Look for changing the USB mode of the device to MSC or MTP
Go to USB Mode settings.
if you have a Sansa View
- From the Main Menu, select More -> Settings/Options -> System Settings -> USB Mode.
if you have a Sansa Fuze
- From the Main Menu, select Settings > System Settings > USB Mode.
if you have a Sansa Clip, e200v1 series, e200v2 series and e200R
- From the Main Menu, select Settings > USB Mode.
Select Auto Detect, MTP or MSC.
e200R - PlayforSure is MTP and Rhapsody is MSC
NOTE: The USB mode is not selectable for Sansa View (FW 1.03.XX and below),
Sansa e200v2 (FW 03.01.14 and below), and Sansa Clip (FW 1.01.11 and below).
The USB Mode setting can be enabled on these players using a firmware update.
For a more detailed explanation of MSC and MTP modes see my tip posted here ---
-> http://www.fixya.com/support/r3774047-solve_mp3_player_connection_problem <-
SOURCE: Adding music.
open up windows media player and select copy to disk or device then drag you r songs to the right side of the screen and then on the left select the bar and find sandisk sansa m240 and then click the copy button
SOURCE: m240 sansa mp3
try removing the battery of the player for around an hour then put the battery back in. If it still freezes on that part maybe your songs are corrupted try reformatting the player.
SOURCE: My Sansa m240 does not play music, it freezes.
Try going into your USB Settings on your device and ensure the unit is set to msc
SOURCE: my m240 can't be recognized!
Please make sure that you have your device on MTP mode (auto detect)..Then the computer should be able to recognize it...To make sure its working correctly uninstall it and reinstall it back from the computer..and that should solve the problem..let me know what the outcome..
Please rate accordingly
Thank you
Computerrep
