Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Kitchenaid dishwasher Freestanding dirty water left in the bottom of the machine after the rinse cycle is completed.
  • kimmeeez Apr 29, 2008
    Brand new builtin dishwasher. I have run it 2 cycles now and it always completes it's full cycle with the bottom being full of dirty water up to the brim.
    I've changed the route of the drain tube for the 2nd cycle and had same results thinking that it was too much of a rise the first time.....
    Any ideas??? what else to try as I purchase it new as a scratch and dent warehouse without warranty.
    President:
  • KitchenAid Master
  • 2,651 Answers
I would check your drain for restrictions under sink. fill with water, and then cancel cycle, did you hear water draining freely??? sounds like a clog
Posted on Feb 22, 2008
Dishwasher not cleaning very well.
Hello do it heat up ok is the water Hot please
Nov 13, 2015 | Siemens Dishwashers
Top (upper rack) of dishwasher does not wash. bottom does mediocre job
Make sure top rack is backed up into water entry in back of diswasher. Also check to make sure holes are not plugged in rotating wash arm. You may have to wash your dishwasher..take out the racks and look to see if they have food gunked up on them, if so wash them off in the sink. Take out the top rack clips and wash the rails inside the tub if they are dirty. You can use a squirt bottle with warm water. Do this after you run a rinse cycle so that dried food gunk is softer. There are alot of places in this machine for food to stick then resurface later. you may try also adding vinegar and baking soda to a rinse cycle and then leaving in it soak before restarting it.
Feb 10, 2011 | KitchenAid Dishwashers
I have a ADG450 about 7 years old, the problem is there is dirty water left at the bottom of the dishwasher after finishing the cycle and the dishes look as if they have had the final rinse in the dirty...
check the pipe leading from the dishwasher to the outlet, maybe under sink. this needs to be raise up as water will flow back into washer. Had this problem myself, felt foolish when the repair man just tied it up and left. !
Jan 03, 2011 | Whirlpool ADG450 Slim-Line Built-in...
Dishwasher not draining completely-suds left
Dishwashers shouldn't have suds so somehow dishwasher liquid was introduced to the dishwasher. Vinegar, alcohol, or a small amount of cooking oil might help eliminate the sudsing.
Jun 20, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
There is a smell in the dishwasher and on the dishes when clean
I suspect stagnant water is laying in the bottom areas. You will have to lay the machine on it's back to access the pump.
May 27, 2010 | KitchenAid KUDK03ITBK Built-in Dishwasher
Dishwasher smells after completed load. The water left on top of cups etc is dirty.
your machine is likely not getting rid of all the dirty water after the wash cycle. you need to make sure there is no debris left in any filters in the bottom of the machine and see if there is a part called a check valve somewhere, it may need to be replaced.
Oct 16, 2009 | Kenmore Dishwashers
No water in kitchenaid dishwasher -- everything dirty and dry after wash cycle. rinse cycle the same. any ideas what might be wrong?
Simplist reason for no water in a machine that has been working well, is to check to see if the float, that is telling the machine to add water or stop because it is full, is stuck. I have had a measuring spoon fall out of its tray and fall under the float located in the bottom of the unit and hold the float up telling the machine it is full of water. It usually looks like a mushroom and should bob up and down.
Oct 03, 2009 | KitchenAid Dishwashers
Water seems to be hot enough, drains properly, arnms not blocked, dishes not being cleaned at end of cycle. Almost seems like it is skipping the wash cycle.
Hi smiller8565,
There is 3 basic problems that will cause a dishwasher to not clean the dishes. You can check these problems and see if any will solve your problems.
1: If there is water or suds left in the dishwasher after the cycle is complete. This will cause dirty water to be used in the final rinse and the dishes will not get clean.
2: The pump that supplies water to the spray arms is jammed or defective and unable to pump the water properly, thus causing the dishes to remain dirty.
3: Timer, the timer is not allowing the machine to work in the wash cycle.
The solutions for these 3 are as follows.
1: check the drain line for blockage, if you have a disposal make sure it is clear and water flows down the drain properly. If you have suds left in the dishwasher, clean them out and run a couple cycles with not detergent to rinse away the old suds.
2: Look down in the bottom for any obstructions in the pump. Popcorn seeds, broken glass, etc.
3: If the unit is skipping the wash cycle you will most likely need a new timer or control assembly.
Good luck and I really hope this will Fix Ya
Mike
Sep 24, 2008 | Dishwashers
Frigidaire Model FDB2810ldc0 s/n:TH43526319
Dishwasher is leaking water from underneath during the rinse cycle and a small drip during the wash cycle
Sep 22, 2008 | Dishwashers
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
121 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
