Question about Samsung CLX-2160N All-In-One Printer
Printer CLX-216X not detected by windows
My new CLX-216X does not print when connected with the USB cable. It is like if there is no power or signal to be detected by Windows Vista
  • Anonymous Jul 29, 2008
    Turned power off & on again also check that the USB correct and that power is connected to printer shows that it is ready to print but nothing happens like that the computer is not talking to the printer
  • Hengist Nov 11, 2008
    When New printer scanner is connected by usb to the Windows XP Professional pc it shows printing... for a very long time with no output.Pull out the cable and sometimes it prints the document. I have tried several cables which work fine with other printers etc. It scans and it prints from USB drive but not as a printer.
  • Samsung Expert
  • 406 Answers
Change the USB cable. If not recognised by vista. Check also whether your USB drivers are properly installed.
If Printer is not at fault please take the copy or a test print log report by continuously pressing the Big buttton with LED inside. Before that check all the trays are in proper position and Powered.
Posted on Feb 14, 2008
Installed HP deskjet 890c printer to new windows 7 laptop - purchased new usb printer cable - will not print from laptop but will print test page from printer
Before we conclude that cable is faulty, we have few things that need to be checked.
  • In the device manager check for "Other Devices" and expand it, you may see an device with exclamation sign on it. Right click and uninstall the device.
  • Disconnect the printer USB and reconnect it back.
  • Windows 7 detects the hardware and automatically installs the correct driver.
Note: When you connect the USB cable to the printer, and then to the computer, Windows 7 activates Windows Update. Windows Update searches online for the most recent product driver on the Windows Update site. If the online driver is more recent than the driver stored in Windows 7, the computer downloads and installs the updated driver.The Windows Update process takes place automatically. Therefore, you might not notice that the process is in progress.
If you dont see any notification on connecting the printer, try plugging to different USB port.
If non if these works, replace the cable.
Good Luck!!
Feb 07, 2012 | HP DeskJet 890c InkJet Printer
HP-1110 printer scanner can't be use in Windows 7 PC
Follow these steps to remove previous HP drivers, and then install the new driver.Step one: Remove previous HP drivers Follow these steps to remove the current drivers.
  1. Disconnect the USB cable from the HP product, if it is connected.
  2. Click the Windows icon (c01367376.gif ), and then click Devices and printers .
  3. Find the printer icon (c01813941.gif ) representing your HP product, right-click it, and then click Remove device .
  4. Follow the on-screen instructions to remove the driver.
  5. Repeat these steps to delete multiple instances of the same printer icon, and also for any fax icons for the product.
  6. Reboot your computer.
When your new operating system is up and running, simply connect the USB cable from the computer to the back of the HP product, and then press the Power button (c01602202.gif ) to turn it on.
Windows 7 detects the hardware and automatically installs the correct driver. A notification lets you know when installation begins and when it is complete. You do not have to download any software or insert the product CD.
Feb 28, 2011 | HP LaserJet 1000 Printer
How can I turn a CLX-3185FN into a CLX-3185FW?
Buy a Netgear WNCE 2100 which has one wired ethernet port connected internally to a wifi radio which is a 2.4GHz transceiver with WPA security. Fully compatible with most routers from D-Link, Netgear, Buffalo, etc. The samsung printer has a USB port to which you can connect and power the WNCE2100. This product is called by two different names. Sometimes it is called a Universal Ethernet Adaptor and others it is called a Network Bridge--which is more accurate. The Netgear product is b/g/n compatible. Try to place it not more than one room away from the router because the signal strength drops very fast if it is more than one wall and or 40feet from the wireless router.
Jan 03, 2011 | Samsung CLX-3175FW Multifunction Laser...
Samsung printer clx 216x is not recognising the new toners we have loaded. it is coming up with error.
re check if toner grade is the same as the original one, and shake well before inserting.
Mar 29, 2010 | Office Equipment & Supplies
I try to install a clx-3175FW on my router a fritz!box of xs4all network. The only moment of wireless contact is when I manualy type the codes in the keyboard of the printer. But at the moment I insert the...
I had the same problem with my CLX-3175FW. It would find my wireless router, but once I entered the WPA key, there was no connection. I solved this by taking the machine over to the wireless router, and then connect them by using a regular network cable. I followed the instructions in the book which came with the product, and then removed the network cable. After this the machine is connected to the wireless network. Regretfully, I still have problems printing wirelessly, so I bought an USB cable to connect the machine directly to my desktop :(
Dec 23, 2009 | Samsung CLX-3175FW Multifunction Laser...
Cannot print from computer. printer will print test pages, though
How the printer is connected to PC Via USB or using Network Cable. If it is connected Netwrok cable than printer configuration page and on netwrok configuration there will be IP Address if this is valid IP Address than reinstall drivers and upgrade the Firmware of the printer.
If Printer is connected USB than try different USB Cable and try different USB Port on the computer
If USB port on the computer is working fine and check in Device Manager if the printer has detected as unknown device or not detected at all.
If detected as unknown device than reinstall printer driver if not detected at all than USB Port on the printer is faulty you need to set up hardware repair of the printer.
Oct 16, 2009 | HP Color LaserJet 3500 Printer
Colorlaser prints black badly
I had a similar problem, which I fixed by carefully wiping the drum with a soft tissue.David
Mar 16, 2009 | Samsung CLX-2160N All-In-One Printer
Computer can't find my printer
you may try to make sure:
1) PC detect your printer when you plug the USB cable in (PC has 2-4 USB interface) and power on the printer, then you can see the indication on the down right of windows bar( indicate find a new device if no driver installed) , it means your printer connection is normal. if windows can not detect your printer go next
2) check USB cable might be some where disconnection, or change another cable, check the the sockets (two side jacks needed), still trouble you may change another PC to test.
Feb 07, 2009 | Lexmark X1270 All-In-One InkJet Printer
Samsung CLX-3160FN won't print from my HP Pavilion Media Center M7467C
I have a brand new HP pavilion, but it wont print from my HP deskjet. If i am lucky i get the first p[age and a couple of lines on page 2. My new laptop (ACER) is quite happy to print using the same cable. printer etc. Conclusion...HP pav is defective. Am I wrong?
May 01, 2008 | Samsung CLX 3160fn All-In-One Printer
Ip4200 - printing issues!
Hi, Perhaps you can try: remove the USB connection of the printer; uninstall and remove all drivers of the Canon IP4200; reboot your PC; plug in your usb to the PC from the printer; power on your printer; let windows auto detect "New Hardware found"; let windows auto install drivers; test print. If after plugging in your usb and powering your printer Windows did not auto detect "New Hardware found", it's possible that your printer's usb cable is defective. If Windows auto detected the Canon IP4200 and auto installed all the necessary drivers but failed in the test print, repeat above steps but instead of auto install, use the original CD driver and not the new drivers (Let me choose which drivers I want". RESET - User manual is available from the Canon site. There are 2 versions, 1 is a Quick Start Guide in pdf and the other is a User's Manual (On-Screen). Both does not say anything about reset, however you may want to google "fix your own printer" and variations of resetting all sorts of printers are available. Some works, others are ... well you can always give it a try. Or in the On-Screen Manual,you can also try the Troubleshooting/Printing Does Not Start. Another thing that you can try is installing the printer in another PC using the old CD drivers and see if it works. If it does, then it is a driver issue with the new PC. If it does not, you're back to reset . Hope this be of some help to you. Good luck and kind regards.
Jul 30, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Samsung CLX-2160N All-In-One Printer Logo
124 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
