Question about Mitsubishi VS-5043 50" Rear Projection Television
Blinking green light
I have a mitsubishi ws-65909. i unplugged it recently and when i plugged it back in the green light on the front blinks and the unit does not turn on. i tried reseting the tv and unplugging it but neither worked.
  • mikecd Feb 14, 2008
    i don't understand what you wrote. are they fuses? why am i having problems with the tv now? i unplugged it hours before a storm but did nothing unusual.
    thank you for your help!
    thank you for your time, i will begin making calls, unless you live in the florida big bend area.
    Sergeant:
  • 395 Answers
SYMPTOM: Power LED does not stop blinking after plug in.
CURE: Check C9B01, C9B02, C9B03, C9B13, C9B14, C9B17 and C9B18 (1000 uFD, 16V,
105C) on the DM Power PCB located within the DM Assembly. If they are bad, replace them with
part # 181P734030 (680 uFD, 16V, 105C).
I have done one of these repairs and they are quite difficult so have a tech do this repair.
Posted on Feb 14, 2008
  • Robert Johnson Feb 14, 2008
    these are failed capacitors in the DM module. this is the Digital module, a large shielded metal box to the left side inside the tv. over time capacitors (mini batteries) fail due to age, they dry up and cause failures in the system. electronics is not infailible something at some time will fail. remember if the set is plugged in it is always running. this a job for a tech it may cost you $300.00 depending on the tech you get. just tell them what I told you about the capacitors in the DM circuit so he (or she) isn't fumbling around to find the problem. this is a known failure in this set. like I said... this is a difficult repair it takes complete dismantling of the internal components to get to the caps.(capacitors). this repair is not for the novice.
I have ws-65909 65 in TV , The power went out and now the timer light is blinking and i can not reset it.
Unplug it for 2-3 hrs. then when you turn it back on again, be sure to reset the sleep timer to "off".
Sep 08, 2010 | Mitsubishi WS-65909 65" Rear Projection...
Power went off in house when it came back on the green light on the front panel keeps blinking will not stop Mitsubishi Bigscreen model ws- 65909
I've got a 65535. When this happens, you can sometimes press the On-Off button for 10-15 secs until the light goes off. If that doesn't work, then unplug the tv for 30 seconds or so, then plug back in.
These sets are known to have power supply issues, and the blinking light may be a coincidence to the power supply failure. It's fairly easy to repair if you know how to solder.
Dec 10, 2009 | Televison & Video
Timer light binking green
U have a DM problem CAPs burned out. download repair manual for your TV.
Jun 30, 2009 | Mitsubishi WS-65909 65" Rear Projection...
We have the dreaded blinking green "timer" light after we unplugged the WS - 65909. We can't get it to reset according to the owner's guide instructions.
The Digital module must be repaired. It is not booting up. When first plugged in the LED in that set will blink for 70 to 90 seconds. That is the amount of time it takes for the digital module to boot up. If it continues to blink past that time the module is belly up and needs to have some capacitors changed in it. Most reputable shops can do this in your home and average cost is between $150 and $250 depending on where you live.
Jun 11, 2009 | Mitsubishi WS-65909 65" Rear Projection...
The green light blinkig and does not stop, no picture
Did you try unpluge from the wall, and repluging back after 10 min.
Also run the self diagnosis by pushing the menu and device buttons on the front and let me know the code?
Thanks
K
Apr 23, 2009 | Mitsubishi WS-65909 65" Rear Projection...
Green light on front panel will not stop blinking
gree light in front won't stop blinking after I plugged on the tv ws-65909
Mar 22, 2009 | Philips 9P5034C 50" Rear Projection...
Green light blinking
The green light on the front blinkes and does not stop even after hitting re-set button.
Oct 26, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Ws 65909
I had a half power outage where everything turned half off, how I still dont know. Anyways I unpluged it and didn't plug it back in until the next day. When I did the timer light was blinking for an hour. I unpluged it for a couple hours more, then I plugged it in and waited for 1 min, unplugged it and repeated, then I plugged it and unplugged it 3 or 4 times in a row, plugged it back in and waited. 1 min. then poof the tv worked. YAAAAAA HOOOOOO!!!!
Dec 30, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Will not power on
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
Dec 09, 2007 | Mitsubishi WS-65909 65" Rear Projection...
Televison & Video Logo
78 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
