Washing Machines Logo
Posted on Jan 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Have a buildup of a hard orangy (rust color) deposit on the bottom of the interior glass door. Seems like mineral deposits, but the color is odd. How do I get rid of it.
Anonymous
Level 2:
Scholar:
  • Expert 82 Answers
  • Posted on Jan 23, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
82
Questions
0
Helped
19793
Points
217
The color shouldn't be a problem. This is common as this is where the door seals and dirt and detergent seems to collect here. Getting rid of it may be a little more tough. It has probably been building up for a while unnoticed because the color stays faint for a long time. First try cleaning with glass cleaner or vinegar and water solution. If this does not work try CLR. You will have to scrub at it but most of it should come off. I have seen this quite a bit and it usually does not all come off. If the door is glass you can be a little more abrasive with the stain but if the door is plastic be very careful not to use abrasives as this is where the door seals.
Thank you
Please rate this post
1helpful
Frigidaire d. w. grit and white film on glasses
Good Morning Friend,
I see that you are receiving grit and a white film on your glasses, in your Frigidaire dishwasher, model# FDB1050REC. Here are some common solutions that you can begin with.
-Check your water hardness. Hard water can cause lime deposit buildup on the interior of the dishwasher. Dishes and glasses may also get spots and film for a number of reasons. To remove buildup, spots and film, clean using the following instructions:
1. Load clean dishes and glasses in a normal manner. Do not load any metal utensils or silverware.
2. Do not add detergent.
3. Select the NORMAL WASH cycle. Close and latch door. Press START/CANCEL pad.
4. Allow your dishwasher to run until it starts the second water fill (approximately 10 minutes).
5. Unlatch and open the door, and pour 2 cups of white vinegar into the bottom of dishwasher.
6. Close and latch the door and allow the cycle to finish.
For extremely hard water, it may be necessary to install a water softener.
-Your water temperature may be low. Avoid extremely low or high temperatures.
-Avoid overloading and improper loading.
-Make sure you are using fresh detergent. Old detergent is ineffective.
-Make sure your rinse aid dispenser is filled.
-Check to see that the proper amount of detergent is being used for cycle selected.
-Your home water pressure may be too low-it should be 20 to 120 pounds per square inch (psi).
If none of these suggestions helps, I would suggest contacting either the manufacturer or a local authorized technician. Hope this helps.
-Best Regards-
WP
tip
Remove hard water stains from inside dish washer
one of the biggest problems with dishwashers, is the insides of it get covered with rust colored stains usually from the hardness of the water in your area.
the stains build up slowly from the water evaporating during the drying cycle, leaving mineral deposits on the interior of the unit.
By luck, I tripped upon a easy solution, thanks to one of my kids.
It seems she wanted to help out,and instead of putting dish washing soap in before starting the load, she put TANG breakfast drink in the dispensers.the citric acid seems to be the ingredient doing the trick.
Unbelievable, but true, the tang removed ALL of my staining, in one run.
give it a try, you'll be amazed.
TANG is a registered trademark of kraft foods.
on Aug 14, 2010 • Dishwashers
Leaving a white film on everything
Hi, what you are currently experiencing is as a result of dishwasher detergent, combined with mineral deposits from hard water, which in yurn can leave a white film on the inside of the dishwasher.
You have to clean the dishwasher by sprinkling baking soda onto a damp cloth. Scrub the inside of the dishwasher to remove soap scum, grime and mineral deposits.
Pour 2 cups white vinegar into the bottom of your dishwasher. Turn the dishwasher on and run it on a full cycle. Stop the dishwasher halfway through the wash cycle and allow the vinegar and steam to work on the remaining mineral deposits for 20 minutes before resuming the cycle.
Open the dishwasher and dry the interior with clean, dry cloths. Keep the door propped open for 20 to 30 minutes to allow the dishwasher to dry completely.
Hope it helps....
My indesit idl40 cleans everything, but leaves a film? does not seem to rinse?
2helpful
What does de-scale mean?
De-scaling refers to removing mineral deposits that build up over time. These minerals are found in regular tap water with higher concentrations in areas with hard water. Run a mixture of 1 cup white vinegar to 1 quart water through the machine followed by 2 or 3 cycles of clean water to clear any buildup. If the buildup is heavy you may need to use a cleaning product designed for cleaning coffee brewers.
My shower no longer heats.
