Question about Mitsubishi VS-45607 45" Rear Projection Television
Vs 45607 do you have to know how to sodder to replace a 9v regulator
    Problem Solver:
  • 17 Answers
Yes, replacing a voltage regulator IC requires soldering.
Posted on Feb 14, 2008
I receive a blank blue screen even though my DVD players says it is playing? My tv is an older HD1080 series. I am not certain if I have chosen the correct model below. I do know it is a projection wide...
i would try other inputs and see if you can get anything. some of these tvs have a bad 9v regulator on the signal board that powers the video switch. if it goes bad, you wont get any video at all on any input, but you will still get menus and sound
its like ic9c25 its a ba09 regulator
Jun 12, 2010 | Mitsubishi VS-45607 45" Rear Projection...
Horizontal lines running on screen
There are some transistors attached to heatsinks (small heatsinks) on the left portion of the chassis. this board that has the input board attached to it is the signal board. those transistors are regulators they are labled 7809 or 7805 depeding if they are 9 or 5 volt regulators. use a multimeter to determine if one pin has 9v (or 5v) coming from it. if not this is your problem. i see alot 9v regulators going bad, some take the cap attached to the 3rd leg with it so check that too. if this sounds overwhelming it might be a job for a repair tech.
Jan 07, 2009 | Mitsubishi VS-60607 TV
My vs-60607 has waving lines
postive 9v regulator on the signal board and possible capacitor right next to it. the regulator is generic 7809. if you test the output it will be 6 or 7v needs to be 9. when the lines go away it is warm and will read 9v. so do the test cold. i'm assuming you know how to use a multimeter. if not then a local repair shop can do this for you.
Jan 01, 2009 | Mitsubishi VS-60607 TV
Vs-45607 Vertical Hold Problem
Good Day; Just replace the caps first, 99.9% fix if not replace 9v regulator. Good Luck, big IRISH.
Nov 23, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Lines in picture
can you post a picture of the lines that are going across your screen? Sounds like maybe retrace lines.
Feb 14, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Vs45607
yes the regulator has to be solderd into the circuit board.
Vs-45607
The 9 volts power many things the microprocesser is one of them, if the voltage is dirty because a filter cap is failing color will be afected as well
Feb 12, 2008 | Mitsubishi VS-45607 45" Rear Projection...
My vs45607 has problem
Theres a leaky capacitor on the 9V regulator output line. If you don't know what I'm talking about, you probably shouldn't try but it should be a fairly reasonable repair by a pro. Good Luck
Dec 28, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Shaking screen
Check the 9v regulator Ic2p01 on the signal board for correct regulation 8.9 to 9.1 volts. If voltage at the output is under 8.9v, replace the regulator Ic. Always replace C2p05 100 Ufd 16 V on this set and that should take care of the shakes but you may want the tech to go ahead and ESR some of the other troublesome caps throughout the Tv. He'll know what you mean. Many of the 100mf caps replace automatically. Several others will have a questionable ESR and should be replaced. Caps are inexpensive, but probing with an ESR meter is somewhat labor intensive so you miht discuss with the tech just how far you want him to go testing for bad caps.
A Mits is a great Tv and this repair is clearly worth it..
Bill
Dec 19, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Picture is Rolling..stops after some warm-up
I have seen this many times. There is a 9 volt regulator on the small signal board that causes this. The regulator goes bad and the 9 volts starts dropping, especially at start-up when the regulator is cold. If the voltage is below 8 volts then the picture gets dark and the vertical becomes unstable, with the picture squeezing down and/or rolling. As the regulator warms up the voltage starts rising back towards 9 volts and the symptoms start clearing up. There are 3 regulators in a row on the board and the regulator in the middle is always the bad one. Replacing that regulator should cure your problems but it should be replaced by someone experienced in servicing Mitsubishi projection TV's because pulling the chassis out is quite tricky.
Aug 05, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-45607 45" Rear Projection Television Logo
37 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
