Question about Motorola Mobility MD671 Cordless Phone
My handset won't charge
For a month or so, I had to set the phone just right so that the connectors would hit and the handset would charge in the base/cradle. (with very little trouble). Now, when I place it in the base unit, the "Charging" light doesn't light up and the cordless handset doesn't work (Battery is low).
Do I just need to buy a new battery or do you think the connections have somehow gone bad & I need a whole new phone?
  • Anonymous Apr 26, 2009
    I replace the batteries on my cordless phone and still will not charge.
Try charging it in a different cradle if you have more than one handset.  This has happened to me where a particular base will not charge a particular phone.  Once charged elsewhere the problem resolved.
Posted on May 03, 2008
Handset won't charge
Not using the handset for several months  would have allowed corrosion to develop on the charging contacts.  You have to use cotton buds and a strong solvent to clean the charging contacts.
Alternately, it may be that the battery is already dead and no longer would accept a charge.  These are plug-in types and are replaceable.  Incidentally, it is also possible that the corrosion developed on the battery connector contacts themselves.
Indication of corrosion would be dull colored contacts with bits of flakes - clean to make shiny again; the connector corrosion would be wet powdery greenish substance on the wires or connector from the battery.
Hope this be of some help/idea. Post back how things turned up or should you need additional information.
Good luck and kind regards.
Oct 26, 2007 | GE 25951EE2 Phone
Uniden xdect 7015 won't turn on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Jul 28, 2012 | Uniden DECT 6.0 Cordless Telephone...
How to open the gprs on globe
Sometimes,GPRS configuration settings automatically pop-up when you insert your sim and powering the phone ON.it will ask you save and confirm as the default.also ask for the code then just enter 1234. it is free of charge on globe now a days.
For a complete listing of compatible MMS & GPRS phone handsets - send Nokia, Sony-Ericsson, Motorola, LG, Verzio, iPhone 3G or Samsung (your handset model) to 2365.
To get your phone's settings, text GO (handset model) to 2951. Example, GO N3650. (For a list of compatible handsets, refer to #1)
Note: For Nokia 6220, 6600, and 6820, text GO < handset model >,1234 and send to 2951. Make sure to type in the two commas before the 1234 PIN. Regular text messaging charges will apply.
* Enter 1234 when asked for PIN to save settings.
Note: For prepaid subscribers, please make sure you have credits first before trying to access GPRS/MMS. You won't be able to use the service if you have zero balance.
Aug 10, 2011 | Cell Phones
Phone keeps dropping calls
Same issue here. Have you checked the battery? I found out that on mine the battery was leaking and corroding the contacts. Need to call Panasonic to find out if they can do something (about 5 month old phone)
Apr 02, 2009 | Panasonic KX-TG9333T Trio Cordless Phone
Panasonic KX-TGA101S base not charging.
Here are a couple things you can try.
Clean the charging contacts, this can be done two ways. The manufacture's recommend using a pencil eraser. I recomend using a q-tip and some rubbing alchol. Just rub the alchol soaked q-tip on all the metal contacts on the bases and the bottom of the handset.
Gooo luck.
Hope this helps
Mar 12, 2008 | Panasonic KX-TG5632 Phone
How do I add an extension handset to my current config?
IF it was a used handset it was likely registered to another base. I just switched bases (1line to a 2 line base). I had to "deregister" the handsets from the old base. I am not sure if you can deregister if the old base is not present? With the old base plugged into power I hit the "function key" at the bottom left of the handset and scrolled down to initial settings. Under registration is "deregistration". I selected that and it put the handset back to its default out of the box. Then simply hit the mute button on the New base and OK on the handset. Worked for all 5 of my old handsets.
Hope this helps
Jan 27, 2008 | Panasonic KX TGA270S Cordless Expansion...
Lost pairing?
First when ya call connects, hit the Menu key (three lines inthe center) choose USE HANDSET.
Second Make sure the Bluetooth is fully charged, andit seems to lose charge fast.
Dec 15, 2007 | Motorola Mobility H300 Wireless Headset
Motorola 580 handset not working
My handset does not connect to the base station. It flashes momentarily, but does not find the base. The base station has a humming noise when the phone line is disconnected and the talk button is depressed. Hum is also present when the phone line is reconnected. The problem was resolved by replacing the 9VDC power supply. The hum disappeared and the handset immediately connected to the base.
Oct 31, 2007 | Motorola Mobility MA580 (612572111116)...
Handset Buttons Stopped Working - Full Battery
Here is a link to Uniden's site, and on the right side of the page, there is a link for a download manual pdf and helpline
http://www.uniden.com/products/productdetail.cfm?product=TRU8885-2
also worth checking if any buttons are stuck, or if the handset is set to pulse rather than tone mode, or if it has had a tumble or knock, possibly the keypad connector has come loose .
Hope this helps.
Sep 17, 2006 | Uniden TRU8885-2 Cordless Phone
Motorola Mobility MD671 Cordless Phone Logo
553 people viewed this question
Top Motorola Mobility Lands Phones Experts
John Donghia Jr.
John Donghia Jr.
Level 1 Expert
Eric Sutherland
Are you a Motorola Mobility Lands Phone Expert? Answer questions, earn points and help others