The problem is most likely your hot water heater; a combination of 1 or more things. 1.Accumulation of rust sediment inside (at the bottom) of the heater will make it harder for the gas flame to heat the water. 2.Where the cold water feeds into the hot water heater, there is a long plastic tube inside the heater so the water feeds to the bottom of the water heater. Occasionally this tube breaks off and the new water does not feed down to the bottom where the gas flame is. You can try flushing the rust deposit out of the bottom of the heater. Screw a garden hose onto the drain-faucet at the bottom of the heater, put the other end into a drain and open the faucet for a few minutes. This may or may not release rust deposit. As for the plastic tube, a plumber would need to examine it to see if that's the problem. The odds are that the problem is not the tube, but is rust deposit. Eventually the heater will rust through and will need to be replaced.
Mar 01, 2011 • Home
How to clean brown water coming out of iron
The reservoir of your iron needs cleaning if it looks as though small deposits are being left in the small holes on the soleplate. Typically, the deposits are minerals from the water that you are using in the reservoir. The deposits may have a white color, and they may resemble salt.
Cleaning the reservoir requires the use of white vinegar and a clean rag. Fill the reservoir of a cold iron at least one fourth of the way with white vinegar. Turn the iron on and place it on the steam setting. Steam iron the clean rag until the reservoir is completely empty.
If the deposits are still visible to you, you will need to fill the reservoir with clean water and steam iron a rag again. If the deposits are still visible to you after this, you will need to repeat the process with vinegar until the deposits are no longer apparent.
Rinse the reservoir thoroughly with clean water by filling it completely and then emptying it completely. In order to avoid mineral buildup and deposits, use only distilled or purified water in the reservoir. If you continue to use tap water, simply remember to clean the reservoir periodically.
Vinegar has a strong smell associated with it, especially when it is heated. Ventilate the area where you are working as much as possible, by opening windows, turning on vents or fans, or keeping the door open.
The water you use to fill your iron is causing this problem. Once you clean it use distilled water available by the gallon at the grocery store. Joe
The coffee comes out very slow and it seems like there is some sort of clog.
This may be caused by hard water mineral deposits.Run a cup of regular vinegar through a normal brew cycle followed by a full pot of water to rinse the vinegar from the machine. This will remove most mineral deposits.
2answers
My viking dishwasher does not rinse the soap scum off the dishes
Maybe . . . remove the lower rack and invert it. Look for cracked or missing plastic coating, exposed, rusted & possibly "swollen" inner steel rod/wire. If found, remove the upper rack and look for more of the same. What you think is "soap scum" is probably rust and other iron compounds leached by the dish soap out of the rusted steel onto the dishes and the dishwasher interior. The following worked for me . . .
To clean the interior (with both racks removed), set to "No Heat" dry, then "Pot & Pan" wash and allow to fill. Open door, dump in a bottle of "Lime A-Way", close & latch door and allow to complete cycle. This should remove most rust and iron-sulphate deposits from interior. If not, scrub them with Lime A-Way and a ScotchBrite pad, then cycle again.
Racks must be replaced (Viking are very expensive, Asko, Bosch, or other lower racks may fit: check your neighbors' racks for fit), upper rack must be Viking unless you can exact-match the Asko or Bosch equivalent.
Possible fix: remove the loose plastic coating and flaking rust with a knife, ruff plastic coating with ScotchBrite, clean with rubbing alcohol, then treat metal/rust with "rust converter" (hardware or home imp store), wash with soapy water, rinse, then clean with rubbing alcohol, dry fully, coat with "high temp" (orange or yellow) silicone sealant (auto part store), covering exposed metal and a half inch or so over the plastic coating. Let set for a day or two.
A trip through the dishwasher for all your stained stainless, glasses and non-metallic coated or non-metallic decorated dishes with Lime A-Way as above (on new or "rebuilt" racks) should get the metallic scum and rust off them.
2helpful
2answers
Water marking/etching glass sink
Hi Mia,
Glass sinks are beautiful! The water deposits you speak of can be from two sources - hard water in which mineralization occurs, and alkaline products or alkaline water. If you have mineral deposits they will easily remove with vinegar and water solution, start at a half and half mix.
It is recommended by most manufacturers to wipe the water out after every use, which is not usually told us when we make the purchase, is it?! :-)
If this is a vanity or bathroom sink, you want to be especially careful that you do not pour or spill cosmetics, skin care products, nor other subtsances that may be alkaline. Many facial cleaners, toiletries, perfumes and household cleaners are alkaline. If you have alkaline damage, it's not possible to repair the etching.
I will hope your problem is hard water or water deposits - try the vinegar solution. I use white vinegar. Good luck, and we'd love to see a photo posted of your sink!
Gregg
Mar 24, 2009 • Home
Top Washing Machines Experts
john h
