Epson CX8400 All-In-One InkJet Printer Logo
Posted on Jan 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Replaced ink cartridges and still getting error c69
Anonymous
Level 3:
  • Master 677 Answers
  • Posted on Jan 23, 2010
Anonymous
Master
Level 3:
Answers
677
Questions
0
Helped
239336
Points
1685
When I was having problems with my Epson, and was costing me too much for the cleaning, Wow Costly,,,,,,,,,,,,decided, to replace the printer.
Found Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate.
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
U162 error on black ink cannon printer
This error occurs when printer fails detecting ink level or printer assume that no ink in the cartridge. We cannot use print, copy,scan, and fax function before the problem fixed. It's recommended for you to replace ink cartridge. To continue using the printer without replacing the cartridge we must deactivate ink level detection function. Be aware that printing in this condition can damage the printer while sending fax or scan is not problem.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Original source: http://ij-forum.blogspot.com/2008/12/error-message-check-ink-u162u163.html#ixzz2Cpr4Be1K
1helpful
New ink cartridge and still getting error UO41
Error U041 is strictly a low ink error message, so it's strange that replacing the ink would not resolve it. Make sure the ink cartridges are inserted properly and the protective tape has been removed from the cartridge. If not, there might be an issue with the ink cartridges not being locked in place.
3answers
Hello I have replaced ink to the printer and i have this error num 10000160 do you have solution to this problem. I try to reset without results. Itzik
Many of the Epson printers ink cartridges have a sensor thatallows the printer and the associated software knows when to replace theprinter ink cartridges (even when the cartridges have ink within them) and whenthe printer needs to be cleaned. You mayreceive error messages if that sensor is faulty. In that case you shouldreplace that sensor. Hope this will help you. Good Luck.
I keep getting a cartridge error message. I have replace the ink cartridges but still have the error.
Are you using Dell Series 11 ink cartridges?
Open the printer with the power on and remove the Dell Series 11 black ink cartridge and make sure the tape is off the cartridge, then reseat the cartridge back in. Now do the same for the Dell Series 11 color cartridge. Now when you close the printer, it should print an alignment page. Any error messages?
Black = Black side(left side) Color = Color side(right side)
Photo = Black side(left side) Color = Color side(right side)
Dell Series 11 ink cartridges have a sensor in them that cannot be reset. Article on refilling Dell ink cartridges.
Dell Series 11 ink cartridges can be purchased at Staples, Walmart or Dell's Website.
It possible to get a Dell Series 11 Cartridge with a bad sensor. Take back to place of purchase for a replacement.
Rick
Cartridge Error # 1203 when replacing black ink cartridge
It sounds like the printer thinks it is not a genuine ink cartridge. Fit a Lexmark cartridge to cure it.
Getting error, "cartridge error" 50C. Dell All-in-one printer, model A940
Hi there Error 50c
Yes this allways happens.
Regarding the Dell A940 "Error 50c"....the user guide doesn't seem to mention "Error 50c". They do, however, mention a "Cartridge Error" on page 52 of the manual. They claim this means that the printer has detected a short circuit (fuse/resister) in the cartridge. As you may or may not have noticed in the manual, this is what they recommend doing about it:
1) Press Power to turn the printer off.
2) Lift the printer cover/lid (scanner unit) until the scanner support holds it open.
3) Turn the printer on.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
4) Remove the color ink cartridge.
5) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the black cartridge with a new black cartridge.
If the error message does not display, repeat steps 1–3 and then go to step 6.
6) Reinstall the color cartridge and remove the black ink cartridge.
7) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the color cartridge with a new
color cartridge.
If there is no error message (indicated by flashing lights), repeat steps 1–3 and then reinstall both ink cartridges.
8) Lower the printer (scanner unit) until it is completely closed.
If you get the error message again, while both cartridges are installed, replace both of the cartridges.
Basically, what they want you to determine is,....if the short circuit is with the "black ink" cartridge or the "color ink" cartridge and then replace the cartridge that has the problem.
You may have to buy a new cartrige.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
6helpful
2answers
Epson rx680
one ink cartridge is out of ink but...
when we try to replace one of the color ink cartridges we get this error message:
ink cartridges cannot be recognized. make sure ink cartridges are installed correctly - how do I get the printer to recognize my full ink cartridge?
5helpful
I changed the ink error c69 shows up
This printer will not work if any of the cartridges are empty. I got the C69 and epson support told me I have to replace the Blue Ink Cartridge as well.
I think this is why the printer was so inexpensive.
1helpful
I Filled Kodak ESP5 Ink Cartridge, but error remains
Try to reseat the cartridge 2-3 times. probably the carrtidge is defective. call kodak @ 1800 421 6699 and they will replace the cartridge for you free of cost.
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
