Question about Hamilton Beach BrewStation 47214 Coffee Maker
Brewstation The machine is dispensing coffee slowly. I have cleaned the coffee maker with a vinegar solution but I'm not sure the best way to clean out the dispenser so it dispenses more quickly
  • winemom Mar 08, 2008
    Acutally I figured out yesterday that it was the screen and did exactly as you said and used a toothbrush to clean it out. I did soak the screen in vinegar for a while first but it probably didn't make any difference. Now it works great. Thanks.
  • Anonymous Mar 24, 2014
    It has been cleaned with vinegar and cleaned the kcup
There is a very fine screen on the outlet of the carafe that becomes plugged over time with fine coffee grounds. You can see it if you look down inside the pot above where the coffee comes out. Just using coffee pot cleaner won't clean it, because it's fine coffee grounds stuck in the screen, that are slowing the coffee going through it.
It's not easy to reach, so you'll a pair of needle nose pliers. Get ahold of the plastic ridge the runs across the top of it and it pops right out. You can use the bristles of an old toothbrush to scrub it. The bristles will fit in the spaces of the fine screen and force the deposits out. You can probably just leave the screen out altogether, it's just there to stop grounds.
Posted on Mar 08, 2008
  • B Valley Mar 08, 2008
    Vinegar won't touch the deposits on that plastic. Get some commercial coffee pot cleaner, and either run it through the entire cycle, or just put the cleaner in the tank and run water through the rest. The hot water is deposited in the tank and mixes with the cleaner. Denture cleaning tablets will work as well.
  • 2,039 Answers
Vinegar is not bad the best is descaler product vinrgar remove calcium in piece sometime block other area of the machine descaler melt calcium you use 1part descaler 1 part water fill the water container start machine when empty rinse 2 or 3 time with water thanks for using fixya pierre
Posted on Feb 14, 2008
Hamilton Beach BrewStation 12 cup Coffee Maker, coffee leaks into the bottom water reservoir after brewing.
there is a small rubber flap valve in the tank. if you carefully clean that on a regular basis your problem should end.
Dec 26, 2011 | Hamilton Beach BrewStation
How to clean Brew Station
Remove the water filter, if you have one. Pour 2 cups of vinegar into the water reservoir. Turn on, wait 20 seconds, and turn off. Leave for 30 minutes. Then turn on, and turn off when finished. After it has cooled, dispense several cups, then empty and rinse the reservoir. Run two or three more cycles with (clean) water only, allowing to cool between the cycles.
Mar 17, 2011 | Hamilton Beach BrewStation 47214 Coffee...
I love the coffeemaker but after a couple of months the flow is so slow>
put bicarbonate soda salt and vinegar in the water unit and make sure you give it a good clean i could instuct u to use drain cleaner but you might die lol nah only kidding soda salt and vinegar are what is used to clean drains and pipes all u can do is try cant hurt but make sure flush the machine
also have you been flushing it after every use if not theres your problem
Mar 11, 2011 | Hamilton Beach BrewStation 47214 Coffee...
Is there a replacement part for the (HB Brewstation model 47665) tank? It's barely a year old, and the tank has a tiny crack (at one of the screws at the hot plate) and leftover coffee spills all over the...
Desiree, I just had a problem with my 3 yr old Brewstation 47665. There is a limited warranty (1 yr) for the model. Call Customer Service and I am sure they can help you. You can find the number on their website. In my case, I would have to buy a new tank for $14.00 plus state tax. $14 is a lot better than $60. The coffee was dispensing extremely slowly and there is no way to remove the parts to clean. I didn't want to part with this coffeemaker, I LOVE IT!
Jul 02, 2010 | Hamilton Beach BrewStation 47665
Brew station is extremely slow, suspect it needs cleaning.
You can run a cup of vinegar through the machine. Run it just as you would making coffee, except without the coffee. Run water through the cycle at least twice to remove sediment and the vinegar. Works like a charm.
Jun 16, 2010 | Hamilton Beach BrewStation Deluxe 47474...
Why does unit fill cup very slowly when the inside filter appears clean.
mix half white vinegar and water together...then pour this solution in just as you would if you were making coffe....minus the coffe grounds of course... then run it through a cycle and then run clear water through again... and you will be good to go...do this once a month or so to keep it working great...
heatman101
May 06, 2010 | Hamilton Beach BrewStation 47214 Coffee...
Keeps flashing CLN after cleaning
i had this problem
if u have hard water and do a fresh clean but it dosnt clean it well then it will flash clean time time again
best soultion to clean if u havnt tried it is
Pure Vinegar white..
run through 2 times then clean with water 2 times then ur problem surely will be fixed .. if not hit me up
at
peterjw@bell.net
and ill have more information for you..
best luck
Oct 26, 2009 | Hamilton Beach BrewStation 47224 Coffee...
I lost the cleaning instructions and cannot remember how much vinegar to use and for how long I notice a leak this morning when i made coffee and thought it was because it had not been cleaned in a while.
Depending on how much calcium build up is in the coffee brewer, it may take a teaspoon or half a cup. The vinegar won't hurt the machine...it just takes a long time to rinse out. Hope this helps. m
Oct 20, 2009 | Hamilton Beach BrewStation 47214 Coffee...
My coffee maker works very slowly after about three weeks of use. Specifically, the water does not pass through the filter and into the pot quickly, if at all. Suggestions?
Try cleaning it with white vinegar. Put in one cup with a potful of water, and let it soak. To get more cleaning, pour the water/vinegar through again, hot. Put in a coffee filter to catch/strain the debris, and you will be able to see if it's helping. When you're through cleaning, pass fresh water through the machine by potfuls, until no traces of vinegar can be detected.
Best regards, --W/D--
Aug 15, 2009 | Mr. Coffee 072179228578 12 Cup Coffee...
Stopped up
I took a small tooth brush and brushed the screen from the inside of the pot. That cleaned it right up and I now have a full stream, dispensing.
May 12, 2009 | Hamilton Beach BrewStation 47224 Coffee...
Hamilton Beach BrewStation 47214 Coffee Maker Logo
866 people viewed this question
Top Hamilton Beach Coffee Makers & Espresso Machines Experts
jason
Greg Cann
Greg Cann
Are you a Hamilton Beach Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
