Question about Panasonic PT-47WX49 47" Rear Projection Television
Resistors I replaced my stk392-110 on myT.V. The reason why I replaced it is because my T.V. would come on and go off. It had 3 blinking lights. Now I need to replace my resistors. When I did replace thestk392-110 that did not help. So now they are saying that I need the resistors replaced.When I look in the tv the part # is R7060 and R7066. I need the location or the value.
  • Panasonic Master
  • 8,617 Answers
R7060 and R7066 are both 0.27 ohm 1 watt flameproof resistors 5% tolerance.
Posted on Feb 14, 2008
Panasonic 51'' HDTV Model PT51HX42F - Turns off, light blinks 3 times, pauses, blinks 3 times again, etc.
the 3 blinks is caused by convergence failure indicating the Convergence ICs and resistors need replacement. You can get the convergence repair kit for your model at www.tvrepairworld.com the kit contains the ICs and resistors and also has the CD that shows how to do the repair.
Jul 28, 2012 | Panasonic PT-51HX42 51" Rear Projection...
TV comes on for 3-4 seconds and then turns off. The power light then blinks 3 times and then pauses, then 3 more blinks ans pauses.
3 blinks is short protection and 98% chance one of the resistors in the convergence circuit is gone.
I can tell you what to look for and if confirmed how to fix set. If the usual problem total parts cost on EBAY will be well under 25 dollars.
If one of the resistors is bad, I have step by step start to finish instructions I can provide for this repair, for most it is a do it yourself job.
If you have questions let me know.
Regards, SD TECH
Nov 03, 2010 | Panasonic PT-53WX53 53" Rear Projection...
PT-53WX53G still shutting off-3 blinks
have you checked the 2.2 ohm 2watt resistors? If the led blinks three times the resistors will almost always have at least one that will be blown and need replacement.
Jul 27, 2010 | Panasonic PT-53WX53 53" Rear Projection...
No picture & the red power light just blinks
If it shuts off and then the power light starts blinking red or never turns on but the power light blinks red continuously that is usually indicative of the convergence ICs (STK 392-110). You never want to replace the ICs without also replacing the resistors that are associated with them. There are usually 6 resistors, one for each of the colors and there corresponding direction, IE Red horizontal, red vertical, blue horizontal, ect. In the case of this model tv all of the resistors are 2.2 Ohm and 2watts. You will find them right where the STK 392-110 ICs are. Right in front of them. They are blue and have this color code on them: Red, red, gold, gold. These are represented by stripes on the resistors. You can get the parts from www.bdent.com They carry the ICs and the resistors. If you do not feel comfortable completing this repair I could do it for you if you send me the board. My email address is: missionelectronics@sbcglobal.net The cost is 375.00 and that includes all parts.
Good Luck.
Mar 08, 2009 | Toshiba TP43H95 43" Rear Projection...
Toshiba TP43H95 projection tv has power but no picture
If it shuts off and then the power light starts blinking red or it never comes on but the power light just blinks red continuously that is usually indicative of the convergence ICs (STK 392-110). You never want to replace the ICs without also replacing the resistors that are associated with them. There are usually 6 resistors, one for each of the colors and there corresponding direction, IE Red horizontal, red vertical, blue horizontal, ect. In the case of this model tv all of the resistors are 2.2 Ohm and 2watts. You will find them right where the STK 392-110 ICs are. Right in front of them. They are blue and have this color code on them. Red, red, gold, gold. These are represented by stripes on the resistors. You can get the parts from www.bdent.com They carry the ICs and the resistors. If you do not feel comfortable completing this repair I could do it for you if you send me the board. My email address is: missionelectronics@sbcglobal.net The cost is 375.00 and that includes parts.
Good Luck.
Nov 03, 2008 | Toshiba TP43H95 43" Rear Projection...
CONVERCENCE PROBLEMS
did you replace the convergence resistors with the ICs? Often the resistors will need to be replaced also when new ICs are installed. 3 blinks means convergence Failure so its either the solder connections on the ICs or the resistors need replacement. If you need more assistance please let me know.
Sep 27, 2008 | Televison & Video
Failed resistor
those are the convergence feed resistors. # blinks on a panasonic means convergence IC failure. You will need to replace the two stk392-110 convergence ICs and the six resistors. You can get replacement ICs and resistors at the following link.
http://servicemanuals.vstore.ca/
Sep 06, 2008 | Panasonic PT-53TW53 53" Rear Projection...
PT-53WX56
yes the 3 blink error code means the convergence ics need replacment. very easy you need two stk392-110 ICs and six 2.2 ohm 2watt resistors very easy an inexspensive repair. you can get replacement ICs and resistors at the following link with free instalation instructions with pictures so you can do the repair yourself and save quite a bit as a repair shop usually charges between 4 and 600 dollars for the repair which takes about an hour. Heres the link.
Aug 05, 2008 | Panasonic PT-53WX53 53" Rear Projection...
The d4 light is flashing in myt 1996 honda accord and the car wont turn over??
HELP..HONDA ACCORD 2003 2.4 gear position indicator light is blinking ....rough idling,less power produce
Jul 23, 2008 | Honda Accord Cars & Trucks
Denon AVR-1601
This is a very common problem with denon receivers of the 2001-2-3 vintage. On almost every one, there are 4 little "surge" resistors in the power supply. These werent quite robust enough from the factory and one day would just burn open for no reason. Well, actually there is a reason, the "surge" that happens every time you power the unit up eventually weakens the resistors and then they pop. You need to take this to a denon service shop as I GUARANTEE they have seen this before. They need to check resistors in the picture, locarde above the **** rectangular connector. Resistors numbers R141, 142, 148, 149: 75f69d7.jpg These resistors when measured, should be less than 10 ohms each. If they are more, then they are blown. If they are blown, then have the shop check the channels for blown output transistors. If the outputs are OK, then these resistors should be replaced with 1 ohm 1/2 watt metal -film flameproof resistors. You might need to be prepared for a large bill, because the entire unit must come apart to replace the resistors, however, just checking them takes only about 10 minutes... Good luck and don't try this at home. Rob
Apr 08, 2008 | Denon AVR-1601 Receiver
Panasonic PT-47WX49 47" Rear Projection Television Logo
98 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
