Question about Apple iPod nano 3rd Generation
Ipod will not connect with ITunes
When I first got my ipod, it loaded into itunes no problem. Now, after it freezing while plugged into the computer (and me fixing it, according to answers from another one of these questions {thanks}) my itunes is not recognizing my ipod. What do I do from here?
  • Anonymous Mar 14, 2014
    itunes freezes when ipod is connected
  • 51 Answers
Okayy.This has happened to me too,firstly check you have the latest itunes software.
http://www.apple.com/downloads/
Surprisingly this can make a difference.
If nothing else works i would back up all music on a cd or memory stick,and reinstall itunes.from there everythings set as the default settings so if anything has been changed to cause itunes not recognising the ipod this may fix it.This is how i fixed mine.Hope this helps!
Posted on Feb 14, 2008
When i plug my ipod on to itunes it wont show up
Sometimes your iPod fails to display in iTunes, which will keep you from being able to transfer songs from your computer to your iPod. If this happens, there are a number of steps you can take to resolve the issue.
Is it the iPod? Your iPod could fail to show in iTunes for a variety of reasons and this issue can be resolved by something as simple as rebooting your iPod. To reboot your iPod, first lay it on a flat surface. Using your thumb and index finger, press the play and menu button at the same time. If done correctly, your iPod screen will go blank and then you'll see the Apple logo. Is it the USB cable? Your iPod could fail to show in iTunes if you are using a defective USB cable. Try connecting your iPod to another computer that has iTunes installed using the same USB cable. If iPod again fails to show in iTunes, replace the USB cable. Is it my computer? One of the most common reasons your iPod doesn't show in iTunes is because your computer doesn't recognize your iPod is connected. Troubleshooting your computer/iPod connection Disconnect your iPod from the computer and reconnect. If your iPod still doesn't appear in iTunes, disconnect your iPod and reboot your machine. Once your computer has restarted, reconnect the iPod. Is it iTunes? Your iPod could be fail to display in iTunes if there is a issue with your iTunes program. If there is a problem with iTunes you can try updating the software to the most recent version. If that doesn't resolve your problem, re-install iTunes. b> http://www.itunes.com/ b> http://www.apple.com/support b> iPod Won't Connect to iTunes b> Apple's iTunes software contains mechanisms specially designed to sync with your iPod, allowing you to transfer music, videos and other media from your computer. If you find that iTunes does not recognize or allow you to access your iPod, then you cannot perform some of the device's most fundamental functions. Fortunately you can often resolve this problem without expensive maintenance, simply by doing a bit of troubleshooting and determining the cause of your connectivity problem.
Try resetting your iPod. Apple recommends this as a first step in troubleshooting an iPod not appearing in iTunes, since a quick reset will often restore functionality. If you use a click wheel iPod, hold down the "Menu" and center buttons until the Apple logo appears on your screen. For the iPod Touch, hold your "Home" button and "Sleep" button simultaneously until the Apple logo appears. Charge your iPod battery. If your battery has absolutely no power left, your iPod will often remain unresponsive even when plugged into iTunes. Try charging for three to four hours and then try connecting again. Plug your iPod into your computer using a different USB port. Sometimes a failed connection can mean you have a faulty USB port, so try plugging your USB cable into a different port and see if the iPod appears in iTunes. Verify that you have the latest version of iTunes. Visit the iTunes page Apple.com and check to see the latest version available. If you do not know which version currently runs on your computer, click "About iTunes." For Mac users, this option will appear under 'iTunes" on your menu bar. For Windows users, the option will appear under "Help" on your menu bar. Download the latest version of iTunes if necessary. Reconfigure your iPod service. If running iTunes on a Windows computer, click "Start > My Computer > Manage," and select "Services and Applications." Under "Services," select "iPod Service" and click "Stop." Leave the window open and connect your iPod to your computer. When your iPod shows up on your computer, click "Start." Reinstall iTunes. If simply updating iTunes does not work, you may have defective software. Try removing the program from your computer and completely and reinstalling it.
