Question about ASUS P4B266 Motherboard
P4 comp not booting up
I had this comp from my son, built it for him 2-3 yrs back. since about 3 mths it would not boot up always. few days ago it would not boot up, not even to bios. no beeps nothing. when i disconnected power it would sometimes boot. i tried diff ps, video card, reinserted memory. yesterday i checked the bios batt and it was dead. put brand new lithium, today it is almost discharged. the only way to boot is to remove/reinsert the cpu (p4 3.06) and than it goes to bios setup. it quit while it was working for no reason, when removing cpu it will go to setuo, cpu speed must be chosen. when its running it is all ok as if nothing was wrong. any ideas? thanks
Bogdan
  • 1 more comment
  • krzemb Feb 14, 2008
    it is the P4T533 C mobo
  • krzemb Feb 15, 2008
    it will boot only if i take out the processor and reinsert it. it will boot to bios, i have to set the right processor speed, save to bios and than it works fine for about 10 minutes. it than just quits and have to start the whole process over. i do not have the same processor and memory, do not want buy as I can not use it later. tried different p/s, video - no change.
  • Gus1966 Feb 23, 2008
    My problem is similar, it gets past the bios, but when it's time for Windows XP Pro to start - it just sits there with a black screen... nothing. I aslo have an Asus P4B266 with 1 gig of RAM. I've removed all PCI cards and RAM and reinstalled them one by one to see if there was a bad componant, but nothing worked.
    Problem Solver:
  • 24 Answers
Get working processor like that of your son's system and working ram, remove both the processor and ram on the system and substitute with the new ones and try booting.
Uzowuanya
e-mail:uzowuanya@yahoo.ca
Posted on Feb 15, 2008
  • 1 more comment
  • IKECHUKWU EKWEKE Feb 15, 2008
    since it could try booting when power cable is disconnected, i think your processor is having problem.
    try.
How do i reset my 2g surf back to factory settings
You can download a windows password reset tool and create a windows password reset disk with it. Few days ago I downloaded a program named Windows Password Reset 9.0 and I successfully reset the forgotten password with the disk.
Oct 19, 2010 | ASUS Computers & Internet
My PC with 865PE Neo2-FIS2R doesn't boot on SATA HDD... It actually runs windows server 2000. but after an unexpected power shutdown... the pc always boot on Managed PC Boot... upon checking on the Boot...
Hi Good day!! well i think your board didn't detect your HDD for some reason:
1. unexpected shutdown
2. cable not properly connect in HDD to motherboard
3. HDD have been damage because of improper shutdown.
here are the step to detect your HDD
1.pull out your cable from the HDD and then re-insert it make sure it its inserted properly.
2.go to CMOS and then in the "MAIN menu" check the primary master, primary slave, etc. in the primary master your HDD should be detect there. if not enter your primary master for auto detecting.
if nothing happens and still not detected you must replace the cable of your HDD.
Pls. Reply to help you more
Regards
JR
Oct 07, 2010 | MSI 865PE Neo2-FIS2R (MS-6728-030)...
When i try to boot my toshiba a75 laptop i receive a boot last good ... it won't boot i removed memory module i installed 2 yrs ago and it boots ... i purchased new memory module and get same error- it...
Below are the specs to the type of memory that can be installed in the A75...it is very specific and cannot be anything else then what is listed. You have 512 mb built onto the motherboard, with one expansion slot. That slot can only hold up to 1 gb stick if the BIOS has been upgraded. Go to Toshiba support and make sure the BIOS on the machine is up to date so it will accept the larger stick of ram memory and make sure all the specs are right on the stick that you have.
Each memory slot can hold DDR PC2700 with a maximum of 1GB per slot.*
  • Maximum Memory: 1536MB
  • Slots: 1 (1 bank of 1)
  • Standard Memory: 512, 768, or 1024MB (512MB non-removable)
  • USB Support: 2.x Compliant
  • Oct 20, 2009 | Toshiba Satellite A75-S231 Notebook
    BLUE SCREEN
    is what happen to your laptop is lower specs i thought..so you need to re-install the windows comptaible to your laptop and meet the specs...but before you do that you need to back up 1st your important files..
    Mar 12, 2009 | Compaq Computers & Internet
    Problems with my mother!
    PUT YOUR OLD COMP BACK THE WAY IT WAS .IF IT BOOTS AS ALWAYS,GO TO CONTROL PANEL.SELECT "SYSTEM",SELECT DEVICE MGR,SELECT DISK DRIVES.RIGHT CLICK ON YOUR SLAVE,SELECT UNINSTALL,FOLLOW INSTRUCTS.TURN OFF COMP AND REMOVE YOUR SLAVE.REBOOT.HOPE IT WORKS FOR YOU!
    BUME
    Mar 07, 2009 | Intel D865GLC Motherboard
    HD installed with XP in Giga MB,not booting up in the originalP3
    it is impossible or else you reload the hd on the motherboard
    Jan 21, 2009 | Computers & Internet
    Star sight demo
    My son in law told me to go into the menu and turn off auto demo, I found it and did. I have no idea how it turned on though.
    Thanks for the inquiry!!!
    Nov 06, 2008 | Zenith Televison & Video
    MEDION MD40954 boot problem-freezes
    First think You should Do is Look at the Fans and Heatsink Blades... They Could Be Clogged.... Or a Dust/Hair Ball can be stick in the fan chamber... Use Forced Air To Blow Out .. (make sure you're not blowing it further into the laptop though)
    You Might need to remove the underside of the case to access these parts... Also Take the Memory out and reseat it back in place... Pull the hard drive and Reseat that as well...... after all that... reattempt a boot.....
    if still messed up... try booting into Safe mode by pressing F8 upon boot and choose the first choice to boot in Safe Mode.
    there you can run checkdisk and/or troubleshoot further..
    http://www.wnycomputerpro.com
    Jun 11, 2008 | Medion MD-40954 Notebook
    Hard Disk and Booting issue
    go into your BIOS and on the bottom of your screen there should be a (last good config) of (fail-safe config) value for one or=f the F1 to F12 buttons. also. are you running a 4gb hdd??? or is that a typo? anyhow, XP REQUIRES 2GB at all times free if your hdd is running at less that that (cause its full) your boot up could be messed around. finally make sure that the little plug on your hdd is across the Master or cable select pins not the slave as this can cause probs too. good luck.
    Sep 22, 2007 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
    ASUS P4B266 Motherboard Logo
    96 people viewed this question
    Top ASUS Computers & Internet Experts
    Alun Cox
    David
    David
    Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
