Question about Toshiba MV13L3 13 in. TV/VCR Combo
I need remote control code for above
  • 1 more comment
  • Anonymous Apr 06, 2008
    OLD REMOTE STOPPED WORKING / BOUGHT A NEW UNIVERSAL REMOTE AND NEED A REMOTE CONTROL FOR THIS TOSHIBA
    PLEASE HELP
  • judW Apr 22, 2008
    Toshiba model MV13L3 remote also no longer works.
  • Anonymous Oct 01, 2008
    bought a universal remote can't find right code
5 Suggested Answers
SOURCE: Toshiba MD13N3 13 in. TV/DVD Combo Troubleshooting
031 030 007 just do a search in google
Posted on Jul 27, 2007
  • 56 Answers
SOURCE: toshiba 13' tv dvd combo, Fios remote control need code
Greetings!
Here are the codes: take a deep breath:
0181, 1283, 0183, 1292, 0087, 0677, 0859, 0872, 1183, 1383, 1683, 1731
You may find that these don't work. Often, with combination pieces like yours, you will find you are lucky if you can get a universal remote to turn it on and change the volume and little more. The fact that Toshiba did not build this peice can compound the problem. My suggestion, if you can't get the universal to program up, is to use the original remote for the set. If you do not have the original remote it is available from www.encompassparts.com for around $15.00 plus shipping. The original part number for the Toshiba remote is 72796929.
Rob
Posted on Jan 14, 2009
  • 21 Answers
SOURCE: Timer VCR Recording for a Toshiba MV13M2 13 in. TV/VCR Combo
Hello, you can go to the toshiba web site and download the manual from there.
The other option is to go into the TV menu, and select the timer rec set selection and access it there and fill in the times for the program you want to recording and that should do it.
I hope tihs helps.
BWLY
Posted on Jan 23, 2009
PABLOCSA
  • 1124 Answers
SOURCE: Universal Remote Codes
Try, 0045, 0043, 0845 or 0154, 0156, 0060
Posted on Feb 03, 2009
I need help with codes for a toshiba tv with built in dvd & vcr,i have a espn gamechanger remote
Your remote is programmable so you can use its "code search" function to seek a suitable code or codes to control your Toshiba combo. If a search through all available codes produces no result, you may have to try another programmable remote. Not all programmable remotes store the same codes.
Oct 01, 2014 | Time ESPN College GameDay GameChanger 0000...
Need to program a symphonic tv with a oneforall remote urc-4021boo
Hello
Setup codes for Symphonic TV with One for all URC 4021 remote control are:
0180, 0171
The One For All 3 Device Universal Remote Control is preprogrammed at
the factory to operate an RCA TV, a Toshiba DVD player, and a Motorola
cable box.To control devices other than the default brands,perform the following
steps; otherwise skip this section:
[1] Turn on a desired device (e.g.,VCR or DVD player) and, if
applicable, insert media (e.g., cassette or disc).
NOTE: Please read steps 2 through 4 completely before proceeding.
Highlight or write down the codes and device you wish to program
before starting step 2.
[2] On the remote control,press a device key once (i.e., DVD/VCR,
CBL/SAT,or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo,
or TV/VCR/DVD Player Combo press DVD/VCR once.After programming
a VCR Combo device, you will be able to control channel selection,
volume, and VCR functions.
NOTE: To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD/VCR once.After programming
a DVD Combo device, you will be able to control channel
selection, volume, and DVD functions.
NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
[3] Press and hold SET until the LED (red light) blinks twice,
then release SET.
Use the Manufacturer's Codes (starting on page 18) to
locate the type of device and brand name and then enter
the first four-digit code for your device. If performed correctly,
the LED will blink twice.
NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter
the same code again.
[5] Aim the remote control at the device and press POWER
once.The device should turn off. If it does not, repeat
steps 2 through 5, trying each code for your brand until
you find one that works. If it still doesn't work, try
Searching For Your Code on next page.
NOTE: If the device does not have a POWER key, press PLAY
OK
Jul 26, 2011 | One For All URC-4021 Remote Control
Need instructions and codes for toshiba t.v.
Hello
Codes for Toshiba TV with One for all URC 4220 are:
0060, 0154, 0156, 1265
applicable, insertmedia (e.g., cassette or disc).
[2] On the remote control,press a device key once (i.e., VCR/PVR,
DVD,CBL/SAT,or TV).
or TV/VCR/DVD Player Combo press VCR/PVR once.After programming
volume,andVCR functions.
Combo, or TV/DVD Player Combo, press DVD once.After programming
a DVD Combo device, you will be able to control channel selection,
then release SET.
[4]Use the Manufacturer's Codes to
the same code again
[5] Aimthe remote control at the device and press POWER
OK.
Jul 03, 2011 | One For All URC4220 Remote Control
I need code for URC-3220 Universal remote control for toshiba tv/vcr in one.
I can help you reprogram your URC-3220 Universal Remote for your Toshiba TV/VCR Combo.
The Toshiba TV/VCR Combo codes are 1145 & 0845.
Please review my Fixya Tip posts for:
TV/VCR/DVD Combo Codes
Searching for the proper codes, or
Downloading the URC-3220 users manual / owners guide.
I hope that helps.
Apr 07, 2010 | Universal Remote Control Remote Control
Need programing codes to run my cble, vcr, and dvd players using my toshiba tv remote model #ct-90159
What is the brand of your VCR?
If you using Panasonic VCR on this TV, the code are : 14 or 51 and or 59. Try one by one the code above until the vcr work on your TV.
How to do?
1. Press the code button
2. Press the 2 digits code
warm regards, Jay
Nov 22, 2009 | Toshiba CT-90159 Remote Control
Feb 03, 2009 | Toshiba MW27FN1 27 in. TV/VCR/DVD Combo
Universal remote control codes for toshiba t.v. amd syphonic vcr
have a jensen universal remote need codes for toshiba tv vcr combo lost book.
Jan 19, 2009 | Directed 434MHZ Remote Control
Big Easy programming
TV Toshiba 0154 0156 0060 1256PROGRAMMING
TV/VCR COMBO CONTROL
Perform the following instructions to
control a TV/VCR Combo:
1. Turn on the TV/VCR Combo and
insert a video cassette.
NOTE: Please read steps 2-4 completely
before proceeding.Highlight or write down
before moving on to step 2.
2. On the remote control,press VCR/DVD.
blinks twice, then release SET.
3. Use the Setup Codes For TV/VCR
Combos (on the back side) to locate
the brand name and then enter the
If performed correctly, the LED will
blink twice.
NOTE: If the LED did not blink twice, then
repeat steps 2 through 3 and try entering
4. Aim the remote control at the device
and press POWER once. It should turn
off. If the device does not respond,
repeat steps 2-3, trying each code for
your brand until you find one that
works. If it still does not work, try
Searching For Your Code.
POWER key, press the (PLAY) key.
hope that helps
Jun 26, 2008 | One For All URC-3300 Remote Control
NEED CODE FOR TOSHIBA TV
Codes for Toshiba TV.... 159,178,109,120,181,105,049,095,170,260,358,394,902,012,095,117 and 141
Nov 29, 2007 | GE JASRM24912 Remote Control
Toshiba MV13L3 13 in. TV/VCR Combo Logo
234 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