Jan 29, 2013 | Apple iPod touch Second Gen (8 GB,...
My ipod wont show up on the bar when i plug it in the itunes
Itunes freezing when ipod is connected
Need to reformat your ipod - don't disconnect the ipod until you hit eject - ever you should be able to use it again try a different cord and reformat then have fun cause you get to reload all the music unless you were able to save your iTunes library
Jan 16, 2013 | Apple iPod classic MP3 Player
ITunes screen freezes on connecting the iPod. The ipod is not detected by iTunes even in disk mode. No menu of iTunes opens up when iPod is connected
if itunes is freezing when connecting the ipod then 1 of 2 things are happening
the ipod has an error on the disk and needs to be replaced or your anti- virus is going to scan your ipod for virus and can because its an ipod -
so test your ipod with another cpu that will tell you alot
if it freezes itunes on 2 different cpu then its the ipod -if it works fine then its your anti-virus - you need to disable or remove
norton is Nestorius for this
Jan 23, 2010 | Apple iPod nano
Ipod is disabled connect to itunes
Go on to itunes and plug your mp3 in to your computer
and download it and salect which tunes you want. If it dose not work
there is somethind wrong whith your mp3
Aug 19, 2009 | Apple iPod touch Second Gen (8 GB,...
I jus gotta new ipod nano 2gb, i plugged it into the comp and it shows apple sign then "do not disconnect". a auto play window opened and it appears in "my computer". i click on it and it shows three...
First, you should use itunes for you iPod. I know that there are other programs that can let you load music on it, but you should use iTune, Really.
1. You should first download iTunes. It is free.
2. Next. Load your music into iTunes. Do all of this BEFORE you plug your iPod into the computer.
3. Connect your iPod to the computer. Use a fast USB port. These are usually located on the back of the computer.
4. Your iPod should appear in the iTune pane on the left side. You should be able to see a set of 'tabs' that you can click. The first one is about your iPod.
5. At this point, you can click on the music tab to tell the computer to load what to load into the iPod. Click 'sync' to load your music.
6. When the syncing is complete, you will see that notice above in iTunes. Click the arrow next to the iPod picture in the iTunes pane to discharge the iPod. The iPod picture will disappear. Make sure that you also safely release the iPod in the task bar at the bottom of the computer. You will need to click on a green icon that looks like a plug and select 'safely remove storage device'. Wait until the computer tells you it is safe to disconnect it. Then disconnect.
Hope that helps.
Dec 19, 2008 | Apple iPod nano
Need driver for ipod nano for windows millenium
You will need to download the latest version of iTunes. It is free. When you have done that, load all of your music into iTunes. Then connect your iPod to the computer with the internet connected. You should be able to see your iPod on the left side of iTunes. You can then click the music tab to tell itunes what music to load into your iPod.
Be sure to click the arrow next to your iPod when the syncing is finished to release your iPod from itunes. Also click the green plug icon at the bottom right of your windows screen. If you cannot see the plug, click on the white arrow until you see the green plug. Click on it and you will see your ipod listed as a mass storage device and a message asking if you want to disconnect it. Click disconnect mass storage device and wait until you see a message saying ;safe to disconnect mass storage device. Done. Hope that helps.
Nov 21, 2008 | Apple iPod nano
My Computer and iTunes does not recognize my iPod
Try this: turn off your ipod, hold the home button, and plug it into itunes while still holding the home button until a picture of the itunes symbol appears with a cable under it. itunes should say "ipod found in restore mode". This will completely reset your ipod, hopefully fixing any bugs or problems in it. also, you will lose all data saved on the ipod that isn't also backed up by itunes. Music, pictures, and video can be re-synced.
Aug 16, 2008 | Apple iPod touch
Itunes
have you tried to check for problems on your computer. it could be your computer may be the one at fault for not allowing you to connect to itunes.
Aug 12, 2007 | Apple iPod nano 2nd Generation MP3 Player
Apple iPod nano 3rd Generation Logo
261 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
