You have to press the STORE button. Also, this will only save to the preset you're on and has no effect on other presets. So if you're on preset 1 and you disable EQ then press STORE you've only turned it off for that preset. #2, 3, etc. will still be enabled.
After you press STORE will show you something like this:
STORE: ROCK VENUE
Replacing
U1 DJ Setup
PRESS STORE TO ADVANCE
Rotate the DATA whell to select the program to be replaced and press STORE. The existing program (the one that had EQ turned on) will be replaced with the new program (the EQ turned off). If, for example, you do this to preset 1, now every time you dial to 1 you'll have the same, no EQ setting.
I think the auto focus is not working
