Question about Riso RZ220 Duplicator
Error Code I have a riso GR3770 that has a T1 error code, and advice? I called service out two years ago with the same error, and the tech reset something and charged me a high dollar amount for about five minuets of work.
    Sniper:
  • 71 Answers
From memory (haven't looked at one for about 7 years) the T1 fault was when the latch hadn't disengaged.
Back panel off, towards the middle at the bottom there is a small solenoid with a kindof latch/hook. It will be engaged onto a small lever.
IF it is the same fault as above, it's really easy to sort, by pushing it off with a screwdriver, as a lever.
The way to tell is if the roller under the drum is still engaged. If so, you won't be able to pull out the drum.
Let me know if it helps, or if you want another suggestion.
Posted on Feb 14, 2008
    New Friend:
  • 34 Answers
T1 is a main moter lock. Try pushing the ALL RESET see if that is the fix. If not the drum may be stuck on the master removal hooks. The problem is this will cause it to jump time.This is not easy to fix.
Posted on Feb 20, 2008
  • adrianojos67 Apr 13, 2011
    How do you put the drum back into timming, we believe the drum jumped out of timming
  • eandhgraphic Apr 14, 2011
    Remove the back cover, cut plastic ties that secure electrical harness, carefully unplug harness that was secure to large metal frame that support the belt tensioner, undo screws that secure the frame. Be sure to scribe a line on the shaft & disc of two half moon disc that rides between the two sensors. you have to remove them in order to get the frame off & thus the scribe marks are for timing purposes. remove tension motor to release tension from main drive belt release two screws from clutch and the large tension spring. return drum to the ( A ) position Home. rotate drum in clock wise rotation from the back of machine. A position is recognize by removing the drum there is a sensor at 6 O' clock @ the bottom of drum opening, match sensor on drum offset to the right of bottom sensor. replace all parts in reverse, pay attention timing marks and belt tension secure electrical connections & tie down. do not attempt if you are not mechanically inclined.
Riso RP3700 with error code T03-502. Looked it up online and it said Motor clamp locked. How to fix it?
T03-***
!!System Error!!
Press Reset Key
If Recovery has Failed, Call Service
Reset method: Jam reset or switch on power again
Feb 18, 2017 | Office Equipment & Supplies
My riso ks 800 duplicator shows E13 Error code
my riso ks 800 duplicator show error code E3
Apr 14, 2011 | Office Equipment & Supplies
Call service engineer code T14 just come up on my Riso GR3770 I am fairly conversant with my machine but I have not seen this before - can you help?
Try to hold both and press the M/L P/L button then turn on, u r entering the test mode of the mcahines,, then press 97 and start button.
Jul 13, 2010 | Riso RZ390 Duplicator
Code Error T4
T-4 is an ink overflow condition. You may need to check and clean out ink section of drum. Remove the ink then press reset button. Then turn off and on and re-insert ink.
Dec 01, 2008 | Riso RZ220 Duplicator
Riso HC5500 System Error - Restart!
I need help with the error code. s04-307 in my riso hc 5000
Oct 22, 2008 | Office Equipment & Supplies
Error Code T14 on Riso GR3770
The machine is not alinged. I had that code this evening and the guy came here and in no time he fixed it. is your drum going in the machine? if so then turn off the machine and while pushing down the clear/reset button turn the machine on
Oct 16, 2008 | Riso RZ220 Duplicator
Riso ks800
e4-ink over flow. solution-clean ink sensor.
e3-clamp motor locked. solution-use code 64
Sep 21, 2008 | Office Equipment & Supplies
534 people viewed this question
Top Riso Office Equipment & Supplies Experts
Marius Chiriac
paulfvincent
Adorjani Laszlo
Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
