Question about Bosch 3.81 cu ft WFMC530 1UC Nexxt 500 Plus Series Washer
Code E13 What does the code E 13 mean?
  • tcharolais Oct 08, 2008
    I just bought it from the store and it will not let water in, is there anything that I can do? Is this going to be an ongoing issue?
For a Bosch washing machine, Error 13 is pumping time exceeded. So, in general, the issue is pump related. Things to check would be if the pump is blocked (it can be cleaned out if you can get the service door in the front panel off), check the wiring connections to the pump, and check the drain hose to make sure it is not blocked.
Posted on Apr 02, 2008
Error code E:13
I thin E13 is motor error, I will check.
Sep 03, 2008 | Bosch Nexxt 300 Series WFMC2201UC
I am getting a E13 code Does any one know what that is and how to fix it??
Dave, E13 code for WHAT?!?!?!?!?!!?
Have any idea of how many machines you have out there with a code 13? And they are all different.
U need to stop wasting others time and be specific with your inquiry.
Mar 10, 2016 | Washing Machines
2000 Buick Century. Put in a replacement radio/cd/casset player. Radio works, clock works, but CD and casset do not. The message comes up E 13. What does this e code mean?
if its a radio shack radio, it means E13 means "Tape Communication Error". It is caused by the
microprocessor reading speed pulses from the tape deck either too fast, most other makes mean about the same thing, normally a stuck tape will cause this code to show up, either that or the drive gear that loads and unloads the tape is broken, cracked, or jammed
Sep 26, 2011 | 2000 Buick Century
My riso ks 800 duplicator shows E13 Error code
my riso ks 800 duplicator show error code E3
Apr 14, 2011 | Office Equipment & Supplies
What dose e13 means
error, code 13 for service man
Oct 04, 2009 | Black & Decker Heating & Cooling
Have a mpi monitor flashing a e13 code
I have a propane monitor heater just installed 2 months ago and I get an e 13 code and the heater won't stay on???
Oct 19, 2008 | Rinnai Toyostove Direct Vent Heater: Laser...
Just moved
E13 code means Pressure switch Fault
To check :- Remove Plug First ( Remember Safety First )
The pressure switch is at the top, its move likely to be a blocked pressure bottle, which is under neath the tub accessed via the rear bottom access panel 3 to 4 screws. the bottle is on the side of the filter with a small clear tube going up to the pressure switch. Clean this bottle out.
E19 code means Power Failure during Programme
Mar 10, 2008 | Hotpoint WMA64 Front Load Washer
Bosch 3.81 cu ft WFMC530 1UC Nexxt 500 Plus Series Washer Logo
1,526 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Marvin
Marvin
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
