Question about Motorola Talkabout T5500 (7 Channels) 2-Way Radio
They just don't seem to work!
The all settings are the same and when pushing PTT or pushing the call button the other radio does not respond.  Either radio in the sequence.
  • titans13 Mar 07, 2008
    I have the exact same issue...not sure how to make them talk.
I have a new pair of 5500. It seems not working, but I discover that using channel 1 in one and channel 2 in the other they work, the same if using channel 2 in one I have to select 3 in the other, it is like a frecuency error. Maybe is the same with yours.
Posted on Mar 28, 2008
I had the same problem, I solved it my holding down the PTT button on one and the scan option on the other. It seems that the channel indications are faulty and and Channel 1 on one matches with Channel 15 on the other and so on. But once this was sorted the units work fine.
Posted on Apr 27, 2008
PTT button on RDV 2020 is hard to push
This problem is typically caused by small component behind the PTT button being cracked or broken. The RDX series radios respond best if the user presses the PTT button in the center versus the top or bottom sections of the button. Once the button becomes hard to press it is best to get the radio repaired. Commonly if the radio remains in use the PTT issue will get worse as the internal PTT component is pressed harder, pushing it further away from the outside button and eventually loosening it from the component board.
Best regards.
Apr 18, 2014 | Motorola RDV2020 Two Way Radio2 VHF 5...
Puxing PX-777 PTT problem
It sounds like a PTT fault as presumably the headset has its own
ptt?
Try a reset?
Jan 25, 2014 | Radio Communications
Shuts off immediatley after pushing PTT button
sounds like your batteries are shot and not able to supply enough power for transmit
Jan 10, 2014 | Motorola Walkie Talkie 2-Way Radio
Setting of PTT ON
Improve the FixYa experience for everyone by voting.
Unfortunately, you haven't provided a model for your Nokia and I don't understand the nature of your problem. The best that I can do is offer you a definition of PTT:
Push to talk (PTT). Push to talk (PTT) functions as a two-way radio. The PTT option is available only if enabled by the service provider.
I have no personal interest or association with any product that I may suggest.
May 18, 2012 | Nokia Cell Phones
My magone BPR40 radio isn't sending when PTT is pushed. It is receiving fine. Any suggestions?
A couple of thoughts:
1) Check the mic hole and see if it is covered or clogged with debris.
2) Does your PTT button seem hard or the opposite, mushy? You could have an internal PTT issue. The PTT is a common failure part on 2-way radios. Feel around for the 'sweet' spot and see if you can make a simple or partial transmission, or if it will even momentarily open up the receiver on the other unit. If so, your radio is in need of repair. It would likely need a new internal PTT. (At most repair centers where the BPR40 is repaired the flat rate repair currently are around $69 for the BPR40)
3) Has any reprogramming been recently done on the radio? If so, double check the programming to be sure your PL/DPL code is set the same as your other radio.\
4) Check your battery. Trade batteries with the other unit and see if the problem changes. It takes more energy to transmit than to receive.
Best regards.
Jun 15, 2011 | Motorola Mag One BPR40 Two Way Radio
I have old motorola talkabouts..and don't remember to change the channel. can you help? They are Yellow and have no screen on them...I can't find any model number on them. the date is Dec 1998 it...
Hold the push to talk(PTT) button while turning the unit on, it will talk to you. press PTT to change channel, push monitor to switch to codes, press PTT to change codes. When you have the correct settings press monitor and it will confirm settings.
Jun 13, 2011 | Motorola Talkabout FRS 250 (14 Channels)...
When I turn on the radio the indicator light on the top of the unit just flashes. I cannot set the frequency or code. When I push the monitor button I hear static but otherwise the radio is dead.
The flashing light can be an indication there is activity on the frequency the radio is set to. Pressing the monitor button should give you the white noise (static) sound, so this function is working correctly. This also tells us your speaker is working fine, as well as your volume. The typical reason you cannot go into programming mode (when you hold the PTT in while turning on the radio and hear the female voice announce your frequency) is a bad or moved internal PTT switch. This typically happens over time as a user presses ever harder on the PTT to communicate. However, this does not explain why you are not receiving. This could simply be a result of an incorrect PL code in conjunction with the bad PTT. If you have a frame removal tool, you can extract the component board and physically look at the internal PTT. You can then hold in the very small button and program the radio to the frequency/PL you desire. If you are needing the radio repaired, you can get this style unit repaired for around $69 flat rate
Jul 16, 2009 | Motorola MU24CVS UHF (4 Channels) 2-Way...
CLS 1110 Programming
Not certain what order you are doing it, so I will type a brief explanation:
With the radio turned OFF, hold in the PTT and the MON, while turning the radio on. Continue to hold the PTT and MON until the radio stops making noise. You are then in programming mode and can use the menu button to walk through the stages of programming.
Mar 23, 2009 | Motorola CLS 1110 (1 Channel) 2-Way Radio
One way comm only
swap batteries if does not work this unit should need repair or replace, display blinking can be produced for power failure ( battery, contacts, circuits) or can be a controller issue.
Feb 07, 2008 | Motorola Talkabout T5500 (7 Channels)...
Squelch when keying ptt
I would check my ptt wiring making sure the button is set so that when you push it it switches you from RX to TX. If you have a wiring diagram that would be helpful if not are you able to get one? In any event make sure the wires are not misconnected.
Sep 12, 2007 | Maxon MCB-40 40-Channels Handheld CB Radio
Motorola Talkabout T5500 (7 Channels) 2-Way Radio Logo
128 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
