the `Tune' screwdriver hole by the aerial input sockets of the recorders. I expect if your cable unit plugs into your aerial socket of the TV that it has an adjustment for what channel it is on. The TV on screen menu may be different in some countries, so it would help if I knew where you are.
Oct 21, 2006 | RCA F32632SB 32" TV
Sanyo DVW-5000 DVD Player/VCR Logo
60 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
