Question about Radio Communications
BMW 528i AM Radio Reception Problem
AM reception extremely poor, (FM OK) would a motor drive ariel help ? instead of the embedded ariel in the rear window ?
If I replace the whole radio using an adapter plate to fill in the large hole , can I still use the original speakers ?
  • 105 Answers
An external antenna will make an improvement over the embedded one. The longer, the better.
You can re-use the original speakers & wiring for an after market setup. You should obtain a Haynes service manual for your car, as it has the wiring diagram for the factory radio, including color codes of the wiring. You will need this info to re-use the factory speakers & wiring.
Posted on Feb 17, 2008
Very poor FM receptio, and virtually no AM reception
The cascadia has an integrated AM-FM-WX, XM?, and CB antenna system, that is also prone to poor grounding. The best solution is to install aftermarket antenna systems for all of the equipment... I am driving a 2013 Cascadia with quite poor FM, and non existant AM, and WX reception. The XM works. I am afraid to hook up my CB to this, as it is pushing too much power, and is a sideband unit. I would like to hang the engineer by his/her toenails from the nearest tree for comming up with this garbage...
Mar 24, 2012 | Panasonic Car radio CD CQ-C1110GN CD...
Buzzing sound on radio when putting on rear defroster
One of the problems with AM reception iam afraid but here i suspect that the aerial mounting isnt earthing properly thus causing the AM reception to be susceptable to interference
Feb 15, 2012 | 2001 BMW 330
The FM radio reception went out. AM radio reception is still ok. What should I look for to fix the loss of FM radio reception?
Pull radio and check antenna plug in rear of radio, They'll still pull AM with antenna unplugged
Apr 03, 2011 | 2005 Chrysler 300
RDS reception with BMW Business radio
Well i remember the M25 being built so i wouldnt know about radio reception ,but i do remember radio london and caroline.Now i would imagine that this sort of auto reset of tuning reception is controled by a micro chip and this chip is now not working as it should so if you want it to work then its most likely cheaper to install a new radio.Or just use long wave for radio 4.
Jul 16, 2010 | 2000 BMW 3 Series
FM reception for Sony ICF-CD513?
The electrical cord acts as an antennae for this radio. Uncoiling the cord will give the best reception for FM. Rotating the radio (and built in ferrite bar antennae) will give the best reception for AM listening.
Jan 31, 2010 | Sony ICF-CD513 Clock Radio
Poor radio reception with Jensen VM9512 in 2001 Nissan Altima
If you used the 2 plug nissan radio harness, there should be a blue wire on there which is the (power antenna) even if your car doesn't have a power antenna, this wire needs to be connect to power on the am/fm amplified ant which is used in many nissan cars.
if the jensen has a blue or a blue/white wire, connect it to one of those. if not, you can always connect it to the red ACC wire. that should solve your reception problem..
hope this helps
Aug 25, 2009 | Audiovox VM9512 Car DVD Player
!994 Park Avenue FM radio reception poor. AM signal OK
Check antenna connections at radio and antenna assy.. Poor connections will only receive AM and hardly any FM
Apr 06, 2009 | 1994 Buick LeSabre
No am reception and poor fm reception - 2004 Kia Sedona
If the antenna is on the front, pop the hood, and locate where the antenna wire connects to the bottom of the antenna and make sure it is connected well. If everything checks out there, you will have to pull the radio from the dash, and look at the back of it. There will be a large black wire by itself connected to the radio. Push it in to make sure its connected as well. That could really be your only problem unless your radio happens to have a fault on the inside which is extremely rare. Hope that helps
Mar 15, 2009 | 2004 Kia Sedona
JVC detachable face with auxillary input
You may have a bad antenna or antenna cable.
FM signals are measured in microvolts and are easily influenced by poor antennas or a mashed antenna cable.
Aug 12, 2008 | JVC AM FM CD DET FACE CAR STEREO
Radio Communications Logo
255 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Marvin
Marvin
Are you a Radio Communication Expert? Answer questions, earn points and help others
