Grundix Yacht Boy 400
I have the above. It turns on and off without any problems. You can tune to different stations. However, no sound is heard. Can this be repaired?
  • Renron Jul 29, 2008
    same issue, no sound. Small click from speaker / headphones when turned on. NO sound from either Am or FM across the dial. It worked perfectly yesterday all day, turned it off. Put it in the truck (gently) and today ....nothing. I opened it up and saw a discolored cap, tested it and it was within specs. no signs of leaking. Any ideas?
  • Anonymous Aug 19, 2008
    put in fresh batteries, set my channels/codes but i have no sound
Can you hear anything through headphones?
Posted on May 18, 2008
Raymarine autopilot
Hi Alchik. Lightning hits can affect all and everything, Murphies Law says that until you have replaced all control electronics, the fault will continue to pester you. Is there any part of the system that has not yet been replaced? Because that is probably going to be the course you have to set for yourself. I loath acts of God when it comes to electronics.
Mar 21, 2008 | Audio Players & Recorders
Radio is turned on but no sound, mute is off
The radio has an amplifier? and you are sure there are speakers connected?
Jul 09, 2014 | Alpine CDA-7894 CD Player
I don't know anything about grundig yacht boy 206
Go to this site and look for the type of documentation that interests you.
Jan 25, 2013 | Audio Players & Recorders
I have a grundig yacht bot 205, serial number 001143. I was wondering what year and where it was manufactured?
The Grundig Yacht Boy 205 was early 90s and could have been made anywhere. The Grundig Yacht Boy 205a was early to mid 60s and made in Germany.
Apr 28, 2011 | Grundig Yacht Boy 205 AM/FM/SW Radio
Pioneer premier deh-500ub presetting stations
Storing the strongest broadcast
BSM (best stations memory) lets you automatically
store the six strongest broadcast frequencies.
1 Use MULTI-CONTROL to select BSM in
the function menu.
2 Press MULTI-CONTROL to turn BSM on.
The six strongest broadcast frequencies are
stored in the order of their signal strength.
# To cancel, press MULTI-CONTROL again.
Tuning in strong signals
Local seek tuning lets you tune in only those
radio stations with sufficiently strong signals
for good reception.
% Press LOCAL repeatedly to select the
desired setting.
The LEVEL4 setting allows reception of only
the strongest stations, while lower settings let
you receive progressively weaker stations.
You can also perform this operation in the menu
that appears by using MULTI-CONTROL.
Selecting alternative frequencies
When the tuner cannot get a good reception,
the unit automatically searches for a different
station in the same network.
1 Use MULTI-CONTROL to select AF in the
function menu.
2 Press MULTI-CONTROL to turn AF on.
# To turn off, press MULTI-CONTROL again.
! Only RDS stations are tuned in during seek
tuning or BSM when AF is on.
! When you recall a preset station, the tuner
may update the preset station with a new frequency
from the station’s AF list. No preset
number appears on the display if the RDS
data for the station received differs from that
of the originally stored station.
! During AF search, sound may be temporarily
! AF can be turned on or off independently for
each FM band.
Apr 20, 2009 | Car Audio & Video
Grundig yacht boy 400 radio does not work with mains operations
I had the same problem. Examined the wire from the transformer,and found a break. Repair of the wire solved the problem. WLD
Mar 01, 2009 | Grundig YB 400PE AM/FM/SW Radio
Radio without remote
Press Function button at front of unit until display shows Tuner, and press Preset + / Preset -
If you want to listen Non-Preset stations, press << / >> keys of remote to tune a station. That's the procedure.
If built-in remote in your mobile have above said << / >> keys, you can tune station frequency.
Nov 10, 2008 | Audio Players & Recorders
Sharper image clock radio for shower
To set tuner presets:
1. Manually tune desired frequency.
2. Press MEMO button, Display will flash.
3. Manually enter memory position, 1-5.
4. Press MEMO button again.
The manual is available as a PDF file from the Grundig web site. Or, if you will e-mail me at deepblack <at>ugaalum<dot>uga<dot>edu and put "Yachtboy" in the subject, I will e-mail it to you
Mar 23, 2008 | Grundig Yacht Boy P2000 AM/FM/SW Radio
402 people viewed this question
